TORQUE app- post me some logs :) - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-17-2013, 09:46 PM   #11
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
Originally Posted by dyn085 View Post
I suddenly have the urge to collect data as well, but it will do nothing but drive me insane...
No No NO you can't do that I'm the only one aloud to be insane on here....
Seminoles is offline
Old 06-17-2013, 10:44 PM   #12
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 551, Level 11
Points: 551, Level: 11 Points: 551, Level: 11 Points: 551, Level: 11
Level Up 2% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
More fun with data... This is a log of my commute to work (during non-rush hour) of ambient vs IAT. This is about ~23 or 24 minutes (each vertical line represents about 1 minute). Most of my commute is spent on the interstate travelling at 75+ mph; during this time, IATs stay relatively low (between +2 to +7). The last few minutes were in spent at stoplights and cruising the parking garage for a space.
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 06-17-2013, 10:53 PM   #13
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
I'm going to try to do some logging with Torque over the next couple of days so we can compare AFR to my stock tune + intake. There has been some concern about lean AFRs with stock+intake.
Hatch Nation #90
TboneZX3 is offline
Old 06-18-2013, 08:07 AM   #14
Deesiel678
Deesiel678's Avatar
Fan#: 105147
Can't wait to see the data. I bet they will be about the same... ~12.5.
Old 06-18-2013, 09:11 AM   #15
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Indeed. Yesterday I was viewing the AFR meter real-time at WOT ~4K RPM, and the meter was showing 11.94. I'll wait to pass any judgement until after a log is produced...
Hatch Nation #90
TboneZX3 is offline
Old 06-18-2013, 09:44 AM   #16
Seminoles
Seminoles's Avatar
Fan#: 98405
Forum Activity 2%
I agree with you should see 12.5:1 or lower ( same as a power valve and accelerator pump shot on a Holly ) @WOT and 15:1 @ idle or flat road cruising @ 55 mph. I wounder what it would be going down the grape vine with foot off gas say 30:1 or higher.
Old 06-18-2013, 10:02 AM   #17
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
It should go much higher, unless the 29.4 we see on the log above is a maximum possible reading for OBDII. The reason I say that is because this car completely shuts off fuel above 1500 rpm and off the throttle (in gear). Therefore, off the throttle would be basically an infinite AFR since the fuel portion of the ratio is zero.
Hatch Nation #90
TboneZX3 is offline
Old 06-18-2013, 01:29 PM   #18
Seminoles
Seminoles's Avatar
Fan#: 98405
Forum Activity 2%
That makes sense I was going by what was posted so far since it's hard to get in death technical info on this car and different story's from different dealers.
Old 06-19-2013, 09:16 AM   #19
Seminoles
Seminoles's Avatar
Fan#: 98405
Forum Activity 2%
Which ELM327 do you guys/gals use there are so many on amazon and all have mixed reviews I value your guys/gals opinion more.
Old 06-19-2013, 09:30 AM   #20
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Here's a log from yesterday. I tried to make this as close to the previous one as possible, for comparison's sake. 60mph steady in 5th, downshift to 3rd, WOT to redline.
Stock Ti-VCT w/K&N Typhoon intake. Oddly, the ambient temp reported here seems to be incorrect. It was about 87 degrees ambient when this was logged.
My AFR is definitely leaner than Deesiel678's, especially around 5.1K RPM.
Hatch Nation #90
TboneZX3 is offline
