shifter cable our bad syncro ? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-04-2013, 07:42 AM   #1
sally03svt
Fan#: 96070
What I Drive: 2003 red svt, 2010 black ses
Points 524, Level 10
Points: 524, Level: 10 Points: 524, Level: 10 Points: 524, Level: 10
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 sally03svt Good Standing Member
I need some help please for about a month now I haven't had reverse the plastic bushing peice on the side of the shifter busted so I have alot of play in shifter. Putting it in reverse was tough but it would go now I can put it were reverse is supposed to be and it is first gear ? I've inspected both ends of the cables and they seem fine what.do I need to look for to tell if its a cable our my tranny. Thank you for the help.
sally03svt is offline
Old 06-04-2013, 07:46 AM   #2
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2008 chevy cobalt SS/TC.
Points 2,840, Level 32
Points: 2,840, Level: 32 Points: 2,840, Level: 32 Points: 2,840, Level: 32
Level Up 60% Completed
FF Reputation: 6 05focusST91 Good Standing Member
Try replacing the bushing first, if not the cables are probably no good, make sure that the cables are attached to the bracket properly too.
Funtion>form.
FLOOR IT!
2005 focus ST (gone)
Still here!
05focusST91 is offline
Old 06-04-2013, 11:03 AM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,871, Level 74
Points: 12,871, Level: 74 Points: 12,871, Level: 74 Points: 12,871, Level: 74
Level Up 6% Completed
Forum Activity 99%
Yah, too much slop in the shifter & it won't move the cables as needed. No synchro for reverse, so that can't be an issue...
Sounds like the boot is off so you can see the mechanism. You'll notice that front to back movement of the lever moves one cable, and there are mechanisms to move the other with side to side movement. Cable moves one way when pushed left, then another way when pushed right, off of the center position. Sounds like you're not getting that second cable (L&R) to move as needed because of the broken pieces...
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-04-2013, 11:35 AM   #4
sally03svt
Fan#: 96070
ok and thanks again for the help will Ford have this plastic bushing like thing pour is it special order it.
Old 06-05-2013, 03:50 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
More than likely a "Special Order" piece I'm afraid...
Tousley Ford in MN has been a good mail order source, "Steve" is our best contact there.
Village Ford is a new sponsor here, "Andy" is their rep. and they have a section on this site.
I'd look close for other worn/damaged pieces, just 'cause of the likely wait for parts. SVT should have a metal frame for the shift mechanism, that's a good thing since a number of the plastic frames on other models have been found to break causing similar issues.
Luck!
"Rubber Side Down"
Old 06-06-2013, 10:55 PM   #6
sally03svt
Fan#: 96070
Well ordered that plastic peice for the.shifter do hopefully I'll have reverse this weekend ! And then on to fix the other problems.
Old 06-14-2013, 10:52 AM   #7
sally03svt
Fan#: 96070
Hot dog ! I finally have reverse again ! Not only did I have to change out the plastic bushing but the L shaped bracket that puts the car in reverse on the side of the shifter was chewed up bad so I found a shifter from a wrecked svt and BAM ! I gots reverse. Thanks for all the help guys much appreciated
