PCM relay cycling - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-24-2013, 07:05 PM   #1
highplainsbubba
Fan#: 116082
What I Drive: 2007 Gray SE
FF Reputation: 1 highplainsbubba Good Standing Member
Relay clicking under dashboard
I have a 5 spd man 2007 SE, 104K miles. It runs well but I hear a relay under the dash cycling every 30 seconds or so. I traced it to the PCM coil relay fuse #39 (2 amp). When I pull the fuse, the relay quits cycling. This is without the engine running, with the key on. Like I said, there is no apparent problem other than the relay cycling. The engine runs well and all the windows, cruise,radio, fuel pump and lights work. NO check engine light. Is there an onboard diag that I can run or do I need a code reader?
Update: The fuse was a wild goose chase. It controls power to a lot of things. See the solution below.
highplainsbubba is offline
Old 06-24-2013, 09:18 PM   #2
Focus_on_Christ
Fan#: 96197
What I Drive: 2005 Focus ST California Special
FF Reputation: 1 Focus_on_Christ Good Standing Member
If there are no idiot lights on, there may not be a code. Pepboys and AutoZone checkcodes for free, though, so you could take it there.
I recommend getting a new fuse, just to be safe, while you are there.
Focus_on_Christ is offline
Old 06-24-2013, 09:35 PM   #3
amc49
Fan#: 96610
Points 3,212, Level 35
Points: 3,212, Level: 35 Points: 3,212, Level: 35 Points: 3,212, Level: 35
Level Up 8% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
FF Reputation: 25 amc49 Great Standing Member
Fuse should be good if relay is cycling, couldn't do it if no power to it and no fuse on earth blows and then comes back as good.
Could simply be a bad relay, I'd be trying to find out just what it powers.
amc49 is offline
Old 06-25-2013, 08:31 AM   #4
highplainsbubba
Fan#: 116082
The relay that is cycling is inside the interior fuse box. It is not visible from outside the fuse box. I notice there is a fuse on the back side of the fuse box. Any idea what that does? The web says it is for dealers only. Is there anywhere on the web I can get the schematic for this vehicle without forking over the big bucks? I will take the car to the parts house for a code scan. It can't do any harm. I may also disconnect the battery and see if the problem goes away with a power cut.I think something in the logic is causing the relay to cycle. It is probably the "I have run for 100K miles trouble free, and now I am causing problems so you will have to pay" circuit.
Old 06-25-2013, 11:56 AM   #5
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,526, Level 30
Points: 2,526, Level: 30 Points: 2,526, Level: 30 Points: 2,526, Level: 30
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
Forum Activity 12%
Sounds like a loose wire, bad ground, or other connection issue.
There likely will not be a code, and if there is it might send you looking in the wrong place.
elsolo is online now
Old 06-25-2013, 01:07 PM   #6
amc49
Fan#: 96610
Forum Activity 60%
Look in fusebox for another relay exactly the same with same number on it, if you find one, switch them, will tell you right there if relay or not. A weak coil in relay can easily do that.
After that you will need to assess what that relay does to check things out further.
amc49 is offline
Old 07-01-2013, 08:46 PM   #7
highplainsbubba
Fan#: 116082
Found the problem
Apparently the rear wiper was turned on. It seems the rear wiper is in-op so I didn't know it was turned on. I will have to trouble shoot that problem now. The fuse is good, so it is probably the wiper motor. I have the 3 door hatchback so there are plenty of refurbished wiper motors on Ebay.
That was a lot of irritation for a small problem. I see in the forum when searching for "clicking relay", I am not the only one to make that mistake.
Cleaned and checked the wiper motor and re-installed. Works well with the hatch back in the up position, quits when the door is closed.
OK. here's an update for all you hatchback Focus owners. I bought this Focus new and have had it since OCT 2006. The rear wiper was inop due to a broken wire in the bundle at the hinge point of the hatch back, where the bundle leaves the roof and enters the hatch back. EVERY wire in the bundle had broken insulation and frayed wires from the hatch back opening and closing. I had to solder an extension wire into each wire in the bundle to get it to go back together. The saga of the clicking relay is now over. If you're having problems with anything on the rear hatchback, check the harness at the hatch back hinge point.
