TORQUE app- post me some logs :) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-16-2013, 04:47 PM   #1
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What I Drive: 2013 Oxford white Sedan 5M
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tjrommel Good Standing Member
for those with the TORQUE app, can you all post some logs of AFRs and 0-60 times with mods posted? I hate dyno sheets, data logs are much more important a dyno to me :/ I just went out and bought a GS4 (my iphone started pissing me off lol) and i'm awaiting the shipment of the ELM327.
Tjrommel is offline
Old 06-16-2013, 05:31 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,639, Level 94
Points: 23,639, Level: 94 Points: 23,639, Level: 94 Points: 23,639, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
data log = good. Dyno is good too if you use the right one. I don't trust any cell phone app over a $3k machine.
either way... I'm gonna try torque if it let's me do it without obdII...which I doubt.
mikebontoft is online now
Old 06-16-2013, 05:35 PM   #3
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What do you mean without an obdII?
Tjrommel is offline
Old 06-17-2013, 09:51 AM   #4
Deesiel678
Deesiel678's Avatar
Fan#: 105147
What I Drive: 2013 white SE hatch
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
FF Reputation: 3 Deesiel678 Good Standing Member
No 0-60 times, but you can see measured AFRs in this quick datalog. I posted this in the Tuning Solution thread a few weeks ago. I downshifted to 3rd at ~60mph and did a quick pull to about 6k RPM. My mods are K&N typhoon intake, 2.5" cat back exhaust, and Injected Engineering tune.
2013 Ox White SE hatch black pack 5m
H&R, Eibach, Styluz, K&N, Vibrant, JBR, Injected Engineering
Deesiel678 is offline
Old 06-17-2013, 12:22 PM   #5
Tjrommel
Tjrommel's Avatar
Fan#: 114674
Odd that the afr was so high when you let off. Should have kept going third tops aroubd 89 I can only imagine how much harder it pulls with the tune. Thanks forvthe log
Tjrommel is offline
Old 06-17-2013, 02:56 PM   #6
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
Might be one of there mileage secrets shut fuel off above a certain speed and throttle below a certain position. Like the C-Max these computer are so smart my hat off to the tuners sure they had many of sleepless nights to get where they are. One question is if it is a CAI why is the IAT higher then the ambient temp.
Seminoles is offline
Old 06-17-2013, 03:49 PM   #7
Deesiel678
Deesiel678's Avatar
Fan#: 105147
Its not a 'true' cai, and the heat shield isn't that great. IAT are ok when cruising but I've noticed that it gets heat saturated pretty quickly when waiting at stop lights (IIRC, it gets 20+ degrees over ambient fairly quickly... I will look at my logs again) When it got dynoed at Injected, IATs were nearly 40 over ambient.
Sent from my HTC Droid DNA
Old 06-17-2013, 05:35 PM   #8
Tjrommel
Tjrommel's Avatar
Fan#: 114674
I noticed that also, i have the injen sp sri and i think i'm honestly losing like 5-10 hp. it does nothing but suck in insanly high temps >.>
Tjrommel is offline
Old 06-17-2013, 06:01 PM   #9
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
It's a generally accepted rule that you lose/gain 1% power with every +/-10 degree (F) change in intake air temperature, respectively. If that is true, then to lose 10 hp in the 2.0 Ti-VCT due solely to heat soak, you would have to experience intake air temps 66 degrees (F) higher than ambient.
Granted, following the same rule, you would already be losing ~5hp if you were to compare 60 degree ambient temperatures to 90 degree temperatures, even if there were no heat soak.
I don't believe I've seen intake temperatures more than +20 degrees or so above ambient with the K&N Typhoon even after heat soaking a while at a stop. But, I don't experience exceptionally long stops in my day-to-day commute either.
Hatch Nation #90
TboneZX3 is offline
Old 06-17-2013, 06:19 PM   #10
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,258, Level 95
Points: 25,258, Level: 95 Points: 25,258, Level: 95 Points: 25,258, Level: 95
Level Up 91% Completed
Forum Activity 3%
I suddenly have the urge to collect data as well, but it will do nothing but drive me insane...
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
