A/F ratios??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-23-2013, 08:17 AM   #1
zetec#1
Fan#: 34556
What I Drive: 2002 focus ZX3 n/a built,terry hein
FF Reputation: 1 zetec#1 Good Standing Member
A/F ratios???
Whats a All Motor AFR run around town and idle????
zetec#1 is offline
Old 06-23-2013, 10:42 AM   #2
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,021, Level 33
Points: 3,021, Level: 33 Points: 3,021, Level: 33 Points: 3,021, Level: 33
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
FF Reputation: 3 paulg127 Good Standing Member
With the vehicle in closed loop, it will run stoich air/fuel ratio.
Stoich is dependent on your fuel composition, gas is 14.65, the current 10% ethanol/gas nationwide std is 14.09.
Regardelss of your fuel composition, if you have an aftermarket wideband, you should set it for lambda reading, so you don't have to worry about fuel composition.
Lambda of 1.0 = stoic on the wideband, that equals ~.45 volts on an EGO sensor.
When the vehicle is at high loads/pedal it will run richer, around 13:1 with stock cal.
Why did you post this question?
paulg127 is offline
Old 06-23-2013, 07:54 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,876, Level 100
Points: 51,876, Level: 100 Points: 51,876, Level: 100 Points: 51,876, Level: 100
Level Up 0% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
At idle in closed loop the ECU is always switching the AF , so you will see between 13.5 and 15.3 +/-
WOT or high load you dont want to see anything over 12.8-12.9
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 06-27-2013, 12:02 AM   #4
svtgunsmith
Fan#: 115359
What I Drive: 2002 sonic blue svt
FF Reputation: 1 svtgunsmith Good Standing Member
this has me wondering why im seeing 11 to 11.5afr wot on my innovative lc1 wideband
even though my car came with an sct tune by steeda canada
from what I understand best n/a power is typically 12.8 to 13.5 afr but my dyno sheet shows 172 whp
I am also using Esso 92 octane gas which apparently contains no ethanol
svtgunsmith is offline
Old 06-27-2013, 10:18 AM   #5
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
With out knowing your mods I cant say about the dyno sheet other then that sounds high for NA , as for the AF your very rich and loosing performance in WOT from that
WOT I wouldnt go above 12.8 there is no power gain from 12.8 to 13.2 thats worth having over the engine safety 1 - 2 Hp
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 06-27-2013, 10:40 AM   #6
svtgunsmith
Fan#: 115359
Bought the car already modded so these are the mods I know about
Cold air intake, 67mm throttlebody, underdrive pulley's, clutch with light flywheel
borla catback exhaust and steeda canada tune
heres my dyno pic
Old 06-27-2013, 06:16 PM   #7
zetec#1
Fan#: 34556
Sparco steering Wheel(310) and quick release is in, got the XC3 ,made the Firewire, got a new laptop, downloaded Live wire (XC3),fixed AEM CAI, coil fixed, new tires. I will get the PCM code and summit the forum soon. I cant wait to have a car the behaves while cruising, With a better idle......TOM
zetec#1 is offline
Old 06-27-2013, 06:18 PM   #8
LouBomb
It was all a DREAM!
LouBomb's Avatar
Fan#: 32545
What I Drive: A magical pony by the name of Sally
Points 11,179, Level 69
Points: 11,179, Level: 69 Points: 11,179, Level: 69 Points: 11,179, Level: 69
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
Forum Activity 3%
FF Reputation: 9 LouBomb Good Standing Member
there has to be more done to the car then the listed mods.. the intake should add none in reality given that the svt stock intake has been shown to have the greatest airflow.. throttle body doesnt add hp just response..
do you know who you bought it from? was he a member here? reason i ask is because the mods you may have already installed can have an affect on AFR
2000 Turbo Zx3
2003 Pitch Black SVT
2000 SPI 220k miles all original THE UNICORN
Focus Revolution Club
Formely IMPORTKILLA35
LouBomb is offline
Old 06-27-2013, 08:01 PM   #9
zetec#1
Fan#: 34556
I built the car. The car was dyno tuned by steeda. My steeda xcal two broke. So I got another xcal2 and had the car re-tuned by a local company. They made a dogs of it. They left the in open loop only and the cruising/idle and MPG a horrible. I had 168Whp 158lbs with the steeda tune.
I have
Ford racing head (milled .040)
SVT header
AEM intake Cold air
2.5 inch Exaust and flex
essling Cam gears
Cat stage 2cams
crowler spring/retainers
Under drive pullies
MSD coil/wires
FC 65mm TB
2000 port intake man.
EGR delete
Terry hains tranny (4.08 gears)
zetec#1 is offline
Old 07-03-2013, 08:35 PM   #10
svtgunsmith
Fan#: 115359
returned the car to stock with the sct and behold im in the 12.5 to 13 afr at wot, so the sct program cost me more gas and less power.
Food for thought when choosing who to tune your focus
