Spark plugs for Ti-VCT - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-14-2013, 01:04 PM   #11
Roadworthy
Fan#: 109039
What I Drive: 2012 SGM MK3 Titanium
FF Reputation: 1 Roadworthy Good Standing Member
Here is something to consider: since our engines are higher compression, direct injection, a larger spark gap may not actually be the answer.
A dyno would give a better idea of what is going on but think of this: say a larger spark has a wider spark but still the same amount of energy released by the coil. A wide and thinner spark may seem to provide a better burn but it is also less stable. High rpm, high load at WOT and there is a chance you could still get spark blowout.
What you really want is the most spark energy throughout the entire powerband. I'm not totally sure how the ecu handles spark advancement/dwell and recharge or if they are all preset and static.
So in the end a smaller gap (stock 0.036~) may also be good for best overall performance/economy.
2012 SGM Ti DCT Stock and loving it
OEM multispoke 17" with stock rubber summer-X-ice 3's on stuck rims = awesomesauce
Roadworthy is offline
Old 03-22-2014, 05:49 PM   #12
PhillySwindon
Fan#: 150530
What I Drive: Focus titanium 1.6 ti-vct
FF Reputation: 1 PhillySwindon Good Standing Member
What engine size are you referring to? As I'm in the uk, and think the only engine size for the ti-vct engine is a 1.6, which is what I have. So with that in mind, will that mean that plugs for a 2.0 litre engine may be different to 1.6? I've been looking at boschs website and they have two types, laser platinum, and another type but it doesn't say much about them, think they're yttrium? But I sent an email, and they said they have the super 4 range for the focus cmax ti-vct which I'm hoping is same as standard 5 door hatch, but they do know show up when you use the search feature, and I used the exact same model number super 4 plugs on a zetec-e engine. But the super4 were brill, had better fuel economy and car was more responsive. If I was to recommend plug leads, I'll always say magnecor, but not sure if the 8.5mm type will fit in the lead holders easily, but I'm confident that even the 8mm type will be one if the best you can get (honestly I don't work for the company, just reading uk mags such as fast ford, max power, redline etc, a lot of ppl will choose these, and they can do custom leads, their website is very detailed explaining the diff types if distributors and sealing boots, so they know their stuff.
PhillySwindon is offline
Old 04-18-2014, 10:26 AM   #13
Tyfocus95
Tyfocus95's Avatar
Fan#: 120306
What I Drive: '14 Race Red SE sedan
Points 353, Level 7
Points: 353, Level: 7 Points: 353, Level: 7 Points: 353, Level: 7
Level Up 6% Completed
FF Reputation: 2 Tyfocus95 Good Standing Member
How often should plugs be changed?
Tyfocus95 is offline
Old 04-18-2014, 01:32 PM   #14
Kjanracing
Kjanracing's Avatar
Fan#: 135409
What I Drive: 2014 Ruby Red SE hatch with DCT
Points 503, Level 10
Points: 503, Level: 10 Points: 503, Level: 10 Points: 503, Level: 10
FF Reputation: 2 Kjanracing Good Standing Member
the mileage in the service schedule is 100K miles. I'll probably do mine at 50K. They are easy to do.
K&N drop in. Ceramic Smervic bearing retrofit. DCT Phase Detractor delete. Injected Tune. Back Joy seat cushion.
Kjanracing is offline
Old 04-18-2014, 02:01 PM   #15
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,767, Level 73
Points: 12,767, Level: 73 Points: 12,767, Level: 73 Points: 12,767, Level: 73
Level Up 80% Completed
Forum Activity 99%
Good idea.
Even if you don't change them that early, removal/inspection/a bit of never-seize on the threads is a good idea at that mileage. Plugs left untouched too long can be a problem to remove.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 04-18-2014, 03:27 PM   #16
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,725, Level 24
Points: 1,725, Level: 24 Points: 1,725, Level: 24 Points: 1,725, Level: 24
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 10%
FF Reputation: 5 Miller88 Good Standing Member
I did mine around 35K. Didn't want them to seize in the aluminum head. I know iridium plugs are supposed to go at least 100K ... but on my 2011, they were out of gap spec at 35 (or there abouts).
I replaced with platinum. Will change again at 70K
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 04-18-2014, 03:32 PM   #17
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,240, Level 95
Points: 25,240, Level: 95 Points: 25,240, Level: 95 Points: 25,240, Level: 95
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 3%
Exactly this. They will last longer than most (all?) other types, but they still wear down. I pulled mine at 30k (habit) and re-gapped them along with applying some anti-seize on the threads.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 04-18-2014, 07:07 PM   #18
Jburks
Jburks's Avatar
Fan#: 145009
What I Drive: 2014 Ford Focus Hatchback SE RR DCT
Points 4,960, Level 45
Points: 4,960, Level: 45 Points: 4,960, Level: 45 Points: 4,960, Level: 45
Level Up 5% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 1 Jburks Good Standing Member
So it's probably a good habit to do them around 30-35K then? i've always done mine on other cars around 60K. These being as easier as they are to replace though, i'd have no problem doing them sooner.
2014 Focus SE DCT RR. "Fiona"
Mods- Green Drop in-Snorkel Delete-plastidip-RokBlokz
Instagram- _jburks_
Build thread-http://www.focusfanatics.com/forum/showthread.php?t=382642
Jburks is offline
Old 04-19-2014, 11:55 PM   #19
Miller88
Fan#: 73790
Forum Activity 10%
Pull and regap. Iridium tips last much longer. Plus, it's good to get them out sooner rather than later.
Miller88 is offline
