BSD gains and potential problems? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-10-2013, 10:43 PM   #1
drummer829
Fan#: 71497
What I Drive: 2005 liq grey ST
FF Reputation: 1 drummer829 Good Standing Member
I saw a blog from a couple years back about people not having any problems with the balance shaft delete, but was just wondering if people have been running the BSD without any problems.
Also, I've heard a wide range of people claiming what the gains are. I've heard from a small change in throttle response to 7 whp gain. Can someone with first hand experience tell me what their gains were
drummer829 is offline
Old 06-10-2013, 11:50 PM   #2
msperber
Fan#: 80053
What I Drive: 05 ST Focus 2014 SE Champion
Points 301, Level 6
Points: 301, Level: 6 Points: 301, Level: 6 Points: 301, Level: 6
Level Up 2% Completed
FF Reputation: 3 msperber Good Standing Member
We did the Bds mod with the intention of being able to place a windage tray in the oil pan. We have notice a slight vibration at idle, but after that no issue at all. My car is a dedicated race car, solid motor mounts, super high rate springs, and full race suspension struts and shocks. Prior dyno results and post results were more influenced by the tune than the Bds upgrade. Is it worth it, for our application it was a must, for a street car with small mods, if ya like working on your car go for it.
msperber is offline
Old 06-11-2013, 08:00 AM   #3
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Its an easy and cheap way to remove 20lbs from the front of the engine. Been balance shaft free for almost a decade, and love it.
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 06-11-2013, 03:24 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,337, Level 75
Points: 13,337, Level: 75 Points: 13,337, Level: 75 Points: 13,337, Level: 75
Level Up 22% Completed
Forum Activity 99%
Same here, dumping that lump of iron was a real improvement - weight off the nose & the engine spins up easier (noticeably quicker change in revs).
Vibration change on stock mounts virtually unnoticeable - from 0 to "I think I can feel it running" at times....
Extra quart of oil capacity doesn't hurt either.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-11-2013, 06:06 PM   #5
drummer829
Fan#: 71497
So the added vibration wasn't a big problem?
Old 06-11-2013, 10:26 PM   #6
jetrinka
jetrinka's Avatar
Fan#: 45622
What I Drive: 88 5-speed XR4TI
FF Reputation: 180 jetrinka Excellent Standing Member jetrinka Excellent Standing Member
Buy-Sell-Trade Rating: (6)
With stock mounts you probably won't notice a big difference. Perhaps a little bit of vibration but nothing crazy. That being said, this is also a subjective subject. If you put polyurethane mounts in you will feel it even more. I had the BSD in my ST for years with the rear mount and trans mount being polyurethane and loved it. In my experience putting a polyurethane passenger mount in made the vibrations really bad but with only the others it was fine.
Ability to run a baffle, extra quart of oil, faster spin up, minimal vibrations, all sounds like a win win.
jetrinka is offline
Old 06-11-2013, 10:41 PM   #7
drummer829
Fan#: 71497
Yea, it all sounds like an awesome piece for $40. Also would it hurt at all if you didn't put the full 6 quarts in? Like say you kept it at 5
Old 06-11-2013, 11:33 PM   #8
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
All the above^^^^^^^^^^^^^^^^ win, win, win. I've had no issues w/ a bsd plug & a windage tray. I just installed a vf engineering trans mount w/ no vibe issues. Your removing about 18 lbs of static weight & don't forget the rotating weight too. Your motor will spin up quicker & hold more oil & you'll lose weight too. Its one of the best cheapest mods you can do.
felixthecat is online now
Old 06-12-2013, 12:15 PM   #9
drummer829
Fan#: 71497
Do I have to get a new oil pan or something?
Old 06-12-2013, 03:07 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
No new oil pan required, and that extra quart is needed to get the level up to normal without that large assembly taking up space in the pan.
The BSD delete kit by itself just blocks off the oil passage for the balance shafts. Just pulling the assembly would leave an open oil passage right to the pan & you'd lose oil pressure.
"Rubber Side Down"
