No start, clutch switch? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-22-2013, 05:57 AM   #1
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,266, Level 19
Points: 1,266, Level: 19 Points: 1,266, Level: 19 Points: 1,266, Level: 19
Level Up 66% Completed
Forum Activity 4%
FF Reputation: 1 popwarhomie Good Standing Member
Lately when turning key to crank I get nothing.. Try 5 times and still nothing.. Then it will start just fine. Starting to get annoying.
Push the clutch in a new times and sometimes it will work.
Im guessing the clutch switch is going bad and not knowing the clutch is pushed in when trying to start?
Or ignition related?
2010 Focus SE coupe 5 speed
Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/Projector retrofit/LED tails/ Walled with 2 SQ HDC3 18s.
94 Lightning
A lot of mods.
popwarhomie is offline
Old 06-22-2013, 06:57 AM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,376, Level 77
Points: 14,376, Level: 77 Points: 14,376, Level: 77 Points: 14,376, Level: 77
Level Up 82% Completed
Forum Activity 19%
FF Reputation: 15 Elizabeth Great Standing Member
Well the clutch switch is the cheapest place to start!!
And most likely the problem.
Elizabeth is offline
Old 06-22-2013, 09:18 AM   #3
popwarhomie
Fan#: 94974
Forum Activity 4%
Can I unplug it?
94 Lightning
A lot of mods.
Old 06-22-2013, 09:45 AM   #4
rsnow
Fan#: 105358
What I Drive: 2002 pitch black svt
FF Reputation: 1 rsnow Good Standing Member
no, you cant unplug it... jumping would work but then cruise wont work if you do that. These have a self adjusting switch, you can remove the switch and reset it, but it is most likely worn out and wont help long. So just replace it. make sure no brackets are bent
rsnow is offline
Old 06-22-2013, 03:55 PM   #5
popwarhomie
Fan#: 94974
Forum Activity 4%
Okay thank you.
94 Lightning
A lot of mods.
Old 06-24-2013, 11:43 AM   #6
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 06-25-2013, 04:52 PM   #7
gun_runner
gun_runner's Avatar
Fan#: 91693
What I Drive: 2000, Dirt Metallic, Kona ZX3
Points 1,959, Level 26
Points: 1,959, Level: 26 Points: 1,959, Level: 26 Points: 1,959, Level: 26
Level Up 59% Completed
Forum Activity 3%
FF Reputation: 1 gun_runner Good Standing Member
What year? Had this problem with my 2000 zx3.
The car wasn't detecting my key. The little light on the dash next to the hazard switch would blink rapidly indicating that it couldn't find the transponder in the key. Most of the time if i just waited 20 seconds it would find the key, and start right up. It became longer and longer, and finally it stranded me at a restaurant on my lunch break from work. Missed half a day and had to replace the keys, PATS reciever in the steering column, and they had to program a new PATS code in. $420 at the dealer.... Hope you don't have this problem.
I can re-drill the hubs and rotors/drums on your mk1 or mk2 focus to accept 5x108 or 4x100 wheels for only $120!!! http://www.focusfanatics.com/forum/showthread.php?t=323550
gun_runner is offline
Old 06-26-2013, 06:01 AM   #8
popwarhomie
Fan#: 94974
Forum Activity 4%
2010...
94 Lightning
A lot of mods.
Old 06-27-2013, 10:27 AM   #9
TiIngot
Fan#: 110130
What I Drive: 1996 Corvette LT4 Convertible
Points 181, Level 3
Points: 181, Level: 3 Points: 181, Level: 3 Points: 181, Level: 3
Level Up 62% Completed
FF Reputation: 3 TiIngot Good Standing Member
Take a look at the following link.
http://www.focusfanatics.com/forum/showthread.php?t=309714
My daughters '08 with auto trans had the same problem that got worse over time until you had to play with the key for 5 minutes to get the starter to engage. It took three days of trial and error troubleshooting to find out the problem was in the linkage of the steering column between the key cylinder on the right and the starter switch on the left.
Good luck.
TiIngot is offline
