Mtx75 clutch swap - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-13-2013, 08:12 PM   #1
StancedFocus12
StancedFocus12's Avatar
Fan#: 113432
What I Drive: 2012 Ford Focus SE Sport Package
FF Reputation: 1 StancedFocus12 Good Standing Member
Mtx75 clutch swap
Just trying to figure out if a 5spd Mazda 3 clutch will crossover to the current 5spd Focus. Any help or diagram pictures would be great especially with a prototype clutch masters clutch I'm helping make.
StancedFocus12 is offline
Old 06-14-2013, 08:28 AM   #2
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What I Drive: 2013 Oxford white Sedan 5M
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tjrommel Good Standing Member
This is my first non POS, what benefit do you gain from performance lctches
Tjrommel is offline
Old 06-14-2013, 01:43 PM   #3
StancedFocus12
Fan#: 113432
What don't you gain from performance clutches?
Old 06-14-2013, 01:46 PM   #4
Tjrommel
Tjrommel's Avatar
Fan#: 114674
Less slip? Doesn't make sense I me how it will increase performance... They're softer so you may gain like .05 seconds on 0-60 they wear out faster? So can you please explain what the benefits are. I know nothing on the subject and won't pretend to I just want an answer lol
Tjrommel is offline
Old 06-14-2013, 02:05 PM   #5
StancedFocus12
Fan#: 113432
Well for starters, the stock throw out bearing on mine is and always was trash. It was noisy and makes bad sounds when I shift and Ford was reluctant to fix it under warranty, said it was normal. I call bullshit and am on a mission to prove a point plus the factors of adding a turbo system amongst other mods that increas horsepower and torques to 300+ you need a stronger clutch. Plus, I will not be racing mine so the clutch won't wear out any faster than a normal one would.
Old 06-14-2013, 02:08 PM   #6
Tjrommel
Tjrommel's Avatar
Fan#: 114674
Your TOB rattle when in neutral occasionally? How would a clutch fix that?
Tjrommel is offline
Old 06-14-2013, 03:07 PM   #7
StancedFocus12
Fan#: 113432
Yeah and the new clutch setup I'm getting made has a new stronger more durable one. That's why I'm trying to see if mazda has a matching clutch assembly because if they do I'm swapping
Old 06-14-2013, 04:50 PM   #8
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
If there's a rattle when the clutch is engaged (out) in neutral, it would either be a pilot bearing or the normal MTX75 gear rollover noise. A bad throwout bearing makes noise when pressure is applied to it. Pressure is only applied to the throwout bearing when the clutch is disengaged (depressed/pushed in). As the clutch is disengaged, a bad throwout bearing will make a chirping or squealing noise. Gear rollover noise (rattle) with the clutch engaged in neutral is a very common occurrence with this transmission--more so in the earlier Focus models, but I've heard it on occasion from my MK3 also.
Hatch Nation #90
TboneZX3 is offline
Old 06-14-2013, 08:06 PM   #9
StancedFocus12
Fan#: 113432
Mine makes the noise that sounds like crunching when I let it off and releases super high and its ungodly loud when I'm backing up and put the clutch down. I need a higher grade anyways for the turbo kit I'm working on
Old 06-15-2013, 08:34 AM   #10
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I wouldn't expect a throwout bearing to be your issue...
Hatch Nation #90
TboneZX3 is offline
