Challenge: Can you beat the Diagnostic? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-05-2013, 04:05 PM   #1
Focused_On_Graton
Fan#: 51996
What I Drive: Looking to buy 2004
FF Reputation: 1 Focused_On_Graton Good Standing Member
Hi friends,
I'm not sure how to best get help here.. all help APPRECIATED!
Paid $140 for a Diagnostic at Firestone. They can not find anything...
I'll drive along, and the engine starts to cough, lose power.
The car actually just chokes out and dies.
But, if I massage the gas pedal just right.... force a lot of fuel in there.. it picks up and ZOOOOM! takes off with SO MUCH power.
When it starts to cough, the only *certain* solution is to pull over, switch ignition to OFF, start it right back up, and it's good as new for a day or two.
Thank you Please for ANY INSIGHTS! - Please respond here and to: dasani25@hotmail.com - David
2005 manual transmission ST
Focused_On_Graton is offline
Old 06-05-2013, 04:21 PM   #2
bshin352
bshin352's Avatar
Fan#: 114147
What I Drive: 2013 Tux Black Ti Sedan, DCT
FF Reputation: 1 bshin352 Good Standing Member
Originally Posted by Focused_On_Graton View Post
Hi friends,
what exactly did the diag check for?
are you blowing smoke of anykind out the rear?
bshin352 is offline
Old 06-05-2013, 04:36 PM   #3
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,780, Level 54
Points: 6,780, Level: 54 Points: 6,780, Level: 54 Points: 6,780, Level: 54
Level Up 15% Completed
Forum Activity 47%
Activity: 47% Activity: 47% Activity: 47%
Buy-Sell-Trade Rating: (23)
How many miles are on the car David?
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 06-05-2013, 05:26 PM   #4
donzilla2004
Fan#: 115447
What I Drive: 2014 Focus ST1
Points 68, Level 1
Points: 68, Level: 1 Points: 68, Level: 1 Points: 68, Level: 1
Level Up 36% Completed
FF Reputation: 1 donzilla2004 Good Standing Member
I would make sure you don't have a collapsed PCV hose or a vacuum line of that sort. Many times when the hose gets hot it collapses or it has a hole in it that opens up when soft. I would check over all your vacuum hoses.
donzilla2004 is offline
Old 06-05-2013, 05:57 PM   #5
Focused_On_Graton
Fan#: 51996
>>what exactly did the diag check for?<<
It was a "full electronic diagnostic" meant to pulls codes from computer; a scanner is plugged into obd 2 port; spits out why check engine is on
ran data stream from there; when it peaks etc.
>>are you blowing smoke of anykind out the rear?<< - NO
>>How many miles are on the car David?<< 105K
thank you!
Old 06-05-2013, 07:05 PM   #6
bshin352
bshin352's Avatar
Fan#: 114147
okay so we know of no codes. i agree with donzilla on the vac lines. check those esp with 105k on the clock.
bshin352 is offline
Old 06-05-2013, 07:22 PM   #7
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 328, Level 6
Points: 328, Level: 6 Points: 328, Level: 6 Points: 328, Level: 6
Level Up 56% Completed
FF Reputation: 10 Milton Great Standing Member
His long have you owned it (mileage when you got it)?
What maintenance have you done?
Ever replaced the fuel filter?
Milton is offline
Old 06-05-2013, 08:00 PM   #8
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 47%
^this
Hatch Nation #140
freemind is offline
Old 06-05-2013, 09:06 PM   #9
JFrye
JFrye's Avatar
Fan#: 54896
What I Drive: 2000 ZX3, 99 Dodge 3500 w/Cummins
Points 1,749, Level 24
Points: 1,749, Level: 24 Points: 1,749, Level: 24 Points: 1,749, Level: 24
Level Up 49% Completed
Forum Activity 3%
FF Reputation: 3 JFrye Good Standing Member
Buy-Sell-Trade Rating: (6)
Maybe a bad connection/wire to the fuel pump, or coil pack?
00 Silver ZX3. Zetec, ATX w/3.90 gears. 14" orange steelies. Eibach Sportlines, Massive Strut Bar, BBK 65mm TB, 4 to 1 Header followed by 2.5" into 3" exhaust.
Hatch Nation #31
JFrye is online now
Old 06-06-2013, 12:38 AM   #10
amc49
Fan#: 96610
Points 3,362, Level 36
Points: 3,362, Level: 36 Points: 3,362, Level: 36 Points: 3,362, Level: 36
Level Up 8% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
Well, you asked and it has started, or get ready to throw a stream of parts at the problem.
Last three posts bring up good points. If you are idling fine all the time then disregard any vacuum leak suggestions. If you are NOT idling fine then a big mistake not mentioning it.
Just because you show no codes means nothing, often something happens and not logged as a fault yet since the computer has not made up its' mind what to do with it. They may well be logged as pending codes which many readers will not read.
Can't imagine paying for code reading when it's free in so many places now. You could've bought your own reader for that price.
amc49 is offline
