Getting rid of those dang dark spots for a new face gauge - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 06-11-2013, 12:49 PM   #1
tkheaven
tkheaven's Avatar
Fan#: 59098
What I Drive: 2002 Pitch Black ZX3
Points 1,155, Level 18
Points: 1,155, Level: 18 Points: 1,155, Level: 18 Points: 1,155, Level: 18
Level Up 55% Completed
FF Reputation: 3 tkheaven Good Standing Member
Hello all.. I purchased a new face with leds for my 2002 Focus ZX3.. so far it looks sweet EXCEPT for the fact the these guys didn't clean out the leftover green residue (in truth, it's the white tacky glue film) from the oem face. SO, that said...what is the recommeded method/solution used to eliminate that without messing up/making the clear plastic opaque? Currently, these little spots are restricting light from properly shining through the face. BlackCat (where I purchased the face) recommends, at least gently scraping it off..at most, use a alcohol-based solvent (Isopropyl Alcohol) to rub off it off.
Can anyone going through this process give their 2cents on the most effective way of removing these spots without damaging the plastic?
Thanks
"possible" cloning of humans - check
"possible" evolution from non-living particles - check
"possible" time travel aka Big Bang machine - check
creating the perfect pres. candidate and send him back eight years ...impossible...
tkheaven is offline
Old 06-11-2013, 01:13 PM   #2
tkheaven
tkheaven's Avatar
Fan#: 59098
And while I'm at it... where can I obtain 'replacement pegs'? You know the three tiny stoppers that reside on the face (the small stoppers)- there's one missing.. I left the top open so that the other needles rest at "0"...
tkheaven is offline
Old 06-11-2013, 08:33 PM   #3
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
What I Drive: 03 CD Silver ZX5
Points 11,527, Level 70
Points: 11,527, Level: 70 Points: 11,527, Level: 70 Points: 11,527, Level: 70
Level Up 70% Completed
Forum Activity 2%
FF Reputation: 59 katiekay Excellent Standing Member
Buy-Sell-Trade Rating: (48)
I used a razorblade to clean off all the green residue. You want that plastic to be clear before applying a new face to it. As far as needlestops, I would go to a pick & pull and grab them off another cluster.
Here is what mine looks like:
Hatch Nation #8
September 2012 Ride of the Month
katiekay is offline
Old 06-12-2013, 11:27 AM   #4
tkheaven
tkheaven's Avatar
Fan#: 59098
Pyro, that looks great! I'm changing the face altogether & some was left over on the plastic (w/ the motors). I'm at the autoshop now. I kept teading that rubbing alcohol helps *fingers crossed*...
Are those Contour needles? I'm using those as well. Wondering if you sanded off (or however it's done) the white strip from the bottom? I'm noticing it's not as bright as I thought..
tkheaven is offline
Old 06-12-2013, 11:31 AM   #5
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
Yeah, that's what I meant. A lil rubbing alcohol and a razor blaze on the clear plastic will help! If your new face doesn't have some type of adhesive, make sure to put a lil spray adhesive on the back of the face(avoid spraying adhesive on where the numbers are!
Hatch Nation #8
katiekay is offline
Old 06-12-2013, 11:39 AM   #6
tkheaven
tkheaven's Avatar
Fan#: 59098
They're in there now. The new face has a white plastic backing but was recommended to not take it off. I will, however, apply a little adhesive around the corners before screwing the cluster back in to secure it in place.
The needles on your gauge: are those clear or with the white strip?
tkheaven is offline
Old 06-12-2013, 11:49 AM   #7
katiekay
ɔᴉʇɐuɐℲ snɔoℲ
katiekay's Avatar
Fan#: 42025
Forum Activity 2%
They are clear with the white strip on top, here's a daylight pic:
Hatch Nation #8
katiekay is offline
Old 06-12-2013, 11:51 AM   #8
tkheaven
tkheaven's Avatar
Fan#: 59098
Ok, I see.. I wanted to see how they msy differ from the one I have niw.
I'll try to post a pic once it's all done.
tkheaven is offline
