Blow By Build Up - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-24-2013, 04:24 PM   #1
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,703, Level 100
Points: 73,703, Level: 100 Points: 73,703, Level: 100 Points: 73,703, Level: 100
Level Up 0% Completed
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
Blow By Build Up
Okey dokey. I guess it was bound to happen sooner or later. I have oil build up in my charge piping and IC that is intermittently making it's way into the engine causing it to smoke on occasion. I know I have to disassemble the charge piping and clean it, the MAF and the IC.
I now have my PCV and my valve cover (EGR, I think) routed to a catch can that's venting to atmosphere, so as far as I know, this will alleviate the blow by oil after I clean it up.
So, my question is...what is the safe way to clean out the IC without damaging it? Thanks in advance.
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 06-24-2013, 04:38 PM   #2
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
It should be coming from the front side of the turbo which will need servicing. Remove the IC to clean an drain it well.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 06-24-2013, 05:08 PM   #3
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
I've been researching it and have found that some people use carb cleaner followed by soapy water and then clean water to rinse. After drying well, put everything back together and then let the car idle for 15-20 minutes to ensure evaporation of residual water. Does this sound right?
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 06-24-2013, 10:21 PM   #4
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
does the turbo have shaft play?
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 06-25-2013, 05:05 AM   #5
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
No clue.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 06-25-2013, 08:08 AM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
You can clean it with about anything you want , its Alum and anything short of acid or psi washing will be fine
Carb cleaner then soap will be good , if you can use hot water to rinse it it will dry good after you stand it on one end to drain , or like you stated and let it idle for a bit
On to the cause , this doesnt just happen if you have oil pre intercooler the only place this can come from it turbo , either your over spooling or shock , over heating the turbo or you have seals going or gone out , one last thing could be excessive oil psi and volume to the turbo , I would check things in this order
oil psi / volume to turbo , you should be running a -3 oil line and a restrictor ???
over spooling or shocking , are you making boost out side its limits or the BOV not working properly where when you let off the throttle your stopping/slowing the spinning of the turbo ?
Overheating the turbo , excessive cyl temps , lack of enough fuel at wot , nothing over 11.3 AF or excessive timing ?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 06-25-2013, 05:11 PM   #7
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
Thanks for the info, Tom. How does one go about checking oil PSI?
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 06-25-2013, 06:37 PM   #8
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
Where does the smoke come from? When I'm doned riving smoke comesfrom passenger fenderbecause the dp touches my ac compressor
FF MODERATOR
RIFF CREW
Old 06-26-2013, 05:13 AM   #9
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
It's coming from the exhaust, so oil is making it's way into the engine and burning off. I'm looking at taking the charge piping apart on Sunday, cleaning everything and taking a look at the turbo.
Also, what's the safe oil pressure range for an '05 ZX4, 2.0L ATX with a GT28RS stage II?
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 06-26-2013, 08:21 AM   #10
Mother Focus
Fan#: 73292
It may come from the hot side of the turbo and leaking into the exhaust. Your engine should have a healthy oil pressure...what restrictor in what line size are you running to feed the turbo? In the return? Oil will get back to charge pipe and IC if turbo needs new seals.
PTE 6262CEA
