Fan settings 1, 2, 3 not working. - Focus Fanatics
Old 06-14-2013, 03:02 PM   #1
chrisandrew1989
Fan#: 115764
What I Drive: 2001 1.6 Focus in Aquamarine
FF Reputation: 1 chrisandrew1989 Good Standing Member
Hi all,
My Focus (2001, 1.6 hatch) has developed a blower issue. Settings 1, 2, and 3 will no longer work. After about half an hours running they all then blow a consistently weak stream of cold air, but otherwise nothing. Setting 4 works fine, although the AC doesn't seem to work when I switch to 4, whereas it does on the other settings.
I've had a look around online and the most common solution to this I've found seems to be the replacement of the blower resistor. Before I go ahead and order one though I thought I'd flag it up, just to see what people think.
I remember finding something somewhere that said fan setting 4 runs on a separate circuit to the others, so if the fuse is gone on the resistor the first three settings won't work but setting 4 will. I can't for the life of me remember where I read that though, so I thought I'd play the safe option.
Has anyone had this issue before / know how to rectify it? For the record, the Ford garage quoted me around 80 inc VAT.
Chris.
chrisandrew1989 is offline
Old 06-14-2013, 03:50 PM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
FF Reputation: 3 MEJY1988 Good Standing Member
IMO, it sounds like the fan resistor. You are on the right track about Speeds 1 - 3 going through the resistor pack, and setting 4 bypasses it, but IIRC they are on the same fuse/circuit. I would look at your local auto parts stores or online. Make sure that you have the pack installed in the duct work before using it, as it requires the air flow to keep it from burning up. Look in the How-To Section, I believe I saw a How-To for replacing it. Good Luck.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 06-14-2013, 04:05 PM   #3
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
Resistor block. Do it...
"I'm gonna sing the doom song..."
Mile30 is offline
