Remove rear drums for replacement, and new shoes - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-22-2013, 01:36 PM   #1
berndt
Fan#: 102080
What I Drive: 2002 Ford Focus SE
Points 581, Level 11
Points: 581, Level: 11 Points: 581, Level: 11 Points: 581, Level: 11
Level Up 62% Completed
FF Reputation: 1 berndt Good Standing Member
I'm replacing the front rotors, and brake pads this weekend, and from the shop manual, it looks pretty standard to what IM used to: get the wheel off, get the caliper off, and replace what I need.
The rear look way different, than previous drums I've worked on. The manual says to take the spindle off, and then the drum comes off? What the heck? And drums are sold with bearings?
Can someone explain this to me please?
What I want to do is replace the drums, and shoes.
thanks.
Bryan Berndt
bryanb@bryanb.net
2002 Focus SE, auto, 2.0L SPI
berndt is offline
Old 06-22-2013, 11:38 PM   #2
berndt
Fan#: 102080
http://www.youtube.com/watch?v=D4bchckCwqM
This looks like what I need...
Bryan Berndt
bryanb@bryanb.net
berndt is offline
Old 06-24-2013, 10:59 AM   #3
Bruce Almighty
Fan#: 90526
What I Drive: 2007 charcoal ZXW
Points 47, Level 1
Points: 47, Level: 1 Points: 47, Level: 1 Points: 47, Level: 1
Level Up 94% Completed
FF Reputation: 1 Bruce Almighty Good Standing Member
Just did mine this week-end, there is a post somewhere here (try the HOW-TO section) basically there are 4 bolts in the back of the drum, just remove those and pull out the drum (with the bearing). After replacing the parts just slide it back and tight the bolts.
Bruce Almighty is offline
Old 06-24-2013, 01:24 PM   #4
cpalz
Fan#: 105682
What I Drive: 2002 Zx5 Focus, 2005 Zx4 Focus
FF Reputation: 1 cpalz Good Standing Member
I just removed the center dust cap and the nut underneath it. Pulled drum off. Went to NAPA and bought the drums with the bearings already installed. The drums come with very specific instructions on how to torque center nut to keep from destroying the new bearing. This was on an 2002 zx5. I believe the drums are the same on that year sedan.
cpalz is offline
Old 06-24-2013, 06:50 PM   #5
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
Points 7,929, Level 59
Points: 7,929, Level: 59 Points: 7,929, Level: 59 Points: 7,929, Level: 59
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
I did my drums last year and the damn left/rear has started growling recently... I may have improperly installed the damn things! ABS light is on and everything.
"I'm gonna sing the doom song..."
Mile30 is offline
Old 06-24-2013, 10:53 PM   #6
Saabafoo
Saabafoo's Avatar
Fan#: 74499
What I Drive: 07 Saloon
Points 269, Level 5
Points: 269, Level: 5 Points: 269, Level: 5 Points: 269, Level: 5
Level Up 38% Completed
Forum Activity 2%
FF Reputation: 1 Saabafoo Good Standing Member
When you guys removed your drums, how many miles did they have and how worn were they?
Saabafoo is offline
Old 06-24-2013, 11:28 PM   #7
Mile30
Mile30's Avatar
Fan#: 74686
Forum Activity 4%
8 years/85k miles and I Auto Crossed this thing 8 events for the first 6 years!
1 year/7k miles on the ones I replaced them with... pretty sure they weren't OEM, too.
Mile30 is offline
Old 06-25-2013, 10:10 AM   #8
cpalz
Fan#: 105682
Mine had 136,000 on them. The only reason i replaced them is because my wheel bearings were out, and napa did not have the bearings. But they did have the drums with the bearings already in them. It was not that much more money if I remember right.
cpalz is offline
Old 06-27-2013, 04:12 PM   #9
berndt
Fan#: 102080
I'm still a little confused. If I take out the 4 bolts on the back of the flange, the whole spindle, drum bearing everything comes off?
How does one get to the shoes, and replace the drum in that case? And what about the brake lines, where do they go?
If I come from the outside of the whole thing, like the video does, I take the dust cap off, take the big nut off, which takes the bearing and drum off. Then replace with drum/ bearing assembly?
Bryan Berndt
bryanb@bryanb.net
berndt is offline
Old 06-27-2013, 05:48 PM   #10
cpalz
Fan#: 105682
You do not have to take the four bolts and spindle off. Just remove dust cap, then nut. Then pull drum off. You will see the shoes underneath, and the bearing will be in the drum. Drum may be stubborn, but it will come off as long as you remove the single nut under the dust cap.
cpalz is offline
