indexing and filing spark plugs - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-11-2013, 09:35 AM   #1
TCOC rel1
TCOC rel1's Avatar
Fan#: 105626
What I Drive: 2014 ST Ticket Red
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 0 TCOC rel1 Newbie
Back in the day, we used to "index" the spark plugs so that the opening would face down toward the piston so that as much of the spark as possible would ignite the A/F. We would also"file" the sides of the electrode so that, assumably , some of the spark would fire around the electrode.
Do you think this would be worth the effort on our FoFo's? Below is a link to an article if you need more info.
http://dodgeram.info/Engine-Gas/Spar...0_indexing.htm
*snorkel delete, K&N E-2993, 1 1/4" New Mission Mod* ~2.5" Custom exhaust 12226 MagnaFlow muffler~ ^AMSOIL^ #93 Octane# ^Injected Engineering tune^
@2nd car 10th Gen Ford Lightning 445 HP@
TCOC rel1 is offline
Old 06-11-2013, 10:36 AM   #2
Roadworthy
Fan#: 109039
What I Drive: 2012 SGM MK3 Titanium
FF Reputation: 1 Roadworthy Good Standing Member
Been there done that :P
Can't really index the plugs properly without inserts and an different plug length. I did file down my original plugs to be side firing and maybe it helped, but hard to tell. Seemed to fire about the same.
2012 SGM Ti DCT Stock and loving it
OEM multispoke 17" with stock rubber summer-X-ice 3's on stuck rims = awesomesauce
Roadworthy is offline
Old 06-11-2013, 10:39 AM   #3
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
Not sure if it would be worth it since I don't think we have a 'squish' area and the plugs go straight into the center of combustion chamber like a Hemi, did anyone index plugs on the 426 Hemi?
Now then a gap-less plug like BRISK LGS or BOSH +4 might do a little.
Seminoles is offline
Old 06-11-2013, 10:41 AM   #4
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
In the stratified fuel/air charge environment of a DI cylinder, it's not likely that indexing or profiling will help at all. And, obviously, you can't face the electrode toward the piston in a DOHC engine like this, since the plug is centered vertically at the top of the cylinder. I suppose you could try to index so the electrode faces the injector, but that's not likely to be worth the effort.
Hatch Nation #90
TboneZX3 is offline
Old 06-11-2013, 10:44 AM   #5
Roadworthy
Fan#: 109039
Yeah, the gains for indexing on this type of engine might be null. I bought some new stock plugs but still have my cut ones I can take pics of.
Old 06-11-2013, 11:52 AM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,554, Level 100
Points: 52,554, Level: 100 Points: 52,554, Level: 100 Points: 52,554, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (28)
The reason for indexing Spk Plugs is to locate the wire of the plug so the dome on the piston would not hit it , then some one got the idea this should be done on all engines , like most things people put to much thought into turns out the only reason to index a plug is to keep it away from dome pistons
If you want to expose more of the kernal (which is the theory behind indexing) then us the Autolite AR series plugs these give you the fastest kernel growth and exposure then any other plugs
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
