SVTFocus Noob's TurboBuild - Page 9 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-07-2013, 09:18 PM   #81
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Here's how you make a tester go to Home Depot and get a sized coupler to your inlet of turbo the. Buy a PVC stopper to plug the other side then buy a compressor air fitting and drill a hole in the stopper to screw the fitting in then epoxy glue it for secure air leaks hook that up to your inlet hook other side to a compressor an get your soapy water squirt bottle ready
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 09-07-2013, 11:08 PM   #82
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Proud of you my son!!
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 09-07-2013, 11:10 PM   #83
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
lol thanks italo, it helps me well
FF MODERATOR
RIFF CREW
Old 09-09-2013, 01:38 PM   #84
SVTFocus noob
Fan#: 95927
What I Drive: 2002 Red Focus SVT
FF Reputation: 1 SVTFocus noob Good Standing Member
Okay for the tester whats a safe psi setting for compressor? About to go to Home Depot now to get what I need to make it.
Jake
SVTFocus noob is offline
Old 09-09-2013, 01:55 PM   #85
Mother Focus
Fan#: 73292
3-4psi will do, I use a tire tube, cut the piece that has the valve in it to fill it and clamp it to the turbo.
PTE 6262CEA
Old 09-09-2013, 06:17 PM   #86
SVTFocus noob
Fan#: 95927
Now this is done with the engine off correct? I've got everything listed and got a adjustable gauge to control psi coming off the compressor to 4psi.
Hows this looking so far? Still have to apply adhesive glue to it.
Old 09-09-2013, 09:42 PM   #87
SVTFocus noob
Fan#: 95927
what the name to vac line that runs to back of intake manifold? when using tester found it and it was undone started car up still was reading 17, pulled it out car tried to die (obviously) then plugged in real quick to save idle and wiggled it around while doing so cause the vac reading to flex from 12 to 18" of merc. So guessing the seal on it is bad. Its a male line and fits into a female fitting vs the common female line to male fitting. I can get a pic if needed.
Jake
nvm found it on google:
http://www.focusfanatics.com/forum/showthread.php?t=322876
see my line is missing that red rubber seal.
Jake
Last edited by SVTFocus noob; 09-09-2013 at 09:46 PM. Reason: answered my question
Old 09-10-2013, 02:09 AM   #88
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
your tester looks good cep t the fitting I wuldve used would've been one that snaps into a compressor line
FF MODERATOR
RIFF CREW
Old 09-10-2013, 02:21 PM   #89
SVTFocus noob
Fan#: 95927
I get what you mean I used the same kind of fitting on a "gun" with a gauge then used a extra vac line to connect tester to compressor gun. I'm still reading 17 where as when we first boosted car read 21. I've gone over every connection only thing it can be is that the seal is missing and I can't find one anywhere online. Any thoughts? I'm going to call local junk yard to see if I can get one of a dead foci.
Jake
Old 11-26-2013, 09:59 PM   #90
SVTsteele
SVTsteele's Avatar
Fan#: 115953
What I Drive: 2004 EAP Screaming Yellow SVT
Points 230, Level 4
Points: 230, Level: 4 Points: 230, Level: 4 Points: 230, Level: 4
Level Up 60% Completed
Forum Activity 4%
FF Reputation: 1 SVTsteele Good Standing Member
Any updates?
SVTsteele is offline
