Boot Lock Wire/Connector - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2013, 05:48 PM   #1
TheSheerOg
Fan#: 96730
What I Drive: 2007 Black 1.8 Focus Sport S
Points 759, Level 14
Points: 759, Level: 14 Points: 759, Level: 14 Points: 759, Level: 14
Level Up 59% Completed
FF Reputation: 1 TheSheerOg Good Standing Member
My original boot lock decided to die on me quite awhile back, the boot worked fine, then it started unlocking itself when I turned the car on, and would stay open even after trying to slam it shut, until finally 1 day it died and I was left with only the key option to open it manually.
I recently got around to checking the connector, and I found all 3 pins from the connector had completely rusted away, and the socket on the boot lock looked quite rough. So I went to the scrap yard and took one from another vehicle, along with a snipped off connector.
I snipped off my old dead connector and using wire connectors, put that together, and installed the new boot lock, and hey presto, it worked again !
For a a couple of months, then that again started acting funny, opening itself etc, until it finally died, so I checked it the day it did die, and found smoke coming out of it :| Checked the connectors, they were intact with no sign of damage.
Went and got another boot lock, fitted it, worked fine, for a few days, then that died too just like before.
Im looking to replace the whole wire for the connection to the boot lock, but im not sure how easy, or where to source the wire, and how easy to install it it would be. Anyone have any experience in this ?
TheSheerOg is offline
Old 06-05-2013, 06:47 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,795, Level 73
Points: 12,795, Level: 73 Points: 12,795, Level: 73 Points: 12,795, Level: 73
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 99%
One comment that might be helpful..
Hatch wiring harness, from body to hatch & driver's door harness, body to door are known to often have wiring issues inside their covering - wires break, insulation cracks & comes off, short circuits & odd operation results. Flexing & age are the causes, not unique to the Focus Models.
I'm thinking some of the odd operation, and the short life of the replacement, might be caused by an issue there with the wiring to the boot lid.
Worth checking out in your wiring project to prevent a repeat!
Cheers!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 06-05-2013, 10:10 PM   #3
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
What is a 'Ghia'?
Is it a sedan or some sort of a 'hatchback'
IF it is a hatchback or perhaps wagon there are many reported problems with the wire umbilical with the wires shorting out inside due to the constant flexing of the umbilical between the body and the 'hatch'
mikeeshaq is offline
Old 06-06-2013, 03:32 AM   #4
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
FF Reputation: 68 TerryB Excellent Standing Member
TerryB is offline
Old 06-06-2013, 07:39 AM   #5
TheSheerOg
Fan#: 96730
I had a quick look on my lunch break, and found this -
A small black wire appears to be exposed, while the big (tube?) wire is split, only connected by a couple of strands, but cant see anything inside it.
Old 06-08-2013, 11:40 AM   #6
TheSheerOg
Fan#: 96730
Any ideas what the big black tube/wire is ? I cant actually see anything inside it. With the exposed wire, would wrapping some insulating tape around it do the trick ?
Old 06-08-2013, 12:39 PM   #7
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 324, Level 6
Points: 324, Level: 6 Points: 324, Level: 6 Points: 324, Level: 6
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 10%
FF Reputation: 8 Milton Good Standing Member
If there are only a few strands intact then no just wrapping it with tape will not do. All of those wires need to be examined and repaired. If you do not know how to do that find someone who does. A friend who can teach you or hire a pro.
Milton is offline
Old 06-16-2013, 06:43 AM   #8
TheSheerOg
Fan#: 96730
The black wire with the wires shown apart looks to be intact, so I think wrapping that up would be ok, im just concerned about the thicker tube and how that's pulled apart, im not even sure what it is for, as I cant actually see anything inside it.
I have a couple more boot locks ready to connect up that I grabbed from the scrapyard ready to connect up. Does anyone know the earthing points for the rear wiring harness ? I checked the one on the boot near the spare wheel, and also the one on the rear washer actuator, they both look absolutely fine. Just wanted to see if there were a few more worth checking.
Sorry if I sound completely dumb about all this, im a noob eager to learn :)
Old 06-18-2013, 03:59 PM   #9
TheSheerOg
Fan#: 96730
Figured out what the big black tube was .... the god damned rear washer tube ! So the water spraying out of that onto bare wires = bad times. Mystery over !
Old 06-19-2013, 11:10 AM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Hah - you got it!
I was thinking of that while waiting for the picture to load, low speed connection where I'm at right now...
THAT'S figured at least!
"Rubber Side Down"
sailor is offline
