2002 svt - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > SVT Performance (2002-2004)
Old 06-21-2013, 11:02 PM   #1
Ford SVT
Fan#: 116000
What I Drive: 2002
FF Reputation: 1 Ford SVT Good Standing Member
2002 svt
I had the timing belt sheer some teeth. I replaced the belt and used the cam bar, the crank pin and put it back toghter. Wont start? Timing checks out with #1 piston and there is fuel and spark. But she just wont run.. Any thoughts. Before I pull the head what should the compression be for this motor. Also wouldnt it at least pop or something even if the valves are bent?
Ford SVT is offline
Old 06-22-2013, 07:37 AM   #2
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 mazdaspeed3
FF Reputation: 21 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (14)
does it turn over at all?
I now drive a Japanese Ford.
macdiesel is offline
Old 06-22-2013, 08:58 AM   #3
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2008 Edge SEL
FF Reputation: 34 tukaniSVT Great Standing Member
The popping ... not necessarily. But it would crank.
The compression varies between 110-145 that I have seen from many different members on the site.
When the TBelt went out, did your car die? Did it make a big pop? Did it puff out a big amount of black smoke?
Or did you just notice the sheered teeth and decided to replace it?
Ray
Hatch Nation Member: #147
TeamFocalize Head Honcho
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
OFFICIAL FOCUSFEST PHOTOS POSTED:CLICKY HERE TO SEE THE AREA OF PHOTOS
tukaniSVT is offline
Old 06-22-2013, 11:09 AM   #4
Ford SVT
Fan#: 116000
What I Drive: 2002
Just going 70 mph down the freeway and it lost all power. The intake manifold came off is what we found first. Then after replacing the boots, it just turned over. No popping no backfire no crunching nada. So I took off the timing cover and cranked the motor and thats when we discovered that the cams were not turning. So we replaced the belt. Using the crank pin and the cam bar. The cam belt sheared teeth at the crank so it may ? OR may not have bent the valves. Compression check later today. Will post the outcome.
Ford SVT is offline
Old 06-22-2013, 11:12 AM   #5
Ford SVT
Fan#: 116000
What I Drive: 2002
Forgot to add this..So while I was checking everything I found that . Yes it fires one #1 when it should the injector fires right before that and I am not out of fuel. I also have fuel pressure at the rail.
Ford SVT is offline
Old 06-22-2013, 12:38 PM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
FF Reputation: 153 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
I would do a compression test , this will tell you if you bent valves
Compression could be 90 - 120 +/-
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 06-22-2013, 03:55 PM   #7
Ford SVT
Fan#: 116000
What I Drive: 2002
Well about two hours ago I discovered that all the exhaust valves are bent open. After a comp. test of 0 across the board, I pulled the head. At least the pistons aren't damaged.
Ford SVT is offline
Old 06-23-2013, 07:54 PM   #8
Ford SVT
Fan#: 116000
What I Drive: 2002
So can I put a stock head on the svt and just swap the cams?? Or what is the way to delegate the intake variable.??? I have a ported and polished head with the larger valves and another set of cams here...
Ford SVT is offline
Old 06-26-2013, 08:57 PM   #9
Ford SVT
Fan#: 116000
What I Drive: 2002
Delete not delegate, the svt cam sensor. Do I need a complete tune or can I tune it out with my prp3??
Ford SVT is offline
Old 06-27-2013, 02:15 AM   #10
macdiesel
macdiesel's Avatar
Fan#: 31579
Don't think you can swap svt cams to a zetec head. As for the vct, can't tune it out with a scan tool, you will need to by a vct delete kit. Massive speed system sells a kit. The car will need to be tuned after.
