Removing active grille shutters - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-04-2013, 04:50 PM   #11
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
Originally Posted by suss6052 View Post
Sure I'll get right on that, although it would be easier and safer to buy a go-pro and mount it to the front of the car pointed looking inwards towards the active grille shutters than it would be to crawl over the hood on a straight stretch of road at 70 mph or so.
Easy and safe, but soooooooo boring in comparison.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 06-07-2013, 10:01 PM   #12
rdsx18
Fan#: 115544
What I Drive: 2012 Focus SE
Points 6, Level 1
Points: 6, Level: 1 Points: 6, Level: 1 Points: 6, Level: 1
Level Up 11% Completed
FF Reputation: 1 rdsx18 Good Standing Member
The AC sucks in my Focus too, glad to see I'm not the only one. My 05 Mustang will get ice cold real quick, but it seems like the Focus takes a solid 15 minutes to get cool in 80 degree weather.
rdsx18 is offline
Old 06-07-2013, 10:47 PM   #13
05_GT
Fan#: 111293
What I Drive: 2014 Mustang GT Premium, Race Red
Points 98, Level 1
Points: 98, Level: 1 Points: 98, Level: 1 Points: 98, Level: 1
Level Up 96% Completed
FF Reputation: 1 05_GT Good Standing Member
Dealing with the (real) heat down here in the Houston area and my A/C has never had any issues. It cools down the cabin very quickly.
2011 Focus SEL, Silver, Bone Stock
2014 Mustang GT Premium, Race Red, MT82, Steeda Tuned.
05_GT is offline
Old 06-09-2013, 06:34 PM   #14
Seminoles
Seminoles's Avatar
Fan#: 98405
What I Drive: 2012 SGM SE Sedan
Points 969, Level 16
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 1 Seminoles Good Standing Member
Are you losing coolant if so have dealer replace radiator cap known problem.
Seminoles is offline
Old 09-27-2013, 10:39 AM   #15
motor
Fan#: 119291
What I Drive: 2001 White Punto
FF Reputation: 1 motor Good Standing Member
They can be removed. The Mountune intercooler kit has the installer remove them, tape up the connector and fix it to a safe location. Since this kit doesnt void the warranty and in the UK is even installed by some Ford dealers you dont need to worry about it hurting the car.
I miss the old R12 a/c units I had in my old cars, with the new 'ecofriendly' refrigerants that everyone has to use and efficiency standards set high I dont think a/c units in any car will be as frosty as they used to be.
You might want to use a cheap thermometer to measure the outlet A/C temp with the system set on recirculate and max. That is usually the standard dealership techs use to gauge if the system is working normally. That might help you talk to the dealer about what to expect.
And I believe your car uses the pressure in the a/c system as a trigger to open the shutter. So it is supposed to open the grills if the a/c system is struggling.
motor is offline
Old 09-27-2013, 11:35 AM   #16
BrApple
BrApple's Avatar
Fan#: 95810
What I Drive: 2012 Red Candy SE HB
Points 578, Level 11
Points: 578, Level: 11 Points: 578, Level: 11 Points: 578, Level: 11
Level Up 56% Completed
Forum Activity 2%
FF Reputation: 1 BrApple Good Standing Member
Although I can say my ST doesn't seem to have nearly as cold an air conditioning as my SEL did even though both had the exact same grille shutter system and more than likely the same condenser.
My guess would be the intercooler and its location in front of the raditor. When I added a turbo and front mount to my Contour I noted that if I didn't turn the A/C before moving, more so on the highway, the A/C would not be very cool. But let it run first then drive and it was fine. My take on this is the heat from the front mount intercooler not letting the A/C condesor work as it should.
- 12 Focus SE - 5spd
- 99 Contour SeVT <- 3L/NPG Turbo
- 2k Contour SVT - #2137
- 12 Impreza 2.0i Premium - CVT
BrApple is online now
Old 09-27-2013, 12:48 PM   #17
xwhit3devilx
xwhit3devilx's Avatar
Fan#: 86578
What I Drive: 2014 Hyundai Veloster Turbo
Points 5,510, Level 47
Points: 5,510, Level: 47 Points: 5,510, Level: 47 Points: 5,510, Level: 47
Level Up 80% Completed
FF Reputation: 2 xwhit3devilx Good Standing Member
Question- if the Grille shutters are open whenever the air is on, does that mean if you use AC on the highway the shutters will stay open all the time?
xwhit3devilx is offline
Old 09-27-2013, 12:55 PM   #18
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
I believe they do stay open anytime the A/C is on. However, I have not been able to hold on tight enough to the hood at highway speeds to physically examine that theory.
Hatch Nation #90
TboneZX3 is offline
Old 09-27-2013, 02:44 PM   #19
xwhit3devilx
Fan#: 86578
Lol. That would explain why I can only get 36mpg or so on the highway. With the AC turned off I average closer to 40, granted not having the compressor running helps efficiency a lot.
Old 09-28-2013, 07:19 AM   #20
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
That sounds about right. I experience a difference of about 3 MPG highway dependent on the A/C being on or off. That seems in line with most other cars I've owned in the past though, so it's hard to say what portion of that difference can be attributed to the shutters.
Hatch Nation #90
TboneZX3 is offline
