Jackson racing SC need help identifying it! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-22-2013, 06:42 PM   #1
Basselisk
Fan#: 102662
What I Drive: 2003 CD Silver SVT
Points 504, Level 10
Points: 504, Level: 10 Points: 504, Level: 10 Points: 504, Level: 10
Level Up 8% Completed
Forum Activity 2%
FF Reputation: 1 Basselisk Good Standing Member
well guys, I was lurking around the performance shops in my town, when I found a supercharger and intake manifold laying in the ground of a shop, the guy told me theyre for an SVT focus and was installed in one 4 months ago, he only has the manifold, sc, 2 camshaft (I didnt know the kit came with those btw...), and a black box apparently some kind of electronic controller not sure...
so the guy is asking 1k for it... the blower looks in good shape, the part Im worried about is the manifold since they can cost quite a bit... and blowers I can find shitloads in yunkyards...
I will get pictures until monday, sadly I forgot to take them when I was there..
meanwhile... what would I need to install it on my svt? and how can I tell its for an svt and not the zx3 pkg?
thanks!
Basselisk is offline
Old 06-22-2013, 11:19 PM   #2
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
you would also need bigger injectors with this and a tune and a wideband
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 06-22-2013, 11:26 PM   #3
jwill2489
jwill2489's Avatar
Fan#: 78236
What I Drive: 2003 SVT JRSC w/BBK
Points 3,468, Level 36
Points: 3,468, Level: 36 Points: 3,468, Level: 36 Points: 3,468, Level: 36
Level Up 79% Completed
FF Reputation: 4 jwill2489 Good Standing Member
You will also need of of the brackets that came with the kit. Relocation and support stuff. I doubt your finding m62 svt Jackson blowers by the dozens either.
jwill2489 is offline
Old 06-23-2013, 06:20 AM   #4
Basselisk
Fan#: 102662
Forum Activity 2%
So you think I should get the blower and the intake manifold and just start collecting or custom making the other parts?
I guess I can get the guy to lower the price of the blower, since theres a lot of parts missing...
Old 06-23-2013, 10:53 AM   #5
jwill2489
jwill2489's Avatar
Fan#: 78236
Have fun making a custom alternator relocation bracket.
There's a tb bracket, a power steering bracket. Lots of stuff
Old 06-23-2013, 12:54 PM   #6
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
for less headaches you could go turbo
FF MODERATOR
RIFF CREW
Old 06-28-2013, 01:34 AM   #7
iceberg65
Fan#: 64382
What I Drive: 00 laser red cougar
FF Reputation: 2 iceberg65 Good Standing Member
The alternator relocation bracket is going to be the tough one to recreate; I really cant see someone making one without considerable skill and tools. The Throttle cable bracket can be built without too terribly much work. The power steering relocation is missing on most used kits anyway and people make do. The lower manifold support bracket seems to be missing on a fair share of used kits as well some people make a twisted steel bracket without experiencing detrimental effects and others just dont use a lower support. This increase the chance of developing a manifold leak.
Gaskets are getting to the point where you cant just order them anymore but would have to make your own. Which really isn't that big of a deal.
$1000 for just the blower and manifold and black box is probably high for a kit with unknown history.
To verify that it is a svt kit look for a EGR port on the manifold (if it has one its for a base zetec)
here are the instructions.
http://web.archive.org/web/200603192...ns/995-100.pdf
and the parts list for the svt kit (with part numbers)
Focus SVT 995-100
988-350 INTAKE & SUPERCHARGER ASSEMBLY 1
051-098 BYPASS VALVE 1
051-121 SCREW, SHCS, M6 X 1.0 X 16 4
051-142 HOSE BARB. 7/32 VACUUM 2 1
051-144 HOSE, SILICONE, 1.5 ID X 1.25 1
051-189 BOLT M8 X 0.75 X 10 WI PLUG 1
051-529 GASKET, JR BYPASS-MANIFOLD 1 1
051-551 HOSE, VACUUM, 7/32, BULK 14
051-553 CLIP RETAINING 7/32 VACUUM 1
052-168 INTAKE MANIFOLD - FOCUS SVT 1
052-171 GASKET, INTAKE MANIFOLD 1
052-284 HOSE BARB,3/8NPT X 1/2 X 90DEG 1
051-122 STUD, M8 X 1.25 X 40 2
051-207 AHCS M8X1.25X25 1
051-528 GASKET,GEN3 S/C-TB ADAPTER 1
051-663 SCREW, SET, M8 X 1.25 X 50 2
051-680 HOSE BARB, 3/8 VACUUM 1
051-783 AHCS, M8 X 1.25 X 55 1
051-938 NUT, HEX FLANGE, M8 X 1.25 2
052-173 SUPERCHARGER INLET - FOCUS SVT 1
052-174 S/C JR M62CW, NO NOSE PULLEY 1
052-179 GASKET, JR62 S/C TO INTAKE 1
052-197 PULLEY-S/C JR 3.6 6-RIB 1
988-625 BRACKET ASSEMBLIES 1
**S/C Support Bracket Kit 3**
051-081 WASHER, FLAT, M10 2
051-084 BOLT, HEX, M10-1.50 X 50 G8.8 2
051-186 NUT,FLANGED,8X1.25,12AF 1
051-505 BOLT FLANGED M8X25X1.25 12 AF 1
051-506 BOLT, HEX FLANGE M8-1.25 X 30 1
051-657 BRACKET, S/C SUPPORT STRAP 1
051-658 BRACKET, S/C SUPPORT LOWER 1
051-081 WASHER, FLAT, M10 1
051-505 BOLT, HEX FLANGE M8-1.25 X 25 2
051-627 PULLEY, 2.0IN IDLER, PLASTIC 1
051-762 BOLT,HEX FLANGE,M10 X1.25 X 30 1
052-170 BRACKET, ALTERNATOR - GEN. 2 1
**P/S Pump Mount Bracket**
051-003 BOLT,HEX FLANGE,M6 X 1.00 X 12 4
051-728 BRACKET, MOUNTING, P/S 1
051-729 BRACKET, ADAPTER, P. STEERING 1
051-787 NUT, FLANGE, M6 X 1.0, 10 AF 4
051-789 SCREW, TAPPING, M6.3-1.81 X 20 1
**Fuel Rail Assembly**
052-185 END CAP, INLET, FUEL RAIL 1
052-186 END CAP, EXIT, FUEL RAIL 1
052-187 END BOLT, FUEL RAIL 2
052-188 PRESSURE DAMPER, FUEL RAIL 1
052-190 O-RING, VITON, NO. 015 5
052-198 ADAPTER, FUEL LINE 1
052-214 FUEL RAIL, MACHINED EXTRUSION 1
052-273 O-RING, VITON, NO. 014 1
052-368 PLUG, PIPE, 1/16-27 NPT 2
988-926 HARDWARE AND HOSE BAG 1
**Hose Bag**
051-134 VACUUM TEE 3/8 1
051-190 CLAMP, HOSE, SAE NO. 6 2
051-235 CLAMP, HOSE, SAE NO. 44 2
051-259 HOSE, VACUUM, 5/32, BULK 56
051-665 HOSE, PCV, 1/2IN BULK 2
051-758 HOSE, SILICONE, 7MM ID, BLACK 36
052-176 HOSE, FLEX LOPRENE 1
052-296 REDUCER, VACUUM, 5/32 X 7/32 1
771-372 HOSE, SILICONE 10MM ID, BLACK 12
**Hardware Bag**
051-004 BOLT,HEX FLANGE,M6 X 1.00 X 16 2
051-016 CABLE TIE, 4IN. 8
051-074 WASHER, FLAT, M8 4
051-075 WASHER, LOCK, M8 4
051-118 BOLT HEX FLANGE M6-1.0 X 30 4
051-119 BOLT, HEX FLANGE M6-1.0 X 10 1
051-122 STUD, M8 X 1.25 X 40 9
051-127 BOLT, HEX FLANGE M8-1.25 X 20 1
051-135 BOLT, HEX FLANGE M8-1.25 X 40 1
051-186 NUT, HEX FLANGE M8-1.25 9
051-187 WASHER, FLAT, M6 2
051-206 BOLT, HEX, M6 X 1.0 X 70 2
051-677 STUD, M10 X 1.5 X 50 1
051-678 NUT, FLANGE, M10 X 1.5, 15 AF 1
051-696 BADGE, JACKSON RACING 2
051-714 BRACKET, SC - ALTERNATOR 1
051-717 SPACER, .33 ID X .63 OD X .33 1
051-718 SPACER, .33 ID X .63 OD X 1.80 1
051-754 ALLEN WRENCH, 4MM 1
051-761 BOLT,HEX, M8 X 1.25 X 90 4
051-788 BOLT, HEX FLANGE M10-1.5 X 40 2
052-180 SPACER, THROTTLE BODY TO INLET 1
052-181 GASKET, THROTTLE BODY SPACER 1
052-182 BELT, 6PK2705 1
052-189 SPACER, STAND OFF, FUEL RAIL 2
052-191 TOOL, FUEL LINE DISCONNECT 1
052-196 BRACKET, THROTTLE CABLE 1
220-136 REMOVABLE THREADLOCKER, BLUE 1
**Documents & Stickers**
051-473 JR WARRANTY CARD 1
052-010 STICKER, PREMIUM FUEL REQUIRED 1
052-282 CARB E.O. STICKER 1
052-071 LICENSE PLATE FRAME, JR 1
052-178 INSTRUCTIONS, S/C SYSTEM, SVT 1
052-183 DFMM - FOCUS SVT 1
iceberg65 is offline
Old 06-28-2013, 01:50 AM   #8
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,625, Level 100
Points: 138,625, Level: 100 Points: 138,625, Level: 100 Points: 138,625, Level: 100
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
For that price I'd pass it up and find a complete kit for a few bucks more or go turbo cause in the end that's probably what it will end up costing with all the missing stuff.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 06-28-2013, 03:06 AM   #9
Basselisk
Fan#: 102662
Forum Activity 2%
Yeh, Ive been thinking about it aswell... I guess Ill go turbo, even thou the idea of having a clean and almost stock install look on the engine bay was tempting, I talked to tom about it and he told me to pass on it, unless the guy wanted less than 200 bucks, which I doubt he will... and even if he does, all the missing parts will be a PITA to get.
I guess is not worth the time and money and I could get the same boost with a small turbo for that grand...
Thanks guys! you saved me from buying a nightmare lol
