Spark plugs for Ti-VCT - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-07-2013, 05:30 PM   #1
hemetaj
Fan#: 110422
What I Drive: 2012 Red Focus SEL
FF Reputation: 1 hemetaj Good Standing Member
Does anyone know if there is aftermarket plugs yet for the Ti-VCT engine? I would like to upgrade mine and can't seem to find any listed online other than the Ford plugs.
hemetaj is offline
Old 06-07-2013, 05:33 PM   #2
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 8,163, Level 61
Points: 8,163, Level: 61 Points: 8,163, Level: 61 Points: 8,163, Level: 61
Level Up 5% Completed
Forum Activity 9%
FF Reputation: 11 Joeywhat Great Standing Member
Only iridium plugs right now. No coppers yet
Hatch Nation #29
Joeywhat is offline
Old 06-07-2013, 05:37 PM   #3
hemetaj
Fan#: 110422
Any word on Pulstars?
hemetaj is offline
Old 06-10-2013, 05:37 AM   #4
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What I Drive: 2013 Oxford white Sedan 5M
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tjrommel Good Standing Member
Why would you want copper, faster wear, weaker-less accurate spark, and picks up the carbon faster. From what I've heard, the iridium plugs paired with the stock coil packs actually has a noticible gain in mpg and slight increase in power on a DYNO (1-2hp).
Tjrommel is offline
Old 06-10-2013, 06:50 AM   #5
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 591, Level 11
Points: 591, Level: 11 Points: 591, Level: 11 Points: 591, Level: 11
Level Up 82% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
why would you want to put that crap into your car? Spark plugs are not a modification .... imho.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is offline
Old 06-10-2013, 03:46 PM   #6
Roadworthy
Fan#: 109039
What I Drive: 2012 SGM MK3 Titanium
FF Reputation: 1 Roadworthy Good Standing Member
Been there done that. The stock ones are fantastic iridium fine tip and will have the best performance and wear. I've spent hours trying to find anything better and...nope. We actually have great plugs! Change out the aluminum wire inside the coil boot to a full copper strand (8ga I believe) and do better that way. Play with the stock gap and higher gaps if you want to play around with things (use a proper gapping tool, not a ring gapper that only opens them up).
2012 SGM Ti DCT Stock and loving it
OEM multispoke 17" with stock rubber summer-X-ice 3's on stuck rims = awesomesauce
Roadworthy is offline
Old 06-11-2013, 07:12 AM   #7
ryan_onizuka
Fan#: 107709
What I Drive: Focus MK3
FF Reputation: 1 ryan_onizuka Good Standing Member
I using BRISK ER14YS SILVER.
ryan_onizuka is offline
Old 06-11-2013, 07:33 AM   #8
kylesvt720
NeedsMoarEverything
kylesvt720's Avatar
Fan#: 51359
What I Drive: 2006 Saabaru "The Unicorn"
Points 10,922, Level 69
Points: 10,922, Level: 69 Points: 10,922, Level: 69 Points: 10,922, Level: 69
Level Up 18% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 17 kylesvt720 Great Standing Member
In the zetecs, svts and duratecs (03-11), everyone had the best luck with properly gapped coppers. Not just stock, but pretty extensive builds.
Jeremy Clarkson on Detroit: “God may have created the world in six days, but while he was resting on the seventh, Beelzebub popped up and did this place.”
ST CREW #107 / TEAM DURATEC #93 / D23 Crew #3
kylesvt720 is online now
Old 06-11-2013, 07:36 AM   #9
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
I wonder how there LGS plug would work
Seminoles is offline
Old 06-14-2013, 12:53 PM   #10
CriticalMass
Fan#: 63989
What I Drive: 2014 Ford Mustang GT Premium Brembo
Points 386, Level 7
Points: 386, Level: 7 Points: 386, Level: 7 Points: 386, Level: 7
Level Up 72% Completed
FF Reputation: 2 CriticalMass Good Standing Member
True.
The platinums provide a weaker spark than the coppers do. Also gapping them out a little further than spec (55 instead of 50) provides a larger spark. And really, so what if you have to replace plugs once a year? It takes a whole, what, 20 minutes?
Copper Spark Plugs
Copper spark plugs are generally considered to have the best performance of any spark plug type. This is potentially different from what advertising companies suggest, but the other metals are, unfortunately, not as conductive in general as copper is. Platinum and iridium plugs are more likely to overheat, which causes damage to the plug components and can compromise the delivery of the spark to the engine block.
Platinum and Iridium Plugs
Platinum and Iridium plugs perform at a lower level than copper spark plugs, because they are less conductive and they tend to overheat. However, the overall longevity of these two types of metal is better than copper plugs. In reality, copper has the best performance of all three and the worst longevity. Platinum has good longevity and the worst performance. Iridium has good longevity and a performance that is decent, which is why iridium plugs tend to be more expensive than any other type. Still, the difference between these plugs in terms of overall quality is minimal, as there is a trade off for each.
Here are some of the thermal conductivity ratings of some commonly used metals (Watts / centimeter*Kelvin). As you can see, copper is untouchable. Iridium gives you the best trade-off between performance and lifespan.
Zinc = 1.16
Aluminum = 2.37
Copper = 4.01
Steel = 0.70 - 0.82
Platinum = 0.716
Iridium = 1.47
However, different engines and systems will work better/worse on different types of plugs. Some older Dodge Neons REQUIRED Coppers (they had a TSB concerning the use of Champion Copper's ONLY because other types caused rough/poor idle conditions)
Another issue with the Duratecs is that the copper plugs seem to smooth out the idle and reduce engine vibration. The HP gains? I'm not willing to say if that's true or not, but a good set of plugs can definitely smooth out idle issues and increase fuel mileage.
2014 Ford Mustang GT Premium + Brembo Package, SGM.
CriticalMass is offline
