car is running on 3 cylinders - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-16-2013, 11:16 PM   #1
Vohaul
Fan#: 114465
What I Drive: 2001 dark blue wagon
FF Reputation: 1 Vohaul Good Standing Member
so the other day on my way to work, it started missing out of the blue..(ie drive up to stop light..fine...leave light, missing) (car is a 2001 focus wagon...ztec dohc)
but after gaining speed, it smoothed out....
managed to get it home at the end of the day, slowly started missing at highway speeds, causing the cel to flash at me..then stop and smooth out, then rough..etc..
went camping for the weekend ...came back today..fired it up...now is definetly missing at all speeds....including idle
so after a quick check..seems number 2 cylinder is not firing...pulled the plug...no spark....tried a different plug...still no spark....
pulled the plug wire off the pack on the right (distributor?)(DOHC ztec 2001 wagon)..
used my multimeter...now im not sure its on the right voltage...but when cranking it over...on the number 2 spot on the dist. i get maybe..1 to .2 of a volt....try it on like the number one spot...instantly goes to over 1.0..so im assuming a bad dist (whatever it's called on this)..is bad?...am i going the right way...is this common?....hard to change?..or am i completely missing something?
Thanks
Paul
Vohaul is offline
Old 06-17-2013, 01:14 AM   #2
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
Coil, not distributor.............
amc49 is offline
Old 06-17-2013, 01:32 AM   #3
Vohaul
Fan#: 114465
Ya, that would be it... Lol..... Are these a common problem
Easy to change out?
Vohaul is offline
Old 06-17-2013, 07:09 AM   #4
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Yep, fairly common. It's pretty easy to remove too, there might even be a how-to around here.
When you take it off and look at the bottom, usually you can see that the insulation is cracked. Then moisture gets in there and you know the rest. I had this happen and bought just the cheap brand from O'Reilly and never had a problem. I usually tend to stick to OEM, Motorcraft or name brand, but perhaps I got lucky.
EDIT: I couldn't find a how-to on here, but here's a Youtube link: http://www.youtube.com/watch?v=BxvcAwNzanc
Take note of the little clip he refers to when unplugging the wiring harness, those are known to break.
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 06-17-2013, 09:52 AM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,746, Level 73
Points: 12,746, Level: 73 Points: 12,746, Level: 73 Points: 12,746, Level: 73
Level Up 74% Completed
Forum Activity 99%
Try to avoid testing that high voltage coil output with a meter. If you'd happened to get a spark it would have "zapped" the meter - fuse can't blow quick enough to protect it from that large an input. Might give you a zap as well...
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-17-2013, 11:44 AM   #6
Covmister
Covmister's Avatar
Fan#: 89659
What I Drive: 2001 white zx3
FF Reputation: 3 Covmister Good Standing Member
test your ohms across the coils! this is only true way to test a coil pack on a waste spark system like the focus. set meter to ohms/resistance. place red terminal in one post and black in another. (coil1 to coil3 and coil2 to coil 4) your looking for a reading of 80 to 100 kiliohms. if you get anything lower your going to burn the wires and plugs, any higher and the the spark wont ignite the fuel. if any OL readings then that pack is ead and you need a new one
In all reality it isnt fast at all, it didnt ever cost 250k, and it wont blow your girls panties off. that being said i drive a ford focus
Covmister is offline
Old 06-17-2013, 03:42 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Right idea - test unhooked & off.
1&4, 2&3 should work - those are the pairs that fire together on a 4 cyl..
Cheers!
"Rubber Side Down"
Old 06-18-2013, 12:31 AM   #8
Vohaul
Fan#: 114465
Yaay..after a bit of fighting....stupid stubborn torx screws...i got the coil replaced....only to find one of the wires broken right at the plug....i ended up crimping the wire to a spade terminal which i ground down a bit and stuck it where the broken wire used to come out of the connector....i then covered the whole thing in silcone.....i will stress this is not a permanent fix....nor do i recommend it...lol..but the car runs and drives and will get me to work....
but, can i get the plug seperately anywhere (other than a wrecker)
thanks
Paul
Vohaul is offline
Old 06-18-2013, 12:49 AM   #9
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,634, Level 94
Points: 23,634, Level: 94 Points: 23,634, Level: 94 Points: 23,634, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
not sure how common they are in wrecker yards there, but there's a ton here. ford should also have them (likely will need to be ordered) .
as mentioned, don't test coil output with the meter... unless it can handle it, but I still wouldn't as it's really not that useful. 60k volts or so.
mikebontoft is offline
Old 06-18-2013, 11:38 AM   #10
Vohaul
Fan#: 114465
thanks
Paul
Maybe i spoke to soo, the car is a bit smoother now, but it still jerks....i wonder it my ghetto coil plug is causing the issue?
Vohaul is offline
