trouble removing driver side axle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-22-2013, 03:03 PM   #1
Kyllgore
Fan#: 1506
What I Drive: '03 ZX3 MTX pitch black,
FF Reputation: 1 Kyllgore Good Standing Member
passenger came out just fine but now trying to tap out the driver side when we see this http://t.co/SOG5GZbtXS what is that bar?
the cv side is still in the tranny
kinda an emergency since it is my only car now too.
here's another pic http://t.co/cIhOVRC2ja
if only this modding stuff didn't take so much money
Mac SRI, FC 65mm TB, SVT 5 spokes
SVT brake kit, SS lines up front, SVT suspension
Kyllgore is offline
Old 06-22-2013, 03:30 PM   #2
Kyllgore
Fan#: 1506
bump please any advice from that picture
well we have the axle out but the inner CV part is still in the axle and I can't just stick something in the passengerside and pop it out
Kyllgore is offline
Old 06-22-2013, 11:22 PM   #3
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Take a drift bar or a long punch & put in & tap it out. That pin is the axle for the spider gears in the diff.
felixthecat is offline
Old 06-23-2013, 12:01 AM   #4
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,703, Level 100
Points: 73,703, Level: 100 Points: 73,703, Level: 100 Points: 73,703, Level: 100
Level Up 0% Completed
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
The driver's side axle has a retaining ring on the splines to hold it in place. If you get one of these:
http://www.autozone.com/autozone/acc...mString=search
And a slide hammer, it will pop out pretty easily.
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 06-23-2013, 06:52 AM   #5
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
A thin profile slot screwdriver can pop it out from the passenger side. Or pop it out on driver side using slide hammer. The clip holding driver stub in works quite well, as it should. Pin is indeed the cross shaft that holds two spider gears in place in the differential carrier.
amc49 is offline
Old 06-23-2013, 10:07 AM   #6
Kyllgore
Fan#: 1506
Thanks so much. Yeah figured out it was for the spider gears but for the life of us could not tap it out or any amount of force. Not a single parts store EDIT (they didn't know they carried it) carried that slide hammer accessory! And in trying to get the axle from the driver side knuckle the upper caliper bracket holder snapped right off and the pinch bolt for the strut deformed. Passenger side worked fine. Luckily my original zx3 knuckles, rotors, calipers and stuff were still in the garage. So until I find a drivers side knuckle my front setup is going back to the old stuff. I'm having I towed to a shop Monday have them yank it out and install the seals and axles. And bleed the breaks luckily its a byop shop and cv axle replacement is 99$, I don't have time to order the part for the slide hammer. I wish I did
Kyllgore is offline
Old 06-24-2013, 08:19 PM   #7
Kyllgore
Fan#: 1506
thanks again 3 bumps and it was out, up and on the road but back to zx3 brakes in the front till I find driver side svt knuckle, and buying parts at stores is a pain sometime they try to sell me wrong parts!
since my suspension and brakes are svt but they get me zx3 stuff, oh and this time we used plenty of anti seize
Kyllgore is offline
Old 06-24-2013, 08:21 PM   #8
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
Yeah, I learned that if you have the slide hammer, the "fork" puller and the hub puller attachment, changing the axles are a piece of cake.
-Carl-
FF Moderator
Member Rules
CJohn364 is offline
Old 07-06-2013, 02:32 PM   #9
Kyllgore
Fan#: 1506
ok so an svt knuckle is nearly impossible to come by could i run the svt knuckle on the passenger side and just replace them with driver side knuckle and lower control arm/ball joint of an 05 and be ok or would that be out of whack?
Ok more along the lines of would it be ok to run one side with an 05 control arm/ball joint and spindle with svt rotor and caliper
and the other side stock svt
Kyllgore is offline
Old 07-08-2013, 10:18 PM   #10
DoctorJ
Fan#: 113834
What I Drive: 2001 Twilight Blue sedan
Points 63, Level 1
Points: 63, Level: 1 Points: 63, Level: 1 Points: 63, Level: 1
Level Up 26% Completed
Forum Activity 5%
FF Reputation: 1 DoctorJ Good Standing Member
Honestly, size the rotating mass should be the same, I don't see why it wouldn't work. To my understanding, the '05 ball joint is just a little larger, which wouldn't really affect anything in terms of steering or alignment.
As long as the caliper/pads, and rotors are the same, I think it would work. Worth a try! Report back if it works.
DoctorJ is offline
