N/A Mk3 Rear Motor Mount Write Up (Pic Heavy) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-24-2013, 11:08 AM   #1
ShoOff
ShoOff's Avatar
Fan#: 109590
What I Drive: 2013 Performance Blue SE Hatchback
Points 1,858, Level 25
Points: 1,858, Level: 25 Points: 1,858, Level: 25 Points: 1,858, Level: 25
Level Up 58% Completed
FF Reputation: 16 ShoOff Great Standing Member
Decided to do a quick write up on how to reaplce your rear motor mount in a n/a mk3. Bare with me as im not one for words, give me a break im a motorcycle mechanic, so this thread uses a lot of pictures.
To get started you are going to need a T30 torx bit, 13/15mm wrenches or sockets, a lift or car ramps, and about 45 mins. Optional is a engine stand to help align bolt holes during installation. You dont have to have one but it sure helped!
1st off remove the slash gaurd/ engine cover from below the car. This is held in with about 8 torx screws......
After the cover is removed then you can start by removing the bracket that holds to mount to the motor and the bolt that holds the mount to the frame.
Once those bolts are removed you can then remove the bracket, once thats gone you can remove the old mount.
With those two items removed you can now slide your new rear motor mount into place where the old one once was. You need to do this BEFORE reattaching the bracket. (Also I used a Cobb RMM, and it came with a replacment bolt to attach the mount to the bracket. This isnt the case for everyone)
In order for you to get the holes to line up to reattach the bracket to the mount you simply just need a little force in whatever direction the hole is off by. I used a spiral motor jack so it made it really easy.
Once all your bolts are back in and torqued down take a good look at your mount.......... sadly this is the only time youll get to see it! Reattach the splash gaurd/engine cover with the T30 torx screws and your good to go! Hope this was helpful to anyone needing guidance. If i missed something please let me know!
Steeda CAI, Steeda STS, Magnaflo Cat Back Exhaust, Injected Tuner, Cobb Rear Motor Mount, TTR Upper Motor Mount, Injected °180 T Stat
ShoOff is offline
Old 06-24-2013, 11:12 AM   #2
RonMaiden
RonMaiden's Avatar
Fan#: 99230
What I Drive: 2012 Red Candy Metallic Hatch SE
Points 4,181, Level 41
Points: 4,181, Level: 41 Points: 4,181, Level: 41 Points: 4,181, Level: 41
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 6 RonMaiden Good Standing Member
How much was the Cobb? Definetly a must do mod.
'12 Focus Red Candy SE Sport 5 spd
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is online now
Old 06-24-2013, 11:26 AM   #3
SPRAYPAINT
SPRAYPAINT's Avatar
Fan#: 89747
What I Drive: 2014 Sterling Grey Focus SE Sedan
Points 2,178, Level 28
Points: 2,178, Level: 28 Points: 2,178, Level: 28 Points: 2,178, Level: 28
Level Up 19% Completed
FF Reputation: 2 SPRAYPAINT Good Standing Member
Good job ShoOff! I can't wait to have a little fun on the way to FF13. I'm thinking about a tuner but not sure at the moment.
It is what it is in life... Just have fun with it!
January 2012 Ride Of The Month
SPRAYPAINT is offline
Old 06-24-2013, 11:36 AM   #4
Gadabout
Gadabout's Avatar
Fan#: 114774
What I Drive: 2006 Vermillion Red ZX4 SE
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 4 Gadabout Good Standing Member
Idk about you guys, but isn't the pretty stuff that people Can't see, still as fulfilling as the stuff that "wows" externally?
Great write up, I don't have an MK3, but I definitely appreciate a benefiting upgrade =]
“Things work out best for those who make the best of the way things work out.” - J Wooden
Team Duratec #42
Gadabout is offline
Old 06-24-2013, 12:58 PM   #5
liquidblue88
liquidblue88's Avatar
Fan#: 109694
What I Drive: 2012 Tuxedo Black 5dr Titanium
FF Reputation: 1 liquidblue88 Good Standing Member
Fantastic write up!!!!
Thank you for doing this! I definitely feel comfortable giving this mod a shot now!
liquidblue88 is offline
Old 06-24-2013, 01:44 PM   #6
ShoOff
ShoOff's Avatar
Fan#: 109590
thanks for the comments guys!! DIdnt know if i was waisting my time or not. If anyone needs help with this or Injected tuner ?'s please feel free to give me a call.
Also Spraypaint, Whats to think about bro! Its sooooo worth the money! But deff looking forward to out caravan up to St Louis!
ShoOff is offline
Old 06-24-2013, 01:45 PM   #7
ShoOff
ShoOff's Avatar
Fan#: 109590
I think the Cobb mount ran me like $170. I know there are cheaper options out there, (MS#, electric, etc) but something about the Cobb spoke to me.
ShoOff is offline
Old 06-24-2013, 07:44 PM   #8
miuzi05
miuzi05's Avatar
Fan#: 106045
What I Drive: 2013 Race Red SE Sedan 5MT
FF Reputation: 1 miuzi05 Good Standing Member
I see a lot of people recommending replacing the rear motor mount, but I'm unclear as to what benefit is gained from it. Can anyone enlighten me?
miuzi05 is offline
Old 06-24-2013, 07:47 PM   #9
ShoOff
ShoOff's Avatar
Fan#: 109590
The stock mount is WAY to soft of both N/A models and the ST. Becasue of this sometimes under hard acceleration you get a lot of "Wheel hop" and sometimes the motor its self will even slam into the firewall! Replacing with a stiffer mount reduces all of that and will make your car more "connected". It will also help put power down to the wheel instead of the loss your get with engine movment.
ShoOff is offline
Old 06-24-2013, 07:49 PM   #10
miuzi05
miuzi05's Avatar
Fan#: 106045
Ah, beautiful explanation. Thanks!
miuzi05 is offline
