Tire Rack Recommended size...? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-17-2013, 08:25 AM   #1
Borski
Borski's Avatar
Fan#: 100013
What I Drive: 2012 Focus - Black - SE
Points 1,383, Level 20
Points: 1,383, Level: 20 Points: 1,383, Level: 20 Points: 1,383, Level: 20
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 1 Borski Good Standing Member
I'm in the market for new wheels and tires for my MK3. Looking at doing 17" with some weight savings. Hopefully a 17x7.5" wheel.
The Tire Rack recommended size for this wheel is a 215/50-17. I am wondering how hard and fast that recommendation is for tire size.
I am looking to put 225/45-17 on the wheel because that's the widest wheel that the STF class allows in SCCA. (STF allows a 17x7.5" maximum with a 225 width max).
Thanks for your help in advance!
| 2012 BLACK SE | DD & AutoX |
| 5 SPEED | SPORT PACKAGE |
| EIBACH SPORTLINE SPRINGS | SUMMER RUBBER: BF GOODRICH SPORT-COMP 2. ALL SEASON RUBBER: KUMHO ECSTA 4X |
Borski is offline
Old 06-17-2013, 08:39 AM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,906, Level 59
Points: 7,906, Level: 59 Points: 7,906, Level: 59 Points: 7,906, Level: 59
Level Up 78% Completed
Forum Activity 38%
Activity: 38% Activity: 38% Activity: 38%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
its less than a 2% difference in size so there shouldnt be any real issues
rambleon84 is offline
Old 06-18-2013, 05:06 PM   #3
Julian@TireRack.com
Fan#: 102247
What I Drive: N/A
FF Reputation: 2 Julian@TireRack.com Good Standing Member
I would be good with the 225/45R17 on the 7.5" wheel. We recommend the 215/50R17 because it's closer to the OE height on the 16's and a bit taller (smoother ride) The rim width range on the 225/45 would be anything from 7" to 8.5" so you are more than fine running that size.
888-428-8355 ext. 4798
Julian@TireRack.com
Remember to reference Julian/Focus Fanatics in the "previous contacts" field to make sure the forum get's credit!
Julian@TireRack.com is offline
Old 06-18-2013, 06:38 PM   #4
Borski
Borski's Avatar
Fan#: 100013
Sounds good! Thanks for the input guys!
Sent from my HTC One X using FF Mobile
Borski is offline
Old 06-20-2013, 12:17 PM   #5
FocusZTSRS
Rally Rev #00
FocusZTSRS's Avatar
Fan#: 99835
What I Drive: 2012 SE Hatch (RALLY00)
Points 24,400, Level 95
Points: 24,400, Level: 95 Points: 24,400, Level: 95 Points: 24,400, Level: 95
Level Up 5% Completed
FF Reputation: 3 FocusZTSRS Good Standing Member
I have a MK3 hatch. I want 18x8s with 215/40/18s think it will rub?
Rally Revolution #00 (Leader)
2012 Blue Candy Metallic SE Hatch
2001 ZTS Rally Car
[HOONIGAN]
Riley
FocusZTSRS is offline
Old 06-20-2013, 03:59 PM   #6
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,188, Level 96
Points: 26,188, Level: 96 Points: 26,188, Level: 96 Points: 26,188, Level: 96
Level Up 84% Completed
Forum Activity 55%
Not unless you are below ET30 or so. I'm running that size of SS-595's, which are notoriously wide, on ET33.
Better have lots of lowz though. This is with Pro-Kit springs though I should be lower soon-
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 06-20-2013, 06:30 PM   #7
Julian@TireRack.com
Fan#: 102247
What I Drive: N/A
I would almost rather see you with a 225/40R18 and keep you closer to the stock 16" OE height.
Julian@TireRack.com
Old 06-20-2013, 06:35 PM   #8
FocusZTSRS
Rally Rev #00
FocusZTSRS's Avatar
Fan#: 99835
The DMACK Tarmac tires only come in 215/40/18
But there should not be any rub? The sparco Asseto Gara wheels are et45 I believe.
2001 ZTS Rally Car
[HOONIGAN]
Riley
Old 06-20-2013, 07:13 PM   #9
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 55%
Nowhere remotely near rub. If anything it will be near the OEM tire placement on the standard 18" wheels with 235/40's width-wise and somewhere around 8mm shorter from tire to fender.
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 06-20-2013, 07:28 PM   #10
Julian@TireRack.com
Fan#: 102247
What I Drive: N/A
Correct, the 225 would be wider and taller so you are good. And with the Sparco ET45 18X8" wheels, you are just fine.
Julian@TireRack.com
