Leaving Vehicle in Neutral - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-16-2013, 06:50 AM   #1
silverload
Fan#: 104810
What I Drive: 2013 winning blue Titanium +
FF Reputation: 1 silverload Good Standing Member
I live in Thailand where it is quite common to leave your car in neutral so a parking attendant can move it a few feet if necessary (you don't give him the keys as we do in America).
Yesterday for the first time I had to do this with my Focus and I got a warning message that the car was in neutral. There was no way to dismiss the warning and I could not lock the vehicle. I finally gave up and just walked away.
Luckily I only had to leave the car for a few hours, because I was afraid of draining the battery with the warning.
Is there any way around this?
silverload is offline
Old 06-16-2013, 07:19 AM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,383, Level 77
Points: 14,383, Level: 77 Points: 14,383, Level: 77 Points: 14,383, Level: 77
Level Up 84% Completed
Forum Activity 19%
FF Reputation: 16 Elizabeth Great Standing Member
I have a manual.. I have to try and see if I leave it in neutral and no parking brake if I can lock my car?
Elizabeth is online now
Old 06-17-2013, 01:38 AM   #3
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
Gotta wonder how many people get run over like that.................
amc49 is offline
Old 06-17-2013, 01:44 AM   #4
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,658, Level 100
Points: 35,658, Level: 100 Points: 35,658, Level: 100 Points: 35,658, Level: 100
Level Up 0% Completed
Forum Activity 8%
So they push your car with no way to steer it? Why are there parking attendants if you actually park the car your self? Such a screwed up system if you ask me.
TheGlassMaker is offline
Old 06-17-2013, 09:38 AM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,874, Level 74
Points: 12,874, Level: 74 Points: 12,874, Level: 74 Points: 12,874, Level: 74
Level Up 6% Completed
Forum Activity 99%
Different Places, Different "norms".
I imagine cars are parked nose to tail in rows, and may be pushed back & forth to get at those deeper in the row. Done here by leaving a key, not a trusted procedure there.
If this is needed often, & for longer parking, wiring in a "parking switch" that fools the system by bypassing the gear position switches manually may be possible (Wiring diagram & electrical knowledge needed).
Those with '13's can experiment to see if there's any easier solution that works..
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-22-2013, 02:14 AM   #6
silverload
Fan#: 104810
I found the solution!
A Thai friend did some inquiries on a Thai motor forum and they pointed him to the Driver assist menu in the vehicle. There is an item called Park lock ctrl which was not checked by default.
We tried checking it and that did the trick! I can now leave the car in neutral without a warning and I can lock the car.
Why neither the Thai nor the English Ford Focus manual didn't make any mention of this option is a mystery to me!
Old 06-22-2013, 06:20 PM   #7
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
You must leave the key in the locked car/ignition too? This is to prevent the car from being stolen? - assuming that's why the car is locked - and we feel safer with this? Or can you pull the key out in NEUTRAL now?
Here we give parking attendants keys to the ignition and not the glovebox - to protect valuables- lol.
IF leaving a key in the ignition is needed then maybe a 'CHIPLESS' key would give you piece of mind too?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 06-22-2013, 06:26 PM   #8
silverload
Fan#: 104810
I have no key, only a fob.
Old 06-22-2013, 07:06 PM   #9
a_2000_se
a_2000_se's Avatar
Fan#: 62964
Forum Activity 5%
ahhhh - I see said the blind man..... Auto or Manual?
I just rented a 2013 SEL a few months ago - with key. Didn't see THAT menu option or it just didn't click for me!
60k+ miles.
Old 06-22-2013, 07:56 PM   #10
silverload
Fan#: 104810
Auto.
