battery light - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-15-2013, 10:44 AM   #1
budpln
budpln's Avatar
Fan#: 89951
What I Drive: 2008 red ses
Points 2,655, Level 31
Points: 2,655, Level: 31 Points: 2,655, Level: 31 Points: 2,655, Level: 31
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
FF Reputation: 1 budpln Good Standing Member
battery light
Whats up guys I don't know if anyone has some insight on this or not but my battery light has come on its a 2008 ses not sure if i just need an alternator or the battery is no good can the car tell that? it runs starts and drives fine but the light has me concerned i need an alternator!! anyone had this problem yet???
budpln is offline
Old 06-15-2013, 01:00 PM   #2
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 969, Level 16
Level Up 69% Completed
FF Reputation: 4 gtferrari Good Standing Member
you can always drive to a parts store and have them test the battery while its in the car. if the battery is ok then pull the alternator and have it tested also.
and its free!
i had a battery go bad a year or so ago and i never had a light. the car wouldnt start and after jump starting it there was no light. so my guess is it is the alternator
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
Old 06-15-2013, 01:04 PM   #3
gtferrari
gtferrari's Avatar
Fan#: 88110
the alternator generates a lot of voltage it is limited down to something like 16 volts of which 14.6 goes into charging the battery. there are three windings and a rectifier using diodes that turn the ac voltage it produces into mostly dc voltage. if you have a lab scope you can see that there is a slight ac sign to the voltage signal. if a winding or diode were to go bad the signal would become unstable and the car can pick this up and alert you to a problem
5000K D2S Retrofit
Old 06-16-2013, 09:00 AM   #4
budpln
budpln's Avatar
Fan#: 89951
Thanks for the info buddy!!
budpln is offline
Old 06-16-2013, 09:17 AM   #5
budpln
budpln's Avatar
Fan#: 89951
I just put my multi meter to my battery while it was running it was only at 13.5 volts so Im guessing the alt. needs to be replaced
budpln is offline
Old 06-16-2013, 12:19 PM   #6
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,340, Level 20
Points: 1,340, Level: 20 Points: 1,340, Level: 20 Points: 1,340, Level: 20
Level Up 40% Completed
Forum Activity 11%
FF Reputation: 1 popwarhomie Good Standing Member
13.5 should mean the alt is working.. But not getting a full 14+ volts. Id say battery issue.
Whats voltage with car off?
My batteries sit at 12.6 volts off and 14.5 on for reference.
2010 Focus coupe 5 speed
Projector retrofit/LED tails/ Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/HDC3 18"s walled/ Juicebox G31/ DC power 270XP Alt/
94 Lightning
A lot of mods.
popwarhomie is online now
Old 06-16-2013, 01:13 PM   #7
gtferrari
gtferrari's Avatar
Fan#: 88110
you have a 6 cell battery. each cell developes 2.1 volts for a total 12.6 volts
a cell can go bad if the fluid has boiled off or spilled out. most batteries are no maintenance so you can not pull the top off and inspect each cell. if you can you can visually check the fluid level. the lead cells should be sitting under the fluid with the fluid just touching the plastic top casing- not coming up the casing wells. the fluid consists of sulfuric acid and distilled water. you can add water to a low cell but use distilled as tap water has minerals which will corrode and cover the lead.
it is uncommon for one cell to go bad from sulfation (a sulfuric coating on the cell due to excessive discharge). it is rather tuff to try to undo this process but you are welcome to try by placing the battery on a charger
5000K D2S Retrofit
Old 06-16-2013, 03:43 PM   #8
budpln
budpln's Avatar
Fan#: 89951
Voltage while the car is off is about 12.6
budpln is offline
Old 06-16-2013, 05:48 PM   #9
gtferrari
gtferrari's Avatar
Fan#: 88110
alt is bad if you see no corrosion on any of the surfaces...
5000K D2S Retrofit
Old 06-16-2013, 11:28 PM   #10
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,146, Level 74
Points: 13,146, Level: 74 Points: 13,146, Level: 74 Points: 13,146, Level: 74
Level Up 74% Completed
Forum Activity 30%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "General Technical Chat".
zetecDon is offline
