Fuel injector cleaner recommendations - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-19-2013, 10:42 AM   #1
nowhere67
Fan#: 92834
What I Drive: 2010 Sterling Grey Automatic SE
Points 255, Level 5
Points: 255, Level: 5 Points: 255, Level: 5 Points: 255, Level: 5
Level Up 10% Completed
FF Reputation: 1 nowhere67 Good Standing Member
Does anyone have a good fuel injector cleaner recommendation? While using the crappy fuel over here in Italy, my car has developed to notorious injector ticking.
CFM CAI w/ bypass valve
FSWERKS Stealth Exhaust
A103 Spark Plugs .055 Gap
nowhere67 is offline
Old 06-19-2013, 01:48 PM   #2
CriticalMass
Fan#: 63989
What I Drive: 2014 Ford Mustang GT Premium Brembo
Points 386, Level 7
Points: 386, Level: 7 Points: 386, Level: 7 Points: 386, Level: 7
Level Up 72% Completed
FF Reputation: 2 CriticalMass Good Standing Member
I believe Techron is the only one Consumer reports found that actually works worth a damn.
2014 Ford Mustang GT Premium + Brembo Package, SGM.
CriticalMass is offline
Old 06-19-2013, 06:03 PM   #3
Gadabout
Gadabout's Avatar
Fan#: 114774
What I Drive: 2006 Vermillion Red ZX4 SE
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 4 Gadabout Good Standing Member
I been wondering this lately as well. I'm nowhere near Italy, however.
I've read/found that Seafoam and Techron are probably our best options. For the longest (though I've never tried it) I thought it was ok to take out the injectors and clean em out with carburetor-like cleaners. But IDK . Ima leave this paragraph right here, so i can follow some professional answers =P
Things work out best for those who make the best of the way things work out. - J Wooden
Team Duratec #42
Gadabout is offline
Old 06-20-2013, 08:00 AM   #4
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,802, Level 76
Points: 13,802, Level: 76 Points: 13,802, Level: 76 Points: 13,802, Level: 76
Level Up 38% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
I use Techron myself. You can find that at Costco.
felixthecat is online now
Old 06-20-2013, 08:16 AM   #5
CriticalMass
Fan#: 63989
Points 386, Level 7
I don't know if they still do but Honda used to recommend this as a "Maintenance" item on their cars. It was a nice little $600.00 maintenance fee once the car started getting up there in miles.
I prefer the Techron route. hehe
Old 06-20-2013, 10:50 AM   #6
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Basicley a fuel injector flush that shops use= disconnect the fuel line & hook the line up & then connect the leads up to the battery & start the car & let idle till the fuel runs out, about 20 minutes or so. It shouldn't cost no $600. for sure. Its a injector flush service.
Old 06-20-2013, 07:35 PM   #7
lowzts
lowzts's Avatar
Fan#: 115627
What I Drive: 02 liquid grey zts mach audio
FF Reputation: 1 lowzts Good Standing Member
Hell no not $600!!!! I work at a shop that does injector flushes... its like $170 ish and the shit works pretty good
Sent from my ZTE N9120 using FF Mobile
lowzts is offline
Old 06-20-2013, 08:00 PM   #8
Custodian
Custodian's Avatar
Fan#: 79355
What I Drive: 2011 SGM Focus Sedan SE
FF Reputation: 1 Custodian Good Standing Member
I have had good luck with Lucas UCL...
Patrick
2011 Focus SE, 2010 Honda SH150i
5w-20 Motorcraft semi-syn until warranty has expired
Hankook Optimo H725 on Drag DR-33
General Altimax Arctic on OEM alloys
Custodian is offline
Old 06-20-2013, 11:49 PM   #9
Trapper L
Fan#: 54336
What I Drive: 2006 Focus ZX4
FF Reputation: 3 Trapper L Good Standing Member
Nowhere67, there are only two chemicals that do any real cleaning- Stoddard Solvent that you might know by the name Dry Cleaning fluid, or a PEA polyetheramine. Techron, BG44 both, use both of these chemicals to the tune of about 30% concentrate. If you can find Gumout WITH Regane, it also is about 30% PEA and does a great job at cleaning at a fraction of the cost of the others. Note, there is a Gumout that does NOT have REGANE. The REGANE is the cleaning agent so make sure it has it on the label. If you have access to dry cleaning fluid, use it at a rate of 1 ounce per 8 gallons. If you read the label on most supposed fuel system cleaners, you'll see the words petroleum distillate. That means it's kerosene in the bottle and hardly worth the cost of the plastic bottle. If you see the letters IPA, that means it has rubbing alcohol in the bottle(IsoPropylAlcohol)
FWIW, Seafoam is a pale oil (read light 20 viscosity oil) naphtha, and isopropyl alcohol (read rubbing alcohol). If you think that's going to make a good cleaner, use a lot of it as the folks at the snake oil farm are in need of money.
http://www.mta.ca/administration/fac...Co.%202010.pdf
Trapper L is offline
Old 06-21-2013, 02:10 PM   #10
CriticalMass
Fan#: 63989
Points 386, Level 7
Yeah Seafoam is meh. The white smoke you see is just the Seafoam burning off. Carbon Deposits being burned off usually produce black smoke.
