rear defrost metal tab broke off - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-13-2013, 10:20 PM   #1
brykit
Fan#: 114184
What I Drive: 2001 Blue Focus Wagon
FF Reputation: 1 brykit Good Standing Member
The metal tab on the defrost grid that connects the female electric connector broke off. Any suggestions on what I can use to connect it again?
brykit is offline
Old 06-13-2013, 10:27 PM   #2
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 326, Level 6
Points: 326, Level: 6 Points: 326, Level: 6 Points: 326, Level: 6
Level Up 52% Completed
Forum Activity 6%
FF Reputation: 8 Milton Good Standing Member
New window.
Milton is offline
Old 06-14-2013, 12:17 AM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,863, Level 74
Points: 12,863, Level: 74 Points: 12,863, Level: 74 Points: 12,863, Level: 74
Level Up 4% Completed
Forum Activity 99%
If the whole bracket came loose from the window, you could TRY super glue (just a drop) to hold it back on, followed by the conductive paint from a grid repair kit painted over it & the grid edge line to reconnect it. (doubt the paint would hold it as a glue)
Worth a try, the first answer MAY be the only "satisfactory" repair if you aren't real gentle with that connection.
luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 06-14-2013, 10:33 AM   #4
don627
Fan#: 56863
What I Drive: 2014 Focus Hatchback
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 2%
FF Reputation: 1 don627 Good Standing Member
Short of a new window it will be hard to make a lasting repair because you have a lift gate, all that banging around when you close it will likely undo any repair you try to make.
don627 is offline
Old 06-14-2013, 02:06 PM   #5
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
Yep, there was a special quick soldering thing they used to do to fix that, be willing to bet they'd rather sell the glass now instead. The fix was very picky about how it was done, heating the glass to solder tab could easily shatter it. Only real place to get that fixed and right would be factory where glass was made.
amc49 is offline
Old 06-14-2013, 03:10 PM   #6
speedyg
Fan#: 49534
What I Drive: 2001 White SE 5-speed
FF Reputation: 3 speedyg Good Standing Member
If its the tab that came off the glass use aluminum tape to hold it in place. Worked fine on my van when the tab came off the glass.
7/8/13 Final mileage 248,565-sold
speedyg is offline
Old 06-15-2013, 01:39 AM   #7
Squareleft
Squareleft's Avatar
Fan#: 33224
What I Drive: 01 ZX3, 07 Volvo S60R
Points 1,090, Level 17
Points: 1,090, Level: 17 Points: 1,090, Level: 17 Points: 1,090, Level: 17
Level Up 90% Completed
FF Reputation: 1 Squareleft Good Standing Member
Buy-Sell-Trade Rating: (6)
They sell kits to repair that situation at parts stores like oreillys, autozone, etc.
Squareleft is offline
Old 06-15-2013, 04:52 AM   #8
amc49
Fan#: 96610
Forum Activity 13%
Yes, and like so many other 'kits' they sell there, they are crap. The window does not defrost as well, hard to get the full amount of current through the patch job since quite a bit goes through there. Fixing the main supply is quite different from just fixing one line going across the window.
amc49 is offline
