Mtx75 clutch swap - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-15-2013, 02:14 PM   #11
StancedFocus12
StancedFocus12's Avatar
Fan#: 113432
What I Drive: 2012 Ford Focus SE Sport Package
FF Reputation: 1 StancedFocus12 Good Standing Member
What do you think then? I want a new clutch regardless its slipping already
StancedFocus12 is offline
Old 07-15-2013, 01:15 AM   #12
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What I Drive: 2013 Oxford white Sedan 5M
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tjrommel Good Standing Member
lol my clutch is slipping at 7k miles, I drive descently hard but not hard enough to make it slip at 7k miles.
Tjrommel is offline
Old 07-15-2013, 07:50 AM   #13
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 7%
FF Reputation: 13 BetaDnB Great Standing Member
This clutch engages super high on everybody's MTX75 equipped MK3.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
Old 07-15-2013, 08:13 AM   #14
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 591, Level 11
Points: 591, Level: 11 Points: 591, Level: 11 Points: 591, Level: 11
Level Up 82% Completed
Forum Activity 3%
FF Reputation: 1 BrApple Good Standing Member
Unless the MK3 Focus is different, the MTX-75 does not use a pilot bearing, so that would not be an issue.
I would say that there is an issue with the tob in the OP's car.
Just an fyi, going to a cermamic clutch for more grip will cause the the tob to make noise faster because of the ceramic dust. Both of the clutches I have had in my Contour hve done the same thing.
As noted the MTX-75 does/can make alot of gear roll over noise. However I have not noted any in my MK3.
An aftermarket clutch that is design for high power will not last as long as a stock clutch. It just isn't designed to. But of couse how it is driven will make a difference.
For a DD with ocational spirited driving a factory clutch is just fine, imho, no need to upgrade.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
Old 07-15-2013, 09:03 AM   #15
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Originally Posted by TboneZX3 View Post
I wouldn't expect a bad pilot bearing to be your issue...
I "misspoke" here--I meant to say at the time that I didn't think the problem was a throwout bearing. I will edit that to correct my mistake.
But, after re-reading the OP's statements, I would also concur that the TOB is likely an issue. He stated the it makes an "ungodly" noise when the clutch is disengaged in reverse ("put the clutch down" in his words). That would point to the TOB. If it is indeed the TOB, I wonder why it would only make that noise in reverse...
Good to know--I wasn't aware of that.
Hatch Nation #90
TboneZX3 is offline
Old 07-15-2013, 09:27 PM   #16
StancedFocus12
Fan#: 113432
It's just the mere fact that when I bought the car it engaged lower and gradually started slipping as it aged. I ordered a new stock clutch to see if this problem can be solved and does anyone know of it can be adjusted?
Old 07-15-2013, 10:03 PM   #17
Tjrommel
Tjrommel's Avatar
Fan#: 114674
How much is a new church?
Tjrommel is offline
Old 07-15-2013, 11:01 PM   #18
indystar
indystar's Avatar
Fan#: 101011
What I Drive: Winning Blue Focus MK3 Sport
FF Reputation: 1 indystar Good Standing Member
is this a mistype or a joke...lol
Sonic's MK3 Crew #18
Winning Blue MK3 Sport
-K&N 57s|Painted Yellow Calipers|Tinted Rear Lights|17" Alloys|Sport Body Kit-
indystar is offline
Old 07-16-2013, 01:04 AM   #19
Tjrommel
Tjrommel's Avatar
Fan#: 114674
I'll let you be the judge ;-)
Tjrommel is offline
Old 07-16-2013, 07:47 AM   #20
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
It can't be adjusted.
Hatch Nation #90
TboneZX3 is offline
