Reverse lights not working please help - Focus Fanatics
Old 06-11-2013, 09:16 PM   #1
suprchrgd_zx3
suprchrgd_zx3's Avatar
Fan#: 87400
What I Drive: 2001 black w/blue flake suprchd ZX3
FF Reputation: 1 suprchrgd_zx3 Good Standing Member
i have a 2001 zx3 5 speed. the reverse lights will not work. i have jumped the switch and still nothing. i used a test light on the wiring plug going to the switch and nothing.... i checked the fuse, #53 in the panel under the dash, its fine. bulbs are new. is their any other switch or relay besides the reverse switch on the transmission under the air box and the fuse under the dash? if anyone can help me solve the issue. ive read lots of threads that say jump the switch to see if thats the problem, i done that and nothing.... so i tested to see if im getting power to the switch, im not... next step i pulled the fuse again to make sure. its fine replaced with a new one just to be sure. still no luck... any help???
suprchrgd_zx3 is offline
Old 06-11-2013, 09:33 PM   #2
felixthecat
felixthecat's Avatar
Fan#: 80663
FF Reputation: 53 felixthecat Excellent Standing Member
I was going to say just replace the switch, like I did last week.
Introduce Mr. Torsen to the mix D23 crew- D-Tech- Sedan Revolution= #131
felixthecat is offline
Old 06-11-2013, 10:04 PM   #3
suprchrgd_zx3
Fan#: 87400
i wish that would have fixed it.. i dont mind wasting the money to fix it if i could just FIND the problem
Old 06-11-2013, 10:11 PM   #4
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
FF Reputation: 15 mikeeshaq Great Standing Member
ZX3 that is a hatchback ?
Well I believe so!
Your umbilical going to your hatch is suspect as the wires inside crack, short open
There are MANY issues and many postings
Now I see you are in the rust belt so you could have a rotten ground connection someplace
mikeeshaq is offline
Old 06-11-2013, 10:19 PM   #5
suprchrgd_zx3
Fan#: 87400
im not even worried about the possible cracked wiring in the hatch i have no power at all even to the switch. the rest of the tail lights brake lights work. i have to get power to the switch before it will even b possible to test the wiring on the other side of the the hatch boot... sooo aggravated
Old 06-11-2013, 10:22 PM   #6
suprchrgd_zx3
Fan#: 87400
Well I believe so!
yes RUST BELT and im leaving this dump as soon as possible. FL bound
Old 06-11-2013, 10:35 PM   #7
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
FF Reputation: 86 BC_ZX3 Excellent Standing Member
So just to state the obvious, fuse 53 is only hot (powered) in ignition position run or start.
Did you test for 12V at the fuse 53 socket with the ignition on? Don't assume simply because a fuse is fine, the circuit is powered before the fuse.
BC_ZX3 is offline
Old 06-11-2013, 10:38 PM   #8
suprchrgd_zx3
Fan#: 87400
i did not test at the fuse box but im going to wal mart right now to get a meter i used my friends earlier today back in 15mins
Old 06-12-2013, 08:30 AM   #9
don627
Fan#: 56863
What I Drive: 2007 infra-red zx3
FF Reputation: 1 don627 Good Standing Member
I'm going to guess the hatch wires up on top between the hatch and body. Are you sure your brake lights work?
don627 is offline
Old 06-12-2013, 10:54 AM   #10
goingFocus
Fan#: 75386
What I Drive: 2005 CD silver ZX3 SES
FF Reputation: 1 goingFocus Good Standing Member
Do the license plate lights work? If not the most likely the culprit is the bundle of wires coming from the body side of the hatch to the hatch. The tail/brake lights come from a bundle of wires that do not pass through the hatch. Rust-belt corrosion is also a likely culprit. Get some dielectric grease and simply remove the connector, to break the corrosion bond, and liberally schmear the grease on the connector. My 2 GL
goingFocus is offline
