studs and spacers questions? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-10-2013, 12:47 PM   #1
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
What I Drive: 01 cd silver 3 door ztec
FF Reputation: 2 sgtsmasher Good Standing Member
MK1
standard studs now
flared fenders all around to fit 9" wide mustang wheels (then)
have 7" wide wheels (now)
was thinking 5mm spacers in front and 10mm in the rear
but! i was wondering with that much offset with spacers:
1: is it going to look off when starring at the car?
2: what length studs am i going to need for each size of spacer?
3: with adding spacers and new studs is it going to make it so the wheel bearings are going to wear out faster?
will post picture of car in a few!
Hatch Nation #72
Call Me BRANDO COMMANDO
sgtsmasher is offline
Old 06-10-2013, 12:52 PM   #2
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
Car is also lowered but that shouldnt matter really
Sent From Your Moms Room
Hatch Nation #72
Old 06-11-2013, 09:57 AM   #3
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,532, Level 47
Points: 5,532, Level: 47 Points: 5,532, Level: 47 Points: 5,532, Level: 47
Level Up 91% Completed
Forum Activity 10%
FF Reputation: 35 thenorm Great Standing Member
1. it'll look fine. there is only 5mm difference between the two, noone can notice that difference.
2. 5mm spacer doesnt genrally need new studs. for the 10mm, im not sure what size you need.
3. your bearings will be fine. your not changing the offset much. its no worse off then when you had those mustang wheels on
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 06-11-2013, 12:28 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,776, Level 73
Points: 12,776, Level: 73 Points: 12,776, Level: 73 Points: 12,776, Level: 73
Level Up 82% Completed
Forum Activity 99%
Prefer wheels with stock offset myself, but as thenorm said, it's not as bad as those Mustang wheels...
FWIW, the rear is about 4mm narrower per side than the front - so the extra 5mm there would make them even at the center. Bit more camber at the rear is what brings the tread out to "even" in the normal fitment. As mentioned, the 5mm wouldn't really be noticeable.
luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-11-2013, 03:32 PM   #5
sgtsmasher
need new focus?!
sgtsmasher's Avatar
Fan#: 65000
ok...ill buy the spacers and try and see if the stock studs are to short or ok to run...i should be all set.
Hatch Nation #72
