Broken Crankshaft - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-10-2013, 01:41 PM   #1
Skernan
Fan#: 107678
What I Drive: 2001 SE
FF Reputation: 1 Skernan Good Standing Member
Broken Crankshaft
I have a 2001 SE that (to make a long story short) was left in my driveway with a broken engine. There have been 2 dropped seat episodes and I thought this was a 3rd. I pulled the engine and found the crankshaft in 2 pieces. Split at the counterweight at cylinder #4.
Any thoughts out there about what might have caused this?Name:  ImageUploadedByTapatalk1370886080.605369.jpg
Skernan is offline
Old 06-10-2013, 08:16 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,775, Level 73
Points: 12,775, Level: 73 Points: 12,775, Level: 73 Points: 12,775, Level: 73
Level Up 82% Completed
Forum Activity 99%
Dropped seat episodes that are bad enough to slam the piston stress/bend rods on occasion, and that certainly stresses the crank....
One guess...
Water ingestion? For another....
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-10-2013, 08:24 PM   #3
Skernan
Fan#: 107678
water from where
Skernan is offline
Old 06-11-2013, 11:59 AM   #4
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
If the engine has experienced 2 dropped valve seats, I would point to that as the most likely culprit. That may have damaged the integrity of the crankshaft, which then broke with further wear?
but as sailor pointed out, that is not the only possibility.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 06-11-2013, 08:37 PM   #5
Skernan
Fan#: 107678
ok, thanks. I am shopping for a new crank now.
Skernan is offline
Old 06-12-2013, 02:58 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Can't see the picture quite clearly enough, but at a second look it seems to have cracked previously then finally broke. (dark section vs. bright section at the break)
The odd possibility of water of water ingestion would be from driving through a deep puddle. Happens occasionally even with stock air intakes.
The double drop valve seat problem is still the best guess IMHO.
Luck gettin' it back together, rebuilt head with "staked" seats or a new replacement head this time...
Cheers!
"Rubber Side Down"
Old 06-12-2013, 08:08 PM   #7
Skernan
Fan#: 107678
Thanks Sailor.
After the last dropped seat episode I had the head reworked at a local shop but I didn't specifically talk to them or check into the seat size/type. I just gave the shop what came in the seal/gasket kit and they pressed them in without questions. This has me a little concerned that the seats aren't the best replacement and I am open to having a third episode.
Adding to this quagmire is the fact that I see a little damage on one of the piston heads like something foreign got into the piston. It could be me over-worrying about it or maybe the guy who fixed this last time didn't clean out the intake and EGR good enough ... or I could have a third seat episode in the making. Would you all fix the valve seats once and for all?
Also, any good tricks out there to make sure the little spring in the main seal stays where it is supposed to when the new crank goes back in? I hear they are a little tricky and the guy who did this last time messed up and i had a decent size lead at the rear seal.
Skernan is offline
Old 06-23-2013, 07:11 PM   #8
Skernan
Fan#: 107678
He new crankshaft from Rockauto came in and I think it's not a match. Take a look at these pics. The end of the shafts are different and the part numbers are a little different (the old one has two additional letters at the front). Thoughts.
Size:  44.0 KBName:  ImageUploadedByTapatalk1372029125.233410.jpg
Skernan is offline
Old 06-27-2013, 05:37 PM   #9
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
So, what's different about the ends, other than the key not in one?
amc49 is offline
Old 06-29-2013, 06:35 PM   #10
Skernan
Fan#: 107678
Just the key not in it ... Showing my newbie-ness. I talked the the vendors and confirmed the casting number. I couldn't find the clearance spec for the journals. Does anyone know what it is?
Skernan is offline
