TORQUE app- post me some logs :) - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-19-2013, 02:26 PM   #51
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,343, Level 41
Points: 4,343, Level: 41 Points: 4,343, Level: 41 Points: 4,343, Level: 41
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 5%
FF Reputation: 9 darkangelism Good Standing Member
The first second the AFR is high, then settles down
darkangelism is online now
Old 06-19-2013, 02:26 PM   #52
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Originally Posted by dyn085 View Post
Have no fear, I will debate the same regardless
If your ambient isn't changing, maybe it's programmed to just be 72 degrees? I'm sure the engine could care less what ambient temps are, so maybe engineers didn't create the link? All the ECU should really care about is IAT.
I think you might be on to something here... I won't know until true ambient temps change a bit. True ambient was virtually identical to my log from yesterday.
Hatch Nation #90
TboneZX3 is offline
Old 06-19-2013, 02:28 PM   #53
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Yes. But, commanded and measured AFR are so close that I wouldn't lay too much blame on the aftermarket intake. Actually, measured was better than commanded for those first couple of records.
Hatch Nation #90
TboneZX3 is offline
Old 06-19-2013, 02:31 PM   #54
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Originally Posted by Deesiel678 View Post
If (when) you log again, add fuel rail pressure and commanded AFR to your log.
Sorry, didn't see your request for fuel pressure until after the log. I'll go ahead and add that to the PID list so it's there for the next one.
Hatch Nation #90
TboneZX3 is offline
Old 06-19-2013, 02:39 PM   #55
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,240, Level 95
Points: 25,240, Level: 95 Points: 25,240, Level: 95 Points: 25,240, Level: 95
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 3%
That definitely looks a lot better. You could be right about the octane change and the ECU re-learning. Pretty rich, imho.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 06-19-2013, 02:46 PM   #56
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I didn't change advertised octane. I went from 93 octane E0 to 93 octane E10.
Or, at least that's what the pumps said... I ran three tanks of what the pump stated was E0 at $0.20 more per gallon than local E10 price. However, during the last tank, I realized that OBDII was reporting the ethanol content as 9.8%! Now that I'm running E10, guess what OBDII is reporting? 9.8%!
Does anyone know if the ethanol % that OBDII reports is accurate? I figure it would need to be if flex-fuel were to work correctly. If it is accurate, then there's probably not much to the theory of lean AFR due to adjusting to new fuel.
Hatch Nation #90
TboneZX3 is offline
Old 06-19-2013, 02:54 PM   #57
novus
novus's Avatar
Fan#: 107022
What I Drive: '12 Tuxedo Black Focus SEL
Points 927, Level 16
Points: 927, Level: 16 Points: 927, Level: 16 Points: 927, Level: 16
Level Up 27% Completed
Forum Activity 3%
FF Reputation: 5 novus Good Standing Member
Originally Posted by Seminoles View Post
Which ELM327 do you guys/gals use there are so many on amazon and all have mixed reviews I value your guys/gals opinion more.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
This is the one I purchased, works just fine.
novus is offline
Old 06-19-2013, 02:55 PM   #58
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
Gas station screwing customers?
Sent from my Galaxy Note 2 using FF Mobile.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 06-19-2013, 02:56 PM   #59
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
I need to pay closer attention to my pump. I usually get gas from the same station, Quik Trip, and always 93 octane. The most recent log I have shows 34.51% (part of the same log as the one I posted on page 1).
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 06-19-2013, 03:15 PM   #60
darkangelism
Sonic Crew #04
Fan#: 85425
Forum Activity 5%
Did your mpg change from E0 to E10, that is the biggest change, should be a couple mpg different
