Water staying in Door Sill - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-08-2013, 11:02 PM   #1
Vanquished
Vanquished's Avatar
Fan#: 114099
What I Drive: 2013 Dodge Charger R/T Plus
Points 865, Level 15
Points: 865, Level: 15 Points: 865, Level: 15 Points: 865, Level: 15
Level Up 65% Completed
FF Reputation: 1 Vanquished Good Standing Member
Hey Everyone,
Last night we had a crazy rain storm here in MA and today I went out to my car and just happened to open a rear door. (I usually drive by myself so I only open the drivers door and trunk). When I opened the first rear door a bunch of water came gushing out (it wasn't in the cabin though), other rear door same story, I bet it would have been the case for the front doors as well but I didn't notice it because I was driving it last night and had a passenger in the front seat so we had opened/closed our doors multiple times during the storm.
Has anyone else noticed this on their MK3 Focus? It wouldn't be a real issue but I worry about rust with standing water stuck in the door sills like this... I should also note I did drive the car after the rain and before I opened the rear doors so it wasn't just sitting there.
Anybody had this issue/have a solution? I mean we did have epic amounts of rain during the storm but it didn't seem like the water was gonna come out had I not opened the doors. I also make really careful to avoid large puddles since I don't want to get water into the intake (super cautious I know).
Thanks!
-Vanq
Vanquished is offline
Old 06-08-2013, 11:06 PM   #2
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
There's been discussion about this issue in the past. I don't have the issue, but I believe that some folks found that water was leaking in somewhere at the seal at the top of the rear door frame. Since the doors have multiple seals (on each side of the sill), the water gets between them and doesn't have anywhere to go once it gets in there.
Hatch Nation #90
TboneZX3 is offline
Old 06-08-2013, 11:11 PM   #3
Vanquished
Vanquished's Avatar
Fan#: 114099
Did ford come up with a fix? It seems like they really wanted to keep the water out with the outer seal but it's having a negative effect in this case...
Old 06-08-2013, 11:44 PM   #4
Some Guy From NY
Some Guy From NY's Avatar
Fan#: 101517
What I Drive: 2012 SGM Focus SEL sedan DCT
FF Reputation: 3 Some Guy From NY Good Standing Member
Same issue here especially after the drenching rain we had last night. I have always had this problem but it was usually a pretty insignificant amount of water from the rear doors, maybe a spoonful or 2. After the rain yesterday though an absolute flood of water poured out, but it was contained to the door sill.
Very annoying.
Mods: Drop in K&N filter, Steeda RSB, MS3 RMM, Remote start, Llumar tint, Ti engine cover, Husky floor mats, OEM splash guards
Some Guy From NY is offline
Old 06-09-2013, 12:11 AM   #5
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Not as far as I know. I don't believe it affects all cars--my car has been in some deluges and it's never happened to me. I wouldn't look at it as a problem of sealing the water in though, rather, keeping it out. IMO, water shouldn't be getting in there in the first place.
Multiple seals like most (all?) cars have today are not just to reduce water intrusion, but also to reduce noise entering the cabin.
Hatch Nation #90
TboneZX3 is offline
Old 06-09-2013, 11:12 AM   #6
Vanquished
Vanquished's Avatar
Fan#: 114099
Yea I'm sure I should. I looked at the seals around the door and I wasn't able to find any breaks. Not wanting to tug too hard on the seal I did gently pull on it in most places to see if it was secured to the car properly, as far as I could tell it is...
I'm sure most cars do have double seals now, Maybe even my montero did but if so it was located closer on the door to the other seal because I always had water in the door sills after washing the car (but it would dry out on its own).
Old 06-09-2013, 12:23 PM   #7
scada
Fan#: 107778
What I Drive: 2013, Silver, Focus S
Points 310, Level 6
Points: 310, Level: 6 Points: 310, Level: 6 Points: 310, Level: 6
Level Up 20% Completed
FF Reputation: 1 scada Good Standing Member
I have the same problem on the drivers side rear door. Doesn't go into the cabin. I just make sure to open the rear door after each rain event.
scada is offline
Old 06-09-2013, 04:07 PM   #8
knapkin
Fan#: 107064
What I Drive: 2013 Performance Blue SE Focus
FF Reputation: 1 knapkin Good Standing Member
Same issue on both drivers and passenger rear doors. Is this something I should be going to the dealership for?
knapkin is offline
Old 06-09-2013, 04:41 PM   #9
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
I have it most on the front passenger door.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 06-09-2013, 10:50 PM   #10
bassmobile
bassmobile's Avatar
Fan#: 95742
What I Drive: 2012 Yellow Blaze Titanium Focus
FF Reputation: 2 bassmobile Good Standing Member
I've had that issue since day one on the rear doors. But nothing is getting into the cabin, and we get some mega rain here in Florida!
bassmobile is offline
