**synthetic or not? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-09-2013, 08:12 PM   #21
VillageT
Fan#: 97061
What I Drive: 2005 Silver ZX3
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Level Up 50% Completed
FF Reputation: 1 VillageT Good Standing Member
95% of engine wear occurs at start-up. Low viscosity (5W20 for the Dtec) oils are much better at getting lubrication to the critical areas during cold starts. Low viscosity synthetic oils and blends do not break down at higher temps like low viscosity conventional oils.
Your engine was designed to run on Motorcraft Synthetic Blend. I put 160K on a Dtec with the MC oil and 5K oil changes with absolutely no problems. The synthetic blends are a little cheaper than the full syn but if you want to run longer oil changes I would go to the full syn.
VillageT is offline
Old 07-09-2013, 08:44 PM   #22
sanford12
sanford12's Avatar
Fan#: 116365
What I Drive: 2012 Focus Titanium
FF Reputation: 1 sanford12 Good Standing Member
I buy what ever full syn oil is on sale then run it for 10,000 miles. With a filter change and and a oil top up at 6000 miles.
FoMoCo cars I've owned
1970 429 Cyclone, 1978 LTD II 302, 1980 Fiesta 2nd best Ford I've owned
1986 Tempo LX, 1990 Areostar,1996 Areostar Best vehicle I've ever owned
2005 Ford 500, 2006 Freestyle, 2012 Focus Titanium pearl white
sanford12 is offline
Old 07-09-2013, 09:23 PM   #23
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,765, Level 24
Points: 1,765, Level: 24 Points: 1,765, Level: 24 Points: 1,765, Level: 24
Level Up 65% Completed
Forum Activity 3%
FF Reputation: 5 Miller88 Good Standing Member
Ford recommends 7500Mile OCI for my 2011 Focus using oil that meets a certain spec. There are numerous conventional oils that meet the spec, along with numerous synthetics.
Ford's Motorcraft oil is a really good synthetic blend and can be had for a great price.
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 07-09-2013, 09:32 PM   #24
amc49
Fan#: 96610
Points 3,376, Level 36
Points: 3,376, Level: 36 Points: 3,376, Level: 36 Points: 3,376, Level: 36
Level Up 18% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
'Low viscosity (5W20 for the Dtec) oils are much better at getting lubrication to the critical areas during cold starts.'
So they would have you believe. One should consider that the thicker oil will not drop back out of passages as fast as the thinner one will, or capillary action, which works better with thicker oil. If the oil is still in the critical area then no need to get it there faster.
Biggest problem I've personally seen is start up rattle using thinner oils, I have cured problems like that by going to a thicker oil. Try explaining that one away..........
'Reactive maintenance methods are seldom wise for complex equipment, systems or living beings.'
Could not more heartily disagree. 'Reactive' thinking often cures so many problems one cannot count. ALL vehicle recall actions are reactive, as well as any action taken by a manufacturer to cure perceived problems in the field. Any modification to a factory service manual based on real world previous result would be reactive as well. Are we saying here those actions are bad?
Reactive thinking can be strong evidence of thinking in the best interest of oneself. The alternative is simply falling into the ranks with the rest of the lemmings. Or, controlled thought. Sorry, you can have my portion of that.
amc49 is online now
