axle shaft seals - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-14-2013, 09:00 AM   #1
Kyllgore
Fan#: 1506
What I Drive: '03 ZX3 MTX pitch black,
FF Reputation: 1 Kyllgore Good Standing Member
axle shaft seals
2 dealership parts department have no idea and keep pushing me towards duratec parts, this is what I have found
http://www.oreillyauto.com/site/c/de...3408&ppt=C0362
would this be correct?
I've found many pics on this site but none of the axle shaft seals.
The dealer seem to not have a clue but only oreilly and napa web sites showing anything.I just need to know so I can order them and replace my axles, anytime you remove the passenger knuckle the center CV joint comes right out freely. Discovered that swaping struts.
Why does ford deny their own motorcraft part #
if only this modding stuff didn't take so much money
Mac SRI, FC 65mm TB, SVT 5 spokes
SVT brake kit, SS lines up front, SVT suspension
Kyllgore is offline
Old 06-14-2013, 10:26 AM   #2
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I believe this would be another option, and appears to be a Ford product:
http://focus.c-f-m.com/fordhalfshaft...ualmtx-75.aspx
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 06-14-2013, 11:40 AM   #3
Lappracing
Fan#: 74732
What I Drive: 2009 Focus black/silver
Points 170, Level 3
Points: 170, Level: 3 Points: 170, Level: 3 Points: 170, Level: 3
Level Up 40% Completed
FF Reputation: 2 Lappracing Good Standing Member
That is the seal that gets pressed into the transmission where the axle goes into it. The Ford P/N is F5RZ-1S177-AA. It is for all Focus' including the Duratec.
Lappracing is offline
Old 06-14-2013, 12:50 PM   #4
Kyllgore
Fan#: 1506
DOH, I'll have ordered from CFM now 3 times in the past month almost. Yeah I don't see how I missed that Thanks Mr.Bergner.
I think the stealership wanted over 30$ a piece for them. I do need 2 of them right?
and they go in the tranny? This is an over looked detail in many how to's I've read.
Kyllgore is offline
Old 06-15-2013, 06:42 AM   #5
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
Yep, you'll want two of them.
I'm kicking myself for not replacing them when I replaced an axle not long ago.
Old 06-18-2013, 01:11 PM   #6
Kyllgore
Fan#: 1506
Yeah so I have read. I'm gonna replace the bearings and hubs as well.
Kyllgore is offline
Old 07-16-2013, 04:59 PM   #7
BoostedFord
BoostedFord's Avatar
Fan#: 95085
What I Drive: 2002 Silver ZX3
Points 2,719, Level 31
Points: 2,719, Level: 31 Points: 2,719, Level: 31 Points: 2,719, Level: 31
Level Up 80% Completed
FF Reputation: 2 BoostedFord Good Standing Member
Was this a hard job to do? I keep putting it off but i hate the smell cause mine are leaky
Focus Revolution
Boosted Zx3 @ 20psi spinnin 327whp
"cant find em grind em"
BoostedFord is offline
Old 07-16-2013, 05:33 PM   #8
amc49
Fan#: 96610
Points 3,357, Level 36
Points: 3,357, Level: 36 Points: 3,357, Level: 36 Points: 3,357, Level: 36
Level Up 5% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Usually the Ford ones have the stone shield and aftermarket don't, just a thought and difference in price.
amc49 is offline
Old 07-16-2013, 09:02 PM   #9
DoctorJ
Fan#: 113834
What I Drive: 2001 Twilight Blue sedan
Points 63, Level 1
Points: 63, Level: 1 Points: 63, Level: 1 Points: 63, Level: 1
Level Up 26% Completed
Forum Activity 5%
FF Reputation: 1 DoctorJ Good Standing Member
I recently replaced both axles, both axles seals, both hubs and both wheels bearings. The job wasn't too bad at all actually. Mind you that everything else up front on my car is brand new (less than 1 month old), and lubed well.
The worst parts:
The snap ring on the backside of the wheel bearing. Soak this thing REAL good if you live in the rust belt. I didn't and it seriously took us 20 minutes to get one out.
The original axel seals were a pain in the but to get out as well. I was pretty limited on the tools i had too. If I had to do it again, I'd use a slide hammer or something similar and a toggle bolt with rubber caps on the "butterfly".
http://www.diseno-art.com/images_3/slide_hammer.jpg
http://image.made-in-china.com/2f0j0...oggle-Bolt.jpg
Putting the seals back in was easy with the right "tool". I used some 2x4 wood i had laying around and placed the seal on the wood, traced the inside & outside hole diameter and "notched" a spot for the seal to sit into the wood. I greased the seal with high temp moly lube, placed it against the transmission and tapped it in. Goes it straight and easy this way.
Other people have used PVC pipe the same diameter as the seal to tap it in.
DoctorJ is offline
