Loss of power/ stumble issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-11-2013, 02:45 PM   #1
lowzts
lowzts's Avatar
Fan#: 115627
What I Drive: 02 liquid grey zts mach audio
FF Reputation: 1 lowzts Good Standing Member
I drive a 02 zts mach audio edition, 5-speed zetec. I'm having problems with what I feel is loss of torque and a stumble under light to medium acceleration. Not sure if its me expecting too much out of my focus with 160xxx+ miles or if its fixable. Simple, cheap upgrades like k&n cone filter (stock intake tubing) and I hack- jobbed my exhaust just after the rear axle. Any advice or input is welcome and appreciated. I'm not a master mechanic but I'm pretty foci smart :-)
Sent from my ZTE N9120 using FF Mobile
lowzts is offline
Old 06-11-2013, 03:07 PM   #2
79mgb
79mgb's Avatar
Fan#: 105006
What I Drive: 1979 MG MGB
Points 2,815, Level 32
Points: 2,815, Level: 32 Points: 2,815, Level: 32 Points: 2,815, Level: 32
Level Up 44% Completed
FF Reputation: 3 79mgb Good Standing Member
Buy-Sell-Trade Rating: (4)
It would help to know what regular or interval maintenance has been done to the car.
Also, Have you replaced any other original parts on the engine? Does the engine have any issues while idling?
Just curious.
Driving a Zetec Powered MGB. :)
79mgb is offline
Old 06-11-2013, 03:11 PM   #3
lowzts
lowzts's Avatar
Fan#: 115627
New egr valve, plugs and wires, alternator, coil pack, clutch and flywheel, regular oil changes and fluid changes, and yes it seems to almost misfire at an idle. Thoufh its intermittant at an idle
lowzts is offline
Old 06-11-2013, 04:03 PM   #4
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 12 Outback
Points 9,450, Level 65
Points: 9,450, Level: 65 Points: 9,450, Level: 65 Points: 9,450, Level: 65
Level Up 34% Completed
Forum Activity 11%
I moved you to the general technical area of the forum. You should get some more answers to your question here.
2012 Subaru Outback 6 speed manual - current DD
I always moderate naked!
bringler26 is online now
Old 06-12-2013, 11:00 AM   #5
Kodyston
Kodyston's Avatar
Fan#: 112498
What I Drive: 2003 Sangria Red ZX3; Zetec; MTX-75
Points 625, Level 12
Points: 625, Level: 12 Points: 625, Level: 12 Points: 625, Level: 12
Level Up 50% Completed
FF Reputation: 3 Kodyston Good Standing Member
My 2003 is kinda doing the same thing. With the intermittent missing at idle, and not wanting to get up and go from a stop. If you figure out what's up, I'd like to know so maybe I can get mine running a little better too.
Kodyston is offline
Old 06-12-2013, 11:04 AM   #6
lowzts
lowzts's Avatar
Fan#: 115627
For sure dude. I'm going to try flow testing my injectors... fuel pressure is good so imma start ruling things out. When I find something I will let u know
lowzts is offline
Old 06-12-2013, 11:25 AM   #7
Kodyston
Kodyston's Avatar
Fan#: 112498
Okay, thanks lowzts!
Kodyston is offline
Old 06-14-2013, 11:20 AM   #8
xsuicidesn0wmanx
xsuicidesn0wmanx's Avatar
Fan#: 65239
What I Drive: 2001 Black Ford Focus SE Sedan
Points 554, Level 11
Points: 554, Level: 11 Points: 554, Level: 11 Points: 554, Level: 11
Level Up 8% Completed
FF Reputation: 1 xsuicidesn0wmanx Good Standing Member
When I had a similar problem it ended up being the pcv hose had collapsed and was restricting airflow(bad vacuum). Feel around, if its real spongy, or feels flat around the 90 deg bend replace it. You can find the 'bend' that usually goes bad about 6 or so inches below the throttle body, and it should go around the back of the engine towards the drivers side and connect to a brief metal tube just below the thermostat/coil pack area. New hose should come with a heat shield on it, i recommend getting a cheap hose clamp to replace the oem clamp while you're at it.
xsuicidesn0wmanx is offline
Old 06-15-2013, 07:26 AM   #9
lowzts
lowzts's Avatar
Fan#: 115627
Going in to have injectors flow tested and possibly cleaned (properly cleaned not a quick lube cleaning). As well ad new pcv valve and hoses. I will let you know when I have results
lowzts is offline
Old 06-15-2013, 07:59 AM   #10
Kodyston
Kodyston's Avatar
Fan#: 112498
Sounds good. I'll be waiting on the results. :)
Steeda Louvered hood, Steeda Razzi body kit, carbon fiber dash trim, shift knob & Steeda door sill plates, American Racing chrome plated 16" wheels, SVT suspension, K&N lifetime drop in air filter and fog light modification.
Kodyston is offline
