Car lock cylinder cleaning - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-14-2013, 01:42 PM   #21
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
one last time:
Just replace the lock cylinder, it is giving you lots of warning of it's upcoming complete failure.
elsolo is offline
Old 06-14-2013, 02:03 PM   #22
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Or radius the edge of the key sticking out of cylinder that faces down, the radius then allows it to bump up and over the groove edge.
Whatever you do don't throw older non-working key away, it has a chip in it that can be removed that matches your PCM. Under the small rectangle on one side of the key's plastic head.
amc49 is offline
Old 06-14-2013, 07:13 PM   #23
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,363, Level 75
Points: 13,363, Level: 75 Points: 13,363, Level: 75 Points: 13,363, Level: 75
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 99%
Originally Posted by elsolo View Post
one last time:
This
Once you told us the new key worked right initially, then not, it isn't a key issue!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 06-15-2013, 12:17 PM   #24
simonfocus
Fan#: 107906
What I Drive: Focus
Points 598, Level 11
Points: 598, Level: 11 Points: 598, Level: 11 Points: 598, Level: 11
Level Up 96% Completed
FF Reputation: 1 simonfocus Good Standing Member
Sailor,
that is also my concern to find out what is the cause the cylinder or the key.
Yes the key initiated in the first time without a problem, now I can hardly turn it around in the cylinder, where as the older one works fine. It can open the doors and moves smooth in the locks.
I just hope a new cylinder will solve my problem, I am off to order one.
simonfocus is offline
Old 06-15-2013, 09:02 PM   #25
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Issues with Ign. lock cylinders were common on early model Focus' over here, with an updated replacement as the repair. Early symptoms were intermittent difficulty in operation - that's why the "guessing" leans that way.
"Stiff" replacement keys (from imperfect copy) seldom get lucky & work smoothly even once. They start out stiff and often get a bit better with use.
Replacement cyl. matched to your keys sounds like a good idea, when the troublesome ones gave out completely an easy swap was no longer possible. "drilling out" a lock, let alone getting stranded, is something to avoid!
Cheers!
"Rubber Side Down"
sailor is offline
Old 06-16-2013, 08:10 AM   #26
simonfocus
Fan#: 107906
What I Drive: Focus
Do you mean that not all cylinders will match any keys? If so how can I find out what type will work with my existing key?
Old 06-16-2013, 04:08 PM   #27
elsolo
elsolo's Avatar
Fan#: 96835
It will work with your keys ONCE you put the right tabs in the cylinder to match your current keys.
Or just put not tabs in it (leave it un-keyed) and any key will turn the cylinder, but only one with the right PATS microchip will start it.
elsolo is offline
Old 06-20-2013, 09:30 PM   #28
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
I finally got around to preemptively replacing my new ignition cylinder, as I will be taking a couple of road trips this summer and don't want to encounter Murphy's Law on some remote country highway.
To recap the cylinder differences, here's a before-and-after pic:
The first step is to remove the dashboard kickplate, and then remove the lower shroud from the steering column. That provides full access to the PATS, which is straightforward to remove:
(The PATS and shroud utilize T20 Torx screws and the kickplate utilizes bolts.)
After the PATS is removed, the old cylinder can be easily slid out by inserting the key and turning to the ACC position, and then applying pressure to the bevelled retainer pin using a slender screwdriver or punch:
Installation of the new cylinder is the reverse procedure (although obviously no need to fiddle with the retainer pin). It bears repeating that the battery should be disconnected prior to starting this job.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
