Want better cargo lighting? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 06-21-2013, 09:20 PM   #1
gatmog
gatmog's Avatar
Fan#: 15492
What I Drive: 2013 Silver SE Hatch
Points 746, Level 14
Points: 746, Level: 14 Points: 746, Level: 14 Points: 746, Level: 14
Level Up 46% Completed
FF Reputation: 4 gatmog Good Standing Member
I purchased:
2x T10 led bulbs
2x 12v sticky back LED strips
and ended up with this:
Total cost: >5$
How to:
Pull the stock cargo light housings and discard the bulbs.
Take the postive and negative wires of your strip lights and insert one wire each under the folded wire terminal of your T10 bulbs (the part that forms a metal V on the bulb). This may take some trial and error because LEDs are single polarity, meaning you would reverse one or the other until both the bulb and strips are working.
Oh, and make sure the wire cannot come across both terminals! That would make a short and you don't want that.
Press the bulbs with the wires attached back into the harness and check to see if they are both working.
Once they are both working, you can tuck the strip though the open space where the light goes and hide the wire behind the trim.
Stick the strips where you want them, tuck the housings back, and enjoy.
TIP: The adhesive on the strips are usually crap and you'll likely come back to your car on a warm day to see the lights dangling from the wires. I used high temp heat glue (280*) to readhere the strips and even the hottest day won't re-melt the glue. Heat glue also falls off on command if it so much as gets a whiff of rubbing alcohol.
Happy modding!
13 Ingot SE Hatch with 201a
gatmog is offline
Old 06-21-2013, 10:19 PM   #2
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
Points 9,389, Level 65
Points: 9,389, Level: 65 Points: 9,389, Level: 65 Points: 9,389, Level: 65
Level Up 13% Completed
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
Pretty ingenious. Good work!
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is offline
Old 06-22-2013, 11:55 AM   #3
JonnyPaste
Fan#: 115169
What I Drive: 2012 Black Titanium HB
FF Reputation: 1 JonnyPaste Good Standing Member
Looks really good! I'll be adding this to the mod list. Also, Very nice mat, I have the same one ;)
JonnyPaste is offline
Old 06-22-2013, 02:17 PM   #4
gatmog
gatmog's Avatar
Fan#: 15492
Yeah I am in love with this mat! Between this and the weatherbeaters I have up front, there is no exposed carpet to get dirty anywhere in the car
Just don't armorall it. All of my stuff goes sliding everywhere at every turn..
gatmog is offline
Old 06-24-2013, 10:29 PM   #5
jcw122
jcw122's Avatar
Fan#: 111081
What I Drive: 2014 Race Red SE 201A Hatch - MTX
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 2 jcw122 Good Standing Member
Great mod! I wonder if they come in warmer white temperatures.
2014 SE in Race Red, 201A, Winter Package, Moonroof. Manual Transmission. e-Focus RMM. Snorkel Delete Mod. Love it!
jcw122 is offline
Old 06-29-2013, 11:29 PM   #6
gatmog
gatmog's Avatar
Fan#: 15492
I'm sure they do--the ones I used are just $1.50 strips from hong kong and they are bluer than I'd like..
http://www.amazon.com/Amico-Waterpro...I1SUNWW13UFT37
I have these--avoid these if you mind the blue tint!
BTW: You can cut most of these to size--I cut 5 LEDs off of mine to fit. The ideal length for mounting where I did is about 8" IIRC
gatmog is offline
Old 07-01-2013, 09:52 PM   #7
Michaelc1220
Michaelc1220's Avatar
Fan#: 93834
What I Drive: 2012 Grey Focus SE hatchback Sport
FF Reputation: 2 Michaelc1220 Good Standing Member
Great write up man! I actually have that same mat as well, along with the weatherbeaters. I changed all of my interior lights to blue LEDs so I might use some blue LED strips and wire them to under the rear footwells.
Michaelc1220 is offline
Old 07-02-2013, 10:35 AM   #8
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
You can order LED strips by the reel in various color temperatures that you cut to length and solder leads to. They would work the same way as in the OP's writeup, but give you more options.
Here is one example. My experience has been very positive with these and the adhesive on the back is strong.:
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Hatch Nation #90
TboneZX3 is offline
Old 07-08-2013, 07:09 PM   #9
RonMaiden
RonMaiden's Avatar
Fan#: 99230
What I Drive: 2012 Red Candy Metallic Hatch SE
Points 4,216, Level 41
Points: 4,216, Level: 41 Points: 4,216, Level: 41 Points: 4,216, Level: 41
Level Up 33% Completed
Forum Activity 11%
FF Reputation: 6 RonMaiden Good Standing Member
How do you pull the hatch bulb cover off without breaking them;I was using a flathead but it felt like I was ready to snap something,is there a trick?
'12 Focus Red Candy SE Sport 5 spd
'99 Toyota 4Runner Sport
'11 Subaru WRX STI Hatch
RonMaiden is offline
Old 07-08-2013, 07:59 PM   #10
Marine
Marine's Avatar
Fan#: 105885
What I Drive: 2012 Ford Focus SEL Hatchback
Points 1,662, Level 23
Points: 1,662, Level: 23 Points: 1,662, Level: 23 Points: 1,662, Level: 23
Level Up 62% Completed
Forum Activity 14%
FF Reputation: 2 Marine Good Standing Member
Here you go
I am doing mine weds. Small flathead towards the rear seat NOT towards the hatch. Look at the tube vid.
http://m.youtube.com/watch?v=zAn8bNn...ature=g-high-u
Marine is offline
