00-05 side markers fit a 07??????? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-19-2013, 10:47 PM   #1
2007 fordfocus
2007 fordfocus's Avatar
Fan#: 106051
What I Drive: 2007 Toreador red ZX3
FF Reputation: 1 2007 fordfocus Good Standing Member
Hi guys I am looking to buy some blacked out side marker lens for my 07 focus... I found a set on ebay and the say they fit a 00-05 will they fit my 07 and also what type of bulb should i use they say they are smoked lens so can i just re-use my stock bulbs????? Are the stock bulbs orange or are the clear ?????? also how hard is it to get to them it looks like i might have to take out the wheel well to get to them????
Thanks any help apprecitated....
2007 fordfocus is offline
Old 06-19-2013, 11:27 PM   #2
_fifth_
_fifth_'s Avatar
Fan#: 72683
What I Drive: oh-sicks Silver ZX4
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 5 _fifth_ Good Standing Member
If I'm not mistaken, they should be the same from 05-07. I'm not all that sure about if the older model will fit our years. Someone else on here can help you out with that bit of knowledge.
The stock bulb is clear so you can totally just keep it in there. If you do replace them you'll either have to pull out your headlights and go at them from the top or take your wheels off, remove the liner and get at them that way. Regardless of how you do it, be patient. There is not a lot of room back there to work with. I had to take both my headlights and my wheels off because I'm clumsy as hell and get frustrated super easy.
That all being said, why don't you just get a rattle can of VHT Nightshade and smoke them yourself? You can control how dark they get and if you don't like it, wait a bit and it'll fade away. The downside is since it does tend to fade given enough time, you'll probably have to redo them eventually.
My name is Karyn! What's yours?
FocusXtreme - 502
Originally Posted by miragesmack View Post
Yeah, too many hatches. When the sedans take over, all will be good!
_fifth_ is offline
Old 06-19-2013, 11:43 PM   #3
mix1983
Life Is Good
mix1983's Avatar
Fan#: 61101
What I Drive: 2000 Honda Civic EX 5spd
Points 9,093, Level 64
Points: 9,093, Level: 64 Points: 9,093, Level: 64 Points: 9,093, Level: 64
Level Up 15% Completed
FF Reputation: 5 mix1983 Good Standing Member
2000 through 2007 are the same. Use the stock bulbs, they're white (which is why the side marker is amber). If I remember correctly the driver's side is a bit tough to get to but very possible. I seem to remember there being a tank on the driver's side that made it a tight fit.
They're just held on by a hollow nut type fastener that screws onto the plastic of the side marker.
By the time you buy VHT Nite Shades, a set of side markers will be the same price, maybe a couple dollars more. So either way you go you won't be gaining or losing any money. VHT is probably easiest, but I'm not sure how hard it is to get back off if you ever want to go back to stock.
I'm all about sharing the road with other drivers - as long as they use the part that's behind me.
mix1983 is offline
Old 06-20-2013, 12:04 AM   #4
2007 fordfocus
Fan#: 106051
Sweet I thought they looked the same ill be sure to order them everything else is blacked out on my car and the bright orange was kinda ruining the look.....lol
Old 06-20-2013, 12:53 AM   #5
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,030, Level 74
Points: 13,030, Level: 74 Points: 13,030, Level: 74 Points: 13,030, Level: 74
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "MK1 Focus".
zetecDon is offline
Old 06-20-2013, 01:54 PM   #6
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,752, Level 59
Points: 7,752, Level: 59 Points: 7,752, Level: 59 Points: 7,752, Level: 59
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 19%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
also, not all of the ones that appear to be blacked out on ebay are actually black. the ones i got have a clear lens but the back/bucket is black. so they look blacked out but are clear, i run an amber light in them.
also, go ahead and run a bead of something along the seal on them before you install. i had an annoying fogging that happened on my; had to take them off, dry them out and then seal them up better
rambleon84 is offline
Old 06-20-2013, 09:07 PM   #7
distroy3d
distroy3d's Avatar
Fan#: 85129
What I Drive: 2001 Silver ZTS
Points 70, Level 1
Points: 70, Level: 1 Points: 70, Level: 1 Points: 70, Level: 1
Level Up 40% Completed
FF Reputation: 1 distroy3d Good Standing Member
Sucks to have an 05-07. Seems like a PITA to change the markers. In my 01 there was nothing in the way. I just climbed under and changed it without removing anything. No headlights removed, no wheels or liners removed lol.
2001 Ford Focus SE, Black - R.I.P.
2001 Ford Focus ZTS, Silver - Hella Dual-Projector Headlamps Painted, Morimoto 5000k 35w H9 kit, eBay CAI
distroy3d is offline
Old 06-20-2013, 10:25 PM   #8
2007 fordfocus
Fan#: 106051
Yeah I was looking at it today and it did seem like a pain....
