Looking for slip on rocker panels. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-13-2013, 09:01 PM   #1
justagrrlinny
Fan#: 115493
What I Drive: 2001 Ford Focus SE
FF Reputation: 1 justagrrlinny Good Standing Member
Hi all, well, after calling EVERY body shop and welder within a 100 miles radius, it's not going to be possible for me use the weld-on rocker panels. Every place I called wants $300+ PER SIDE to remove the old rocker panels and weld on the new ones. I can't afford that. I'd be looking at nearly $1000 to first buy the panels and then pay for the work to have them done.
My only other solution, is the band-aid effect. To buy the SLIP-ON panels and have them riveted on the bottom. I found a shop that would do that for $50 per side. The problem...is that I cannot find the slip-on panels ANYWHERE on the internet. I can only find the weld-on ones.
Here is a link to an eBay listing of what I'm talking about. The problem with this listing is they don't ship to the United States. They were the ONLY listing anywhere on the internet I could find the type I need. If anyone...can PLEASE find a place where I can buy the slip on panels, I would really appreciate it. My car is a 2001 Ford Focus SE 4-Door Sedan.
http://www.ebay.com/itm/4-DOOR-ROCKE...51284783932%26
justagrrlinny is offline
Old 06-13-2013, 10:16 PM   #2
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
What about getting a set of side skirts? I'm not sure if you're wanting to go that route, and most of the ones readily available wouldn't look right without an entire body kit. But you can get lucky and find a set of SVT skirts or the Ford Accessory skirts, which in my opinion, can be pulled off with factory front and rear bumpers.
2004 ZX3 MTX - Twighlight Blue_____________________________________________________________________________ _ _ _ _ _ _
Mr.Bergner is offline
Old 06-13-2013, 10:43 PM   #3
Red01Focus
Fan#: 40437
What I Drive: 2001 Infa Red SE
Points 11,068, Level 69
Points: 11,068, Level: 69 Points: 11,068, Level: 69 Points: 11,068, Level: 69
Level Up 55% Completed
FF Reputation: 10 Red01Focus Great Standing Member
Buy-Sell-Trade Rating: (56)
i don't see then if you couldn't do the same with the one's i sent you a link of
SEDAN REVOLUTION #13
Red01Focus is offline
Old 06-14-2013, 12:13 AM   #4
justagrrlinny
Fan#: 115493
Mr.Bergner -- I would go the side skirt route, but that's an even worse band-aid, and it doesn't fix the bottom part of the panel that is cracked. The metal slip on panels essentially cover the entire panel from top to bottom and are either welded onto the bottom or riveted on. I'm not exactly sure how they connect at the top...they slip over the edges of the inside door jam...but how exactly they do that, I'm not sure at this point. Maybe another reader can explain that portion to me??? But regardless, they can be sealed along the edges and the top, and because they're solid steel, it'll take ages for any rust from the original rocker panels to penetrate through to the cover panels. If I had my choice, I'd have the old one's cut off and new ones welded on...but the price to do that is just outrageous.
Red01Focus -- I think the one's you sent me a link to were for a 2 door and weren't the complete panel...the back curved portion was missing.
Update: I was finally able to find a U.S. shipper for the slip on panels, however, the ODD thing, is that they come in two separate parts...the straight part, and the curved part at the end. Unsure as to why it's like that but may have something to do with how they fit onto the inside door jam.
Here's a link for the U.S.shipper that shows the 2-part slip on panels and shows the curved part I'm talking about: http://www.noramstore.com/Ford_Focus...p/0400140u.htm
Old 06-14-2013, 01:15 AM   #5
burnie
Fan#: 57310
What I Drive: 2002 silver ZX5
Points 419, Level 8
Points: 419, Level: 8 Points: 419, Level: 8 Points: 419, Level: 8
Level Up 38% Completed
FF Reputation: 1 burnie Good Standing Member
Plastic rocker covers
I`ve seen pics of Focus with a factory plastic rocker cover . Does Ford not supply that part ? Might be worth it to check some junk yards
burnie is offline
Old 06-14-2013, 07:39 AM   #6
02ztsian
02ztsian's Avatar
Fan#: 14466
What I Drive: V6Mistake, 03 ZX3
Points 3,015, Level 33
Points: 3,015, Level: 33 Points: 3,015, Level: 33 Points: 3,015, Level: 33
Level Up 77% Completed
Forum Activity 4%
FF Reputation: 9 02ztsian Good Standing Member
Buy-Sell-Trade Rating: (14)
JC Whitney?
CAR ROCKER REPAIR PANELS
Heavy-duty rocker panel slips on easily and covers damaged or rusted-out panel
The easy and economical way to restore original looks
Available for 2- and 4-dr. models
No need to cut or remove old panel. Top-quality 20-gauge steel, die formed to fit perfectly. Fast, easy, professional-looking installation. Simply screw on, rivet on or weld on panel.
http://www.jcwhitney.com/car-rocker-...d620y2001g26j1
Points to ponder:
When you are dead, you do not know you are dead.
It's only painful for others.
Same applies to stupid.
02ztsian is online now
Old 06-14-2013, 08:01 AM   #7
justagrrlinny
Fan#: 115493
02ztsian - I will check there as well but I think the curved part is also left off of those panels.
burnie - Not sure if the factory plastic rocker covers completely cover the rocker from top to bottom?? Also, we only have one junkyard here where I live and they don't have any...already tried them when I was looking for side skirts.
Old 06-14-2013, 08:07 AM   #8
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,527, Level 70
Points: 11,527, Level: 70 Points: 11,527, Level: 70 Points: 11,527, Level: 70
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
These are for sale right now on Facebook:
https://www.facebook.com/groups/401047126585160/
Hatch Nation #8
September 2012 Ride of the Month
katiekay is offline
Old 06-14-2013, 08:41 AM   #9
justagrrlinny
Fan#: 115493
pyroinsa -- It looks like these are for a ZX3. I have a 2001 SE Sedan.
Old 06-14-2013, 08:44 AM   #10
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
All rocker panels are the same length width and height for all Focus models from 2000 - 2007. It doesn't matter what these are off of, they will fit your car.
Hatch Nation #8
katiekay is offline
