2007 focus zx4 replacing fuel filter tips - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-15-2013, 01:40 PM   #1
Dougmilliner
Fan#: 111002
What I Drive: 2007 black SES
FF Reputation: 1 Dougmilliner Good Standing Member
Hey guys I'm in the process of replacing the fuel filter on my 2007 focus. I haven't replaced the fuel filter on a vehicle before. So any help would be greatly appreciated. Thanks!!
Posted via FF Mobile
Dougmilliner is offline
Old 06-15-2013, 10:26 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,528, Level 98
Points: 27,528, Level: 98 Points: 27,528, Level: 98 Points: 27,528, Level: 98
Level Up 18% Completed
Forum Activity 13%
Take the fuel pressure off the system before you start. Remove the passenger side kick panel, unplug the fuel cutoff switch that is there. Then crank the engine and it will remove fuel pressure. If you don't, you stand the risk of going to the hospital with gasoline in your eyes. I wouldn't get right under the filter either. Don't remove the clips. Push in on the white rectangle. Wiggle and pull. Purchase a Microguard filter from O'Reilleys and it comes with the right clips in case you break one. Remove the small section of line going back to the fuel tank with the filter and bracket. You'll need a 1/4 extension and 5/16 or 8mm deep well to remove the screw holding the bracket to the car.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 06-15-2013, 11:33 PM   #3
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 301, Level 6
Points: 301, Level: 6 Points: 301, Level: 6 Points: 301, Level: 6
Level Up 2% Completed
Forum Activity 5%
FF Reputation: 8 Milton Good Standing Member
There are two different types of clips on the 2007 fuel filter. One has a large white rectangle and you push in on the rectangle like its a button.
The second one has a smaller white rectangle and if you examine/feel the other side you will see two prongs sticking out. For that one you squeeze the prongs together am push in on the prongs. The white rectangle will then be pushed out. You can pul on the rectangle but do not try to remove it, that will break it. I'll try to post some flicks.
Milton is offline
Old 06-16-2013, 06:34 AM   #4
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 13%
There's only one type of clip. The one you're seeing- on the side closest to the tank- is simply the back side. Follow that line about 6" back towards the tank, and you'll see a clip that you can reach the front- white rectangular- of the clip. That one points down, the line goes away from the clip horizontally, then turns up, and there is a fitting with a clip right there. It's extremely easy to remove since you can get your whole hand around the line and fitting. Remove that line with the fuel filter, and once you get it out from under the car, it's easy to rotate it so you can remove the other side from the filter.
Eventually the clip will break. Look for new clips. Doorman makes clips, you can buy a bag of 20 or so if you find a site that sells Doorman products. You can also get clips if you purchase the fuel filter kit I mentioned above. I am collecting clips since the way I describe removing the filter doesn't break the clips, at least not after 6 removals or so. I do expect the clips to break eventually.
Be eclectic.
Old 06-16-2013, 09:07 AM   #5
Milton
Fan#: 89715
Points 301, Level 6
Forum Activity 5%
2007 Fuel Clips - Two Types
First my statements pertain ONLY to the 2007 Ford Focus SES, the vehicle I own and for which I have the Ford Workshop Manual. Other years and models may or may not have a similar clip configuration. I can tell you that my vehicle uses both clip types on the fuel filter. Other forum members have found the same clip configuration on Focus vehicles.
It seems to be a common misconception that there is only one type of clip. This most likely contributes to the high rate of clip breakage found on this forum. The link below points to a pdf extract of the Ford Workshop Manual explaining how the two different clips operate.
2007 Fuel Clips - Two Types - Ford Workshop Manual
Good Luck
Milton is offline
Old 06-18-2013, 05:55 AM   #6
rkjjeep
Fan#: 42046
What I Drive: 2007 Silver 5 door
Points 1,383, Level 20
Points: 1,383, Level: 20 Points: 1,383, Level: 20 Points: 1,383, Level: 20
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 2 rkjjeep Good Standing Member
What milton said was the way my 2007 is as well.
rkjjeep is offline
Old 06-18-2013, 12:52 PM   #7
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 13%
I see. I wonder if they will change to that type of clip on everything now. Ford is quite silly when it comes to changing things around on vehicles from year to year, same body style, no apparent reasoning. Parts not broken but they fix it anyway.
Be eclectic.
