Exhaust T55 cam gear bolt stripped - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-17-2013, 01:52 AM   #1
Lurker27
Fan#: 61137
What I Drive: 2002 Silver ZX3
FF Reputation: 1 Lurker27 Good Standing Member
So, my brother and i were doing my SVT's timing belt, and we got the belt on and went to loosen the gears to adjust the timing. The E18 on the intake side loosened with some presuation, but the damn shallow T55 torx on the exhaust side stripped.
I guess I'm panicking and I have 2 questions:
1. Can the timing be set well this way? It seems like with the VCT at full positive I could still get the crank pin + timing bar in the cams and be OK?
2. What would the best way to remove the bolt, if we HAVE TO remove it. I as thinking either weld a Hex 15mm on, or a screw extractor?
Sorry, we're just at a loss!
Lurker27 is offline
Old 06-17-2013, 07:39 AM   #2
jasonbi
jasonbi's Avatar
Fan#: 13305
What I Drive: 2002 SVT
Points 4,592, Level 43
Points: 4,592, Level: 43 Points: 4,592, Level: 43 Points: 4,592, Level: 43
Level Up 21% Completed
FF Reputation: 3 jasonbi Good Standing Member
if the bolts still tight leave it alone and set the timing using the bar/pin...once timing is set using the tools slip the belt on and you're good to go. no need to loosen the gears..
#3286 OF 4788
jasonbi is offline
Old 06-17-2013, 08:32 AM   #3
Lurker27
Fan#: 61137
Can I just wiggle the intake cam like in the focal jet post (advance with VCR housing, retard at cam) when I set it to make sure the VCR is at positive dead stop?)
Lurker27 is offline
Old 06-17-2013, 10:54 PM   #4
FordManSVT
FordManSVT's Avatar
Fan#: 44253
What I Drive: 2003 ZX3 SVT Euro in Comp Orange
FF Reputation: 1 FordManSVT Good Standing Member
I second the leave the bolt alone. I almost never loosen either cam when doing zetec timing. Just make sure that when you slip the belt on that all the slack is in the tensioner side. I'm pretty sure the vct should be where it needs to be without oil pressure applied to it. If you must take the bolt out try a extractor or weld a bolt onto it that has a regular 6 point head.
FordManSVT is offline
