Q: Ford 18" Titanium vs 18" ST (wheel)? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST
Focus ST The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK3 2013-Current Focus ST.
Old 11-09-2013, 11:26 AM   #21
jsr72
Fan#: 97393
What I Drive: 2012 Focus SE
Points 151, Level 3
Points: 151, Level: 3 Points: 151, Level: 3 Points: 151, Level: 3
Level Up 2% Completed
FF Reputation: 5 jsr72 Good Standing Member
Originally Posted by ~dodge View Post
http://hpwizard.com/rotational-inertia.html
i've been educating myself w/more info on this topic. & after reading thru some of the calculations etc. linked above, guess enkeis numbers are indeed a bit generous.
appreciate your patience regarding the discussion. it's something i'm obviously pretty passionate about. have been studying inertia & wheel weight since a child bmx racer & am always looking for any advantage against competition.
The link above is the best online estimator out there IMO.
Sometimes I wonder if the enkei numbers were originally calculated per 4 wheels/entire vehicle and then somebody erroneously multiplied the savings again by 4 wheels. They are pretty much off by a factor of 4.
jsr72 is online now
Old 11-12-2013, 06:29 PM   #22
Hempster
Hempster's Avatar
Fan#: 29310
What I Drive: 2014 Tuxedo Black Focus ST3
Points 739, Level 14
Points: 739, Level: 14 Points: 739, Level: 14 Points: 739, Level: 14
Level Up 39% Completed
FF Reputation: 3 Hempster Good Standing Member
Originally Posted by ST 2K5 View Post
Wow its amazing to me how many people race professionally here.. worrying how to shave off a few pounds just to cut those extra all important milliseconds..
...and then put "all-seasons" on?
What's up with that?
Tuxedo Black 2014 Focus ST3
CD Silver 02 SVTF, #1336 - R.I.P.
"Brace for the G's, and fast heel-toe work!"- Hunter S. Thompson
Hempster is offline
Old 11-13-2013, 01:36 AM   #23
~dodge
~dodge's Avatar
Fan#: 120453
What I Drive: 14 ox white st3 202a 07cbr6rr 89mr2
FF Reputation: 1 ~dodge Good Standing Member
you know, now that would make a LOT of sense & i think you're right. wonder if anyone else has ever mentioned anything to them.
the all seasons are due to dealing w/everyday to day driving in the part of u.s. i live. also kumho ecsta 4x only weigh 20lbs a tyre. that's actually pretty light considering the size & it's versatility.
~fall down seven times, get up eight~ taoist proverb
......can't stop stupid sir; i can only slow it down....
~dodge is offline
Old 11-13-2013, 02:08 AM   #24
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 7,950, Level 59
Points: 7,950, Level: 59 Points: 7,950, Level: 59 Points: 7,950, Level: 59
Level Up 50% Completed
Forum Activity 9%
FF Reputation: 11 Joeywhat Great Standing Member
The point is that you're worrying about such minuscule gains while running tires that don't grip nearly well enough to allow the lost weight to make a difference.
Hatch Nation #29
Joeywhat is online now
Old 11-27-2013, 05:55 PM   #25
~dodge
~dodge's Avatar
Fan#: 120453
Exclamation ))))25% weight reduction((((
i doubt many would consider a 25% weight reduction miniscule. so, you weigh 200lbs & lose 50; that'd be considered minor weight loss???? more weight=increased rolling resistance
strongly recommend this modification as it will easily pay for itself after
'x' amount of miles, due to the 3-4 more mpg, you'll gain @ freeway speeds. when i did a similar modification to an older car it ended up saving me an entire tank of fuel every 700 miles. that's around 35-40$ every 700 miles that i'd prefer to keep or spend elsewhere
lightening your wheels & tyres is another method of reducing fly-wheel weight w/out the massive expense of the part & install of said part. & i assure you, my summer tyre & wheel set up will be putting just as much rubber to the road ie equal sized contact patch as oem w/tyres having exact traction & tread-wear rating; but weighing potentially more than 25% less. my other replies were mostly regarding my winter wheel & tyre set up. (it's 13 1/2 lbs lighter than oem that's 27% decrease) had i purchased similar 'non-studded' snow tyres for the oem 18x8" wheel it would of cost another 400$+ over current winter set up & have the oem wheels & tyres available for re-sell oem ST tyres are NOT recommended or very usable, in 40f or lower temps so 1st major expense for winter driving, will be a proper winter tyre set up, if you just bought a car w/eagle F1 tyres installed.
efforts of en-lightening-ment
~dodge is offline
Old 11-28-2013, 10:20 AM   #26
Pennut
Pennut's Avatar
Fan#: 91326
What I Drive: 2012 Sterling Grey SE Hatchback
Points 1,469, Level 21
Points: 1,469, Level: 21 Points: 1,469, Level: 21 Points: 1,469, Level: 21
Level Up 69% Completed
Forum Activity 6%
FF Reputation: 5 Pennut Good Standing Member
Found this article on Car and Driver....
http://www.caranddriver.com/features...d-tires-tested
I had a 2006 Dodge Magnum SXT that came with 215/65-17 on 5 spoke alloy wheels. I bought a set of the 18" alloy wheels that came on the R/T's with 225/60-18's and used them in the summer. Mpg loss with the 18's was 1 mpg. The speedometer difference was within 1 mph. I believe the mpg loss was more from the wider tire (larger contact patch = increased rolling resistance) than any extra weight.
You might cut a couple 10ths of a sec off 0-60 mph and in the 1/4 mile by going to a (much) lighter wheel, but it's not going to be seconds. No way. You could make your ST faster by going to a thinner tire, but then you would lose cornering performance. Best thing to do is simply make sure you are not carrying any extra stuff (weight) you don't need in the trunk or in the car.
Pennut is offline
Old 12-07-2013, 06:08 PM   #27
Zokambaa
Zokambaa's Avatar
Fan#: 119300
Location: Calgary... (that other place in Canuckland), Canada
What I Drive: 2014 TS Focus ST (Built 27.08.2013)
Points 9, Level 1
Points: 9, Level: 1 Points: 9, Level: 1 Points: 9, Level: 1
Level Up 17% Completed
FF Reputation: 1 Zokambaa Good Standing Member
as long as I get 350km on a tank of gas around I couldn't really care less if I hit 400km then that is good too... I went to 17" winter rims which comparatively feel lighter (did not get exact weight) but they feel a bit lighter than the stockers... if anything I am getting more poor gas mileage than on my summers... perhaps the climate makes a difference since the sub freezing temps lately do rather suck...
But really though... why are people really all that worried about gas mileage on "performance" vehicles? You can drive like a granny on poor handling tires and get a bit more mileage... but what is the point in that? I saved about 4 or 5 bucks on a tank of gas... but I'd pay that 4 or 5 bucks for the enjoyment factor of driving the car in a fashion that it was designed for... if I cared for mileage and granny driving I'd get the base non ST focus instead.
Zokambaa is offline
Old 10-08-2014, 12:05 AM   #28
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,371, Level 77
Points: 14,371, Level: 77 Points: 14,371, Level: 77 Points: 14,371, Level: 77
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 19%
FF Reputation: 15 Elizabeth Great Standing Member
I was looking for the weight of the OE ST wheel and ran into this thread.
I only wanted to add: The greater mass of the stock wheel is really great when you hit a pothole. IE it is not gonna bend like a pretzel
The OE wheel is NOT gonna' fold up like most of the lightweight ones will. Now yeah if you buy a set of forged wheels at $700 a pop it can be light AND strong..
Those 19 pound $150 wheels just may not hold up in real world use.
My trivial street stoplight chases aside. The stock wheels are exactly the kind of strong, not-breaking stuff i want on my car.
If I decide to go racing for real.. Then yeah I would have a set of ultralight and racing tires.. And go back to the street tires and wheels when on the street.
Elizabeth is online now
Old 11-10-2014, 05:32 AM   #29
Radiation Joe
Radiation Joe's Avatar
Fan#: 201441
Points 2, Level 1
Points: 2, Level: 1 Points: 2, Level: 1 Points: 2, Level: 1
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
FF Reputation: 1 Radiation Joe Good Standing Member
Thanks for reviving an old thread. I just purchased a non-ST with the Titanium handling package. Even with the stiffer springs and shocks I could still feel the weight of 18s and 235s.
One week later and I've installed my winter 215/55-16s on 16x7.5 wheels and saved 8 lbs per corner. Although I already miss the responsiveness of the 235/40-18 PS3s, I immediately noticed the difference in ride due to the lighter wheel and tire combination. It's much easier for the shocks to keep the tires planted on the road.
On a completely unrelated note, can anyone tell me if the titanium handling package uses the same steering knuckle as the ST? I'm less than two turns lock to lock and I suspect I may have the quicker steering of the ST.
Radiation Joe is offline
Old 11-10-2014, 06:15 AM   #30
jsr72
Fan#: 97393
Points 151, Level 3
Knuckles are different. See the Edmunds suspension walkarounds.
jsr72 is online now
