Need Help! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-11-2013, 07:45 AM   #1
xFocusingx
Fan#: 99051
What I Drive: 2005 Ford Focus
FF Reputation: 1 xFocusingx Good Standing Member
Need Help!
2005 ford focus zx4
105k
We are going on a 350 mile road trip in 2 days. A week ago I did battery/alternator/starter test, to make sure everything was good. Alternator was putting out almost 14 volts, battery was good.
We are in the northeast,pa getting hammered by rain.Two nights ago, the abs light came on for a few moments, and the battery light came on for less than a mile (gf said) and it went off. Nothing rest of way home.
so she drove it to work last night, was fine. On the way home the CEL came on. So I drove it to work today (I work at Advance) light was on, on the way over. By the time I got to work, it went out. Now the light is not flashing/blinking, but it is flickering on and off. It will be on for a minute, then it dims out, then back, dims again. Barely can tell it is on. Only other light on is check gas cap, which comes and goes.
I pulled live data, car was at 13.8 v, its getting signals from all of the O2 sensors.I turned it off, in hoping if I let the engine cool down, and drive it again it may come back on.
Or, maybe the rain, and or puddles wet a electrical connector and is causing this?
Over the last 6 months, I did new plugs/coil on boots, new brakes all around and a new muffler. Besides that, not much else has been done. Any ideas?
TIA
xFocusingx is offline
Old 06-11-2013, 08:43 AM   #2
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Level Up 50% Completed
Forum Activity 7%
FF Reputation: 8 Milton Good Standing Member
Start by checking all electrical connections and grounds. Special attention to both ends of all wires connecting to battery and alternator.
You should be able to pull the battery and test it.
Milton is offline
Old 06-11-2013, 09:39 AM   #3
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,391, Level 65
Points: 9,391, Level: 65 Points: 9,391, Level: 65 Points: 9,391, Level: 65
Level Up 14% Completed
Forum Activity 5%
I second checking all electrical connections and grounds. Sounds to me like you have something going on there.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is online now
Old 06-11-2013, 08:22 PM   #4
pasta
Fan#: 62350
What I Drive: 2003 eap svt
Points 10,085, Level 67
Points: 10,085, Level: 67 Points: 10,085, Level: 67 Points: 10,085, Level: 67
Level Up 9% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 5 pasta Good Standing Member
Buy-Sell-Trade Rating: (41)
Check voltage with car running at the battery and check with car not running
pasta is online now
Old 06-12-2013, 08:48 PM   #5
xFocusingx
Fan#: 99051
Ok, so I spent about 45 minutes trying to find something wrong, trying to make the light come back on, and had no luck.
I tested the battery/alternator. Car off, battery was 600 CCA, 12.6 volts. Tested the alternator, with no load, car was putting out 13.8 volts. With high beams on, ac on, radio on, alternator was putting out 13.5 volts.
I then used one of the check engine scanners than can read live data, drove the car with it plugged in for about 15 miles. With high beams on, radio, ac etc, vehicle power never went below 13.1 volts, and when it dip that low, only for a second or two. I had it up to 60+ mpg, car was putting out 13.5v. Its getting signals from both 02 sensors, car drives fine, no weird noises, nothing.
So when I drove it to work (morning before tests) only the CEL flickered on and off, not flashing, and it wasn't even on solid enough for me to consider it on. 5 minutes from my job, it went completely off. Tested it, no engine codes. Light did not come on rest of day. This morning I turned it on, light flickered for maybe 2 minutes, went off, fine rest of day
My only guess, is maybe one of the heater in the 02 sensors is going bad (car has 105k never been replaced) which is why the light only comes on for the first few minutes car is running (after being off all night).
Old 06-14-2013, 10:30 AM   #6
xFocusingx
Fan#: 99051
So drove it for the trip, 360 miles.
The CEL flickered on for about 5 minutes off and on. Then it did not appear for even a second the rest of the 350 miles
Old 07-06-2013, 11:36 AM   #7
xFocusingx
Fan#: 99051
So we drove 1100 miles the whole trip, and nothing.
Since we have been back, the CEL flickered on, I drove it to work, while it was still flickering, I checked the CEL and there were no codes. So over the last 2 days, the battery light has come on, but only at night. First night it came on for a few moments, flickered and went off. Last night, it stayed on for about 20 minutes. The ABS light was also on.
So I thought it had something to do with the headlights on, but when we drove the car during the day with the A/C on max, it drove fine, no lights.
Could the alternator be intermittently not charging? I am lost. Am going to take a look at it tomorrow when I am off of work, if I can't find anything may have to take it to a shop.
I have tested the alternator before, and it never put out lower than 12.9-13.0v with a load. Any ideas? Guesses? All the wires and grounds look good, battery cables are clean and tight
Old 07-06-2013, 10:10 PM   #8
xFocusingx
Fan#: 99051
The odds?
I work at a auto parts store, and someone came in, with a 2004 Focus, identical problem I am having, it happened at the identical time, stopped and started at same time when it got hot. I am lost
Old 07-06-2013, 11:12 PM   #9
xFocusingx
Fan#: 99051
anyone hear this before? Gonna give it a try tomorrow
http://www.autoserviceprofessional.c...d-Focus?Page=1
