Fswerks Turbo Kit - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-11-2013, 04:09 AM   #1
Cruise
Cruise's Avatar
Fan#: 100721
What I Drive: 2008 Vermillion ClearCoat, SE
Points 376, Level 7
Points: 376, Level: 7 Points: 376, Level: 7 Points: 376, Level: 7
Level Up 52% Completed
FF Reputation: 1 Cruise Good Standing Member
Fswerks Turbo Kit
I've looked around for answers but could find none, so I'll just ask you guys. You seem like a knowledgeable lot.
I'm planning on purchasing an turbo kit from Fswerks and had some questions:
First, what is the difference between the Garrett GT28R, GT28RS, & GT2871R turbos. I checked their site and couldn't find either of these three turbos to compare.
Second, how does a turboed setup perform with the stock intake manifold, I do plan to get a Cosworth manifold later but was wondering how it would perform until I get to that point. ( Also, I know that manifold requires to tune to work properly. How will the car perform without one, and where can I get one [I heard that Fswerks makes custom tunes but I haven't seen it advertised anywhere])
Third, during the installation of turbos I hear you have to drill through the sump to run oil lines. I was wondering how easy this is or if the duratec comes with holes in it from the manufacture that you can use. (I know some engines have them).
Thanks for any help, and if any of these questions will be answered by the literature that comes with the kit feel free to refrain from answering those.
Cruise is offline
Old 06-11-2013, 07:55 AM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
The different turbos support different maximum HP goals, in increasing order. 28R is around 310hp max, 28RS is around 350HP, and the 2871 is around 400HP. Of couse, all things held consistent, they all will have different sweet spots that they operate at.
If you want the details:
GT2871R:
Turbine
-Wheel: 53.85mm w/ 76 trim
-Housing: .86 or .64 ar
Compressor
-Wheel: 71mm w/ 56 trim
-Housing: .60 ar
GT2871R Compressor Map
GT28RS:
Turbine
-Housing: .64 or .86 ar
Compressor
-Wheel: 60mm w/ 62 trim
-Housing: .60 ar
GT28RS Compressor Map
GT28R:
Turbine
-Wheel: 53mm w/ 62 trim
-Housing: .64 ar
Compressor
-Wheel: 60mm w/ 60 trim
-Housing: .60 ar
GT28R Compressor Map
Regarding oiling, there is no easy tap point for a return. You can get a feed by 'T'ing from the oil pressure sensor, but the return will have to be drilled and tapped.
Egz is offline
Old 06-11-2013, 09:29 AM   #3
AllCarFan
Fan#: 102583
What I Drive: 2005 Saleen Sonic Blue S121
FF Reputation: 1 AllCarFan Good Standing Member
I am pretty sure with the FSWERKs kit, they supply an oil pan plug that already has a tap on it...no drilling required...just an oil change.
The FSWERKs kit, if bought new, comes with tuning and a tuner. You will need a wideband to do it correctly ($189.)
You should be able to make nearly 240whp with the stock manifold, maybe more. There are dynosheets on the FSWERKS website. If you go from a stock manifold to a cosworth, without a tune, you will throw a code. Its not really an issue, but it is a code. If you have a wideband installed, you can see if the new manifold effects your AFR. To be safe, you would need a retune. I dont know if FSWERKS provides tune updates for modifications after the install and tuning of their kit. That is something you will need to discuss with Randy.
AllCarFan is offline
Old 06-11-2013, 12:24 PM   #4
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,142, Level 74
Points: 13,142, Level: 74 Points: 13,142, Level: 74 Points: 13,142, Level: 74
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 30%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "General Forced Induction".
zetecDon is offline
Old 06-11-2013, 09:11 PM   #5
Cruise
Cruise's Avatar
Fan#: 100721
Points 376, Level 7
Excuse my naivete but. what's a wideband?
Cruise is offline
Old 06-11-2013, 09:44 PM   #6
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
u got some learnin to do
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 06-12-2013, 12:14 PM   #7
RPMisChris
RPMisChris's Avatar
Fan#: 76276
What I Drive: 07 svt 2.3 swap thing
Points 5,336, Level 46
Points: 5,336, Level: 46 Points: 5,336, Level: 46 Points: 5,336, Level: 46
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
FF Reputation: 1 RPMisChris Good Standing Member
Buy-Sell-Trade Rating: (16)
I remember when I first asked that question... many years ago.
RPMisChris is offline
Old 06-12-2013, 12:23 PM   #8
AllCarFan
Fan#: 102583
Why cant people answer questions without being smartasses?
A wideband is a guage/wiring that will replace one of your O2 sensors. The guage will give you an accurate Air/Fuel Ratio for your engine....damn near a necessity for tuning properly. You will be able to buy a firewire, splice it, and datalog with your Laptop and handheld tuner.
Old 06-12-2013, 12:26 PM   #9
RPMisChris
RPMisChris's Avatar
Fan#: 76276
Dude I am not trying to be a smart ass. Its a learning process that we all go through. I was just reminescing a little.
Old 06-13-2013, 12:09 AM   #10
Cruise
Cruise's Avatar
Fan#: 100721
Points 376, Level 7
Thank you...
Pretty sure he wasn't talking about you
Cruise is offline
