Several Spontaneous Electrical Issues - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-09-2013, 06:24 PM   #11
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
You might be onto something with the GEM module. As I was printing off the schematics for the systems you've listed - defrost, instrument cluster, blinkers, brake lights, rear wiper - the GEM module in the right "A" pillar is present in each circuit.
pm replied.
BC_ZX3 is offline
Old 06-13-2013, 09:42 PM   #12
MikeD666
Fan#: 115572
What I Drive: 2007, Silver, SES
FF Reputation: 1 MikeD666 Good Standing Member
Update:
I received GEM on Ebay from a smashed car of the same year. The posting claims that it will work on my year car if it has power locks/multifuntion. Here is the link - http://cgi.ebay.com/ws/eBayISAPI.dll...d=879215804013 Does anybody know what multifunction is?
These were not actual pictures. The part plugged and played well. I have part numbers available if anyone thinks necessary.
Started the car, and nothing behaved any differently. Same fuses same problems. I'm toying with the thought that possibly both parts were bad, but highly doubtful.
I replaced R25 relay for the heck of it with a new part, no change.
This leaves me with the rear hatch heater button to test with a swapped out known working one. I'm still not certain that this would have any issue on the cluster or rear wiper. I'm also toying with the thought of the blinker switch handle thing.
I'm desperate for any more suggestions. I've still been studying the wire diagrams from BC_ZX3 - the only thing I'm seeing common is the GEM. I cannot deny that I really do not have the expertise to read them 100%.
Any recommendations on next step?
MikeD666 is offline
Old 06-13-2013, 10:30 PM   #13
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 324, Level 6
Points: 324, Level: 6 Points: 324, Level: 6 Points: 324, Level: 6
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 10%
FF Reputation: 8 Milton Good Standing Member
Wiring diagrams and a volt meter. Slow and methodical.
Milton is offline
Old 06-13-2013, 10:45 PM   #14
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,746, Level 73
Points: 12,746, Level: 73 Points: 12,746, Level: 73 Points: 12,746, Level: 73
Level Up 74% Completed
Forum Activity 99%
I'm guessing "power locks/multifunction" refers to door locking, trunk unlock, panic alarm functions of the key fob.
Noticed you'd asked earlier about dash screws still out/grounds. Metal dash sections that aren't screwed to anything COULD result in an incomplete ground circuit, since the chassis is used as a ground. Also, if you happen on any wires hanging loose with circular wire terminals at the end, these are ground connections that HAVE to be screwed to a grounded metal area.
Relays that provide power to circuits need a ground to function, no ground = relay that won't work, so no power can be supplied.
I'll describe their workings in my next post, think on these hints while I type some more (grin)
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 06-13-2013, 10:57 PM   #15
MikeD666
Fan#: 115572
I went through a little bit with a voltmeter earlier. I was not able to test the wires to the harness for the rear defrost switch - as the ports were too small to reach the pins.
All 4 fuses not receiving power have a voltage of 0.02. Everything else read fine on the fuse box voltage wise.
All grounds I could find looked good externally. I never touched them prior to this work.
I will try and get a better look at the dash later to see if anything is loose. I have looked it over pretty good in the last week already though. I believe I got all the screws back in. I did make an attempt to remove the air bag compartment, but backed out.
I found 2 wires that dead end in some kind of socket. One behind the radio that is clipped to the dash framing - I don't know if this is meant for grounding or testing of some sort. Also the was located near the shifter. I do not see anything loose that connects to these, nor do I recall removing anything from these areas.
Blend door seems to be working good....ha
MikeD666 is offline
Old 06-13-2013, 11:20 PM   #16
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
For a "Primer" on relays;
Basic relay has two circuits, control & controlled power.
Control circuit has a switched low power "hot" input, that goes through a coil internal to the relay, then out to ground.
Controlled Power has a "hot" input, which is connected to it's output by the electromagnetic coil switch when that is energized.
Sample from earlier in the posts;
7A fuse provides power to a switch, when that is on power continues to a relay & then to ground. IF that circuit is complete, the relay switch is closed to complete a power circuit to feed an accessory (like the rear defrost).
Power may go direct to the hot power side of the relay, then to a larger fuse, and continue to the accessory - then to ground to complete the circuit.
SO - if the relay control circuit isn't grounded, relay can't close, power won't go to that large fuse, and the accessory doesn't work.
Exact paths need to be confirmed by the wiring diagrams, but that's an example of how you could get the results you are experiencing.
Hope that helps, it'll give you something to think on at least!
Cheers!
"Rubber Side Down"
sailor is offline
Old 06-13-2013, 11:24 PM   #17
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Sounds like you have a manual transmission, the "extra" plug near the shifter would be a control circuit for an automatic.
Can't guess on the other for sure, harness has functions for many things that are optional.
Luck!
"Rubber Side Down"
sailor is offline
Old 06-14-2013, 12:05 AM   #18
MikeD666
Fan#: 115572
Thanks for the replies. I did not mean to confuse, this is an automatic. I guess I meant the gear selector.
I understand that the end result is further investigation. I just cannot imagine that a ground is bad. The only ones I have found so far are - one on the cabin fuse box - and one on each of the Column A side panels well hidden/protected. I'm still going with the assumption that I've caused this problem.
sailor, when you refer to the ground for the relay, would there be a new second ground when the additional current is applied? I would have to find where this terminates as well.
I've replaced a couple relays, and a few are swap-able. I hate to make these assumption all the time, but assuming they are not all bad, the swapping around method should work for test purposes. I feel the click of all the relays under then hood fuse box when turning the key. None of the two inside feel this way, even with the one I've replaced...and it sounds as if r25 will click when the rear defrost is selected.
I will get my hands on an identical rear defrost switch tomorrow. I'm leaning against this being my problem, as it is pretty well constructed, and has never had issue. If it result from the harness, I would be surprised as well. As I mentioned previous, the harness on this device is one of the tighter ones, even with a plastic tie. It was also easily removable.
Any suggestions or educational comments welcomed!
MikeD666 is offline
Old 06-14-2013, 01:40 AM   #19
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,233, Level 100
Points: 138,233, Level: 100 Points: 138,233, Level: 100 Points: 138,233, Level: 100
Level Up 0% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (11)
Have you checked the rear hatch wiring where it comes out of the body and goes into the hatch? The wires right there tend to crack the insulation on them and touch each other or the body and can cause all sorts of weird electrical problems. Just pop the hatch and pull the rubber boot off and take a looky see.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 06-14-2013, 01:50 AM   #20
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Didn't confuse, I was guessing since many with 5-spds find an empty connector there the automatics use.
You've found some grounds I see, that one near the fuse box could possibly have caused the issues if it wasn't connected.
Relay needs a ground to work (click & close contacts). This can even be "switched" as well for more complicated circuits.
I know the Focus uses at least SOME switched grounds from prev. threads where folks thought a switch was bad 'cause they didn't see power there - it was a switched ground & the fault was elsewhere so no power got to that connector.
I'm working without a schematic, just throwing out info. on how things work in general.
For another example, if you probed that R25 socket and found power at 2 pins, one of the others would likely go to the rear defrost, and the other would be switched ground through the defrost switch & timer.
This is where the schematics come into play, tracing what SHOULD happen on paper, so you can test for where it's working right & where it doesn't match the expected result.
Luck!
"Rubber Side Down"
sailor is offline
