Reverse lights not working please help - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-17-2013, 12:33 AM   #21
suprchrgd_zx3
suprchrgd_zx3's Avatar
Fan#: 87400
What I Drive: 2001 black w/blue flake suprchd ZX3
Points 220, Level 4
Points: 220, Level: 4 Points: 220, Level: 4 Points: 220, Level: 4
Level Up 40% Completed
FF Reputation: 1 suprchrgd_zx3 Good Standing Member
Originally Posted by ShadyNova View Post
why not run power to the switch and see if they work that way then if they do then find out where you power has gone to
how? by running a hot wire from the battery? is that too much current coming straight off the battery? ill try anything at this point
suprchrgd_zx3 is offline
Old 06-17-2013, 12:34 AM   #22
ShadyNova
ShadyNova's Avatar
Fan#: 84525
What I Drive: 2003 Gry/Gry ZX3
FF Reputation: 1 ShadyNova Good Standing Member
well thats just it i dont know what it needs to be let me see if i can info on that mine dont work as well but i have not checked anything out yet
ShadyNova is offline
Old 06-17-2013, 12:37 AM   #23
suprchrgd_zx3
Fan#: 87400
Points 220, Level 4
i pulled the switch already and ran a jumper from each wire to the plug and nothing, so i tested the wire and had no power i tried with key off and on and in neutral and reverse with key off and on also with the headlights off and on.
Old 06-17-2013, 12:49 AM   #24
suprchrgd_zx3
Fan#: 87400
Points 220, Level 4
by reading tons of posts it appears that most people solve their problem by simply replacing the switch. i may replace it anyway but i feel like the problem is deeper than that since i get no current to either of the wires in the plug going to the switch.. ive also heard people talking about another switch under the shifter boot?? perhaps in a different model or transmission?
Old 06-17-2013, 12:56 AM   #25
ShadyNova
ShadyNova's Avatar
Fan#: 84525
well i have a 2003 zx3 and i have looked under the boot and i did not see anything so on my car its on the trans but i will check tomorrow if im getting any power to the switch and let you know
Old 06-17-2013, 08:32 AM   #26
KCaudill
Fan#: 46826
What I Drive: 2006 Tredour Red ZX3 SE
Points 334, Level 6
Points: 334, Level: 6 Points: 334, Level: 6 Points: 334, Level: 6
Level Up 68% Completed
FF Reputation: 1 KCaudill Good Standing Member
The reverse switch is just that a switch. It will not have power. It passes power thru it. Put your tester on volt DC. One test lead from the test meter on the batter + and one test lead on one of the conducters of the switch. If it reads 0V the move the + test lead to the ( - ) side of the batter and test both conductors. You will have to have the key switch to "on" to get power to the switch. If you put both potinals on the switch, you will either ruin the switch if its good, melt the wire, or ruin something else tied to the switch.
KCaudill is offline
Old 07-13-2013, 11:56 AM   #27
brown9335
Fan#: 116688
What I Drive: 02, Blue ZTS
FF Reputation: 1 brown9335 Good Standing Member
Read this post. I have same problem. Did you find anything? I've done all you've done plus checking the pop up inside the transmission that presses the ball bearing switch while the sensor was removed. I'm stuck too. Please share if you figure it out. I'll do the same on my end.
brown9335 is offline
