Tsb 13-6-10 bang noise heard and/or bump felt from front of vehicle during a quick 1-2 and/or 2-3 shift - under moderate to aggressive acceleration - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST EcoBoost Performance (2013-Current)
Focus ST EcoBoost Performance (2013-Current) The place to chat about the 2.0L EcoBoost engine performance, tuning and exhaust related upgrades.
Old 06-10-2013, 09:04 AM   #1
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,066, Level 67
Points: 10,066, Level: 67 Points: 10,066, Level: 67 Points: 10,066, Level: 67
Level Up 4% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
TSB 13-6-10
Looking at the messages, it is pretty involved. Looking at the parts list for the TSB, it is several mounts and such that will need replacement. See below
Printable View (2357 KB)
TSB
13-6-10 BANG NOISE HEARD AND/OR BUMP FELT FROM FRONT OF VEHICLE DURING A QUICK 1-2 AND/OR 2-3 SHIFT - UNDER MODERATE TO AGGRESSIVE ACCELERATION
Publication Date: June 10, 2013
FORD: 2013 Focus
ISSUE:
Some 2013 Focus ST vehicles may exhibit a bang noise and/or bump felt from front of vehicle during a quick 1-2 and/or 2-3 shift under moderate to aggressive acceleration.
ACTION:
Perform the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Raise the vehicle on a hoist. Refer to Workshop Manual (WSM), Section 100-02.
Remove the lower air deflector by removing the three (3) fasteners. (Figure 1)
Remove the engine compartment splash shield by removing the eight (8) fasteners. (Figure 1)
Lower the vehicle.
Remove battery and battery tray. Refer to WSM, Section 414-01.
Position hydraulic floor jack with a wood block under transmission and raise only enough to support weight of transmission.
Do not attempt to lift the transmission or damage will occur.
Figure 1 - Article 13-6-10
Remove battery tray reinforcement by removing the four (4) fasteners. (Figure 2)
Figure 2 - Article 13-6-10
Remove and discard the center fastener securing the transmission support insulator and remove the insulator.
Install revised service transmission support insulator and torque new center fastener to 148 N-m (109 lb-ft).
Replace the clutch slave cylinder hydraulic tube with revised service part. (Figure 3 - Item 12)
Bleed the clutch system. Refer to WSM, Section 308-02, general procedures, 6 speed manual transmissions.
Remove floor jack.
Install battery tray reinforcement with the four (4) fasteners and torque to 48 N-m (35 lb-ft). (Figure 2)
Install battery and battery tray, refer to WSM, Section 414-01.
Replace engine mount with revised service part. Refer to WSM, Section 303-01B
If the three (3) engine mount studs loosen during engine mount removal, torque the three (3) engine mount studs to 17.5 N-m (13 lb-ft)
Figure 3 - Article 13-6-10
Replace roll restrictor with revised service part. Refer to WSM, Section 308-03.
When installing the engine compartment splash shield and lower air deflector, do not over tighten the fasteners or threads may be damaged.
PART NUMBER PART NAME CM5Z-6068-A Roll Restrictor
DV6Z-7A512-B Clutch Line PTL
DV6Z-6038-B Engine Mount
DV6Z-6068-A Transmission Mount
W500361-S442 Bolt - Transmission Mount
W716238-S442 Bolt - Roll Restrictor
PM-20 Motorcraft® DOT 4 LV High Performance Motor Vehicle Brake Fluid
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
130610A 2013 Focus ST 2.0L GTDI: Replace Mounts And Clutch Hydraulic Cylinder Tube Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.8 Hrs
DEALER CODING
BASIC PART NO. CONDITION CODE
6068 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2013 Ford Motor Company
suss6052 is online now
Old 06-10-2013, 02:21 PM   #2
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2014 Mazda CX-5
Points 17,017, Level 83
Points: 17,017, Level: 83 Points: 17,017, Level: 83 Points: 17,017, Level: 83
Level Up 34% Completed
Forum Activity 2%
FF Reputation: 31 misfire Great Standing Member
Buy-Sell-Trade Rating: (13)
MERGED: Multiple threads
Will aka Misfire
2003 LX "traded in"/2010 SES "traded in"/2012 SEL Hatch "current"
misfire is offline
Old 06-10-2013, 03:07 PM   #3
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 21%
Sorry to try and help people by putting it where it was relevant.
The TSB does seem to be much more extensive than just replacing the rear mount with the electric one but also to change the transmission and passenger side engine mounts as well.
Old 06-10-2013, 04:27 PM   #4
misfire
Moderator
misfire's Avatar
Fan#: 31379
Forum Activity 2%
I've already had 2 ST owners call to order parts for theirs
Will aka Misfire
misfire is offline
Old 06-10-2013, 04:32 PM   #5
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 21%
I requested the parts be ordered by the dealer who looked at the car last week, should have a service appointment Wednesday if they have the parts to finish the car.
Kind of nervous about it, but hopefully Ford knew what it's doing to prevent the issue from reoccuring.
I will be happy if it does not allow the mount to smash into the subframe under all conditions.
Old 06-11-2013, 04:22 PM   #6
yellowv
Fan#: 115660
What I Drive: 2013 Ingot Silver ST2
FF Reputation: 1 yellowv Good Standing Member
Got all my parts ordered this morning. From what I hear the tranny mount is not yet available.
yellowv is offline
Old 06-11-2013, 06:41 PM   #7
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 21%
Yeah the transmission mount is seemingly MIA, everything else is either at the dealer or enroute for tomorrow. Unfortunately that means the car won't be fixed yet.
I guess the only actual new part here is the transmission mount otherwise they should have had sufficient stock of parts available.
The roll restrictor is the E-Focus mount, and I'm not exactly sure where the PSMM is coming from or if it's just a new mount the same as the old one but not damaged by the rmm allowing the engine to smack back and forwards.
Old 06-13-2013, 09:26 AM   #8
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
i knwo its a car under warranty, but first mod with these would be poly mounts. solves any and all possible bumping and banging. and can be done in teh driveway...
just saying
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
Old 06-13-2013, 09:45 AM   #9
suss6052
suss6052's Avatar
Fan#: 95752
Forum Activity 21%
Originally Posted by Paladin View Post
i know its a car under warranty, but first mod with these would be poly mounts. solves any and all possible bumping and banging. and can be done in teh driveway...
just saying
Precisely because it's under warranty, and for anyone wanting to have the mounts changed yet stay in stock condition for either autocross, or other reasons it would be best to give the manufacturer a chance to fix it first.
There are after market rear roll restrictors and passenger side engine mounts, but nothing at all for the transmission mount.
If Ford has fixed the issue without increasing NVH too much this would be desireable rather than the harsh vibrations of some of the higher durometer rear motor mounts (roll restrictors) especially combined with the Side mount.
Not everyone wants to tear into a brand new car and toss the warranty aside on those components or their related subsystems.
Now on a 6+ year old beater sure go right ahead and tear into it, but it's a brand new car for pete's sake.
Old 06-13-2013, 06:58 PM   #10
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
Forum Activity 3%
polyurethane trans mount. people make it. poly drivers and passenger side engine mounts. no need for roll restrictor if it doesn't move.
ford had the idiocy to slap a standard ford focus trans mount in there. they didnt think to put something stiffer in there to compete with the added power.
also the vibes are hardly noticable after the mounts break in. only at idle can you feel it.
Paladin is offline
